Titanium / Urethane Cush Drives - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!Motorcycle.com
Old Nov 16th, 2010, 1:57 pm   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Titanium / Urethane Cush Drives for SSSA Ducati / MV
AEM SSSA Titanium Cush Drives-5 pack
AEM SSSA Titanium Cush Drives-6 pack
These cush lugs have been designed and manufactured using the best-known materials and processes for the application. Specifically, these cush lugs were designed to prevent the inner lug or outer ring from separating and backing out of the rear cush/sprocket assembly. This is a common occurrence with the stock steel cush lugs on the 748-998 series and usually results in significant damage to the swingarm eccentric adjuster. The design of this lug will eliminate any displacement of the inner lug or outer ring - even if the elastomer de-bonds from the inner lug (the problem with the stock unit) or outer ring.
AEM Titanium Cush Drive Bushings are a direct replacement for the OE bushings for all single sided Ducatis.
The OEM rubber is replaced with a more durable urethane that slides in from the outside and is retained by a ridge on the inside.
Designed for safety wire.
Saves .5lb over OEM cush drives
Modular design allows the urethane cush drive to be replaced seperately.
Set of 5 fits Ducati 748-998/ S2R/S4RS/ MTS1000/HM/M1100/848 and MV Agusta 750/1000/Brutale
Set of 6 fits Ducati 1098/1198/Streetfighter/ MTS12/Diavel.
Old Nov 16th, 2010, 2:26 pm   #2 (permalink)
Wow! those are very nice! Good job!
dirkwrong is offline   Reply With Quote
Old Nov 16th, 2010, 8:15 pm   #3 (permalink)
Administrator
scott's Avatar
Images: 2
What about the beloved ST4s?
Scott
Sacramento CA
HDDC Posse
'05 BMW LT-C Ocean Blue
'03 Ducati ST4S with ABS
'08 BMW F800ST (Jessica's)
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scott is offline   Reply With Quote
Old Nov 16th, 2010, 9:45 pm   #4 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
These are Single Sided Swingarms,Scott..
The cush drives for the ST are simple rubber donuts.
If you are looking for some more bling on your ST4S, we can come up with something....
-M
Failed Cush Drives mackgoo Superbikes 8 Mar 18th, 2010 6:38 pm
Urethane Cush Drives SAC Superbikes 0 Jun 10th, 2008 2:48 am
need new cush drives, where ? wet Superbikes 1 Jul 6th, 2007 10:59 pm
Cush drives - questions ... fasterdammit Ducati Motorcycle Chat 2 Mar 27th, 2007 12:15 pm
cush drives devilshalo27 Superbikes 5 Mar 20th, 2007 9:17 pm
