1098/1198 "Ohlins" 30mm Triple Clamp Set - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!SportbikeTrackGear
Old Jan 7th, 2011, 2:06 pm   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
MW Billet "Ohlins" Titanium Triple Clamp Set: 1098/1198 30mm
Sale Price: $599.99
List Price: $899.00 **only one set left at this price**
Performance billet triple clamp set for the 848-1198 series.
These triples have a 30mm offset for better stability and include an aluminum headstock pin and hardware to replace the heavy original steel headstock pin. Available finished in titanium gray with 53/56mm diameter for the Ohlins forks. No adapter is required.
These 30mm offset triple clamps add 6mm of trail. You will be able to finish the turn better by allowing you to get on the throttle earlier. The bike will hold your line better as well as get a better overall "feel" for the front end. The 6mm change shortens the wheelbase making the bike turn faster with less effort.
This triple clamp assembly will not require any modifications to the frame
Pictured unanodized to show details.
Old Jan 7th, 2011, 2:09 pm   #2 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
1098/1198 "Showa" Black 30mm offset Triple Clamp Set:
We also have 3 of these left for the Showa forks:
MW Billet "Showa" Black Triple Clamp Set: 1098/1198 30mm offset
Sale Price: $599.99
List Price: $899.00
These triples have a 30mm offset for better stability and include an aluminum headstock pin and hardware to replace the heavy OEM steel headstock pin. Available in black with 53/53mm diameter for Showa forks.
The 30mm offset triple clamp adds 6mm of trail. The additional trail will allow you to get on the throttle earlier so you can finish your turns better. The bike will hold the line better as well as giving you a better "feel" for the front end. The 6mm change shortens the wheelbase making the bike turn faster and with less effort.
Fit Notes:
848 application: No cutting of steer stops necessary with this triple clamp
1098/1198 30mm Offset Triple Closeout moto Motowheels 0 Oct 12th, 2010 10:49 pm
Can one fit a 999 top triple clamp, and front rotors to a 1098/1198? dantevelasquez Superbikes 4 Oct 26th, 2009 9:47 am
Need "triple" mearsurement 1098 showa Dyno-sore Superbikes 0 Jan 8th, 2008 5:40 pm
Stock triple clamp center "thing" - how to remove? Visolara Superbikes 12 Jun 4th, 2006 11:36 pm
