Electrical Plumbing Info - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Oct 26th, 2010, 9:23 pm   #1 (permalink)
Gilly's Avatar
Images: 17
With Gregor's Hyper build also came some good info on electrical parts. I speak of the AMP SuperSeal 1.5 connectors and the tool used to crimp them.
So with Gregor's assistance, I gathered that info so you can use it if that issue comes up. So with that, here it is....
Electrical Tool
Crimping Pliers for Tyco/AMP Connectors
S&G Tool Aid 18920
Ratcheting Terminal Crimper Kit
S & G Tool Aid 18920 - Ratcheting Terminal Crimper Kit SGT-18920 SGT18920 SGT 18920
Listed Price $75
Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more
$74.95
MSD Ignition also makes a tool, but it is not in kit form. If you already have the tool, then purchasing the crimp dies might save you money. $25 each die.
CONNECTORS
Website Source is Mouser.com
AMP #282080-1 FEMALE Plug ($1.30/each)
AMP #282104-1 MALE Plug ($1.33/each)
AMP #281934-2 Seal Protector ($0.09/each)
AMP #281934-3 Wire Seal. Red (for unused wire port on plug)
AMP #282109-1 18-16 AWG Tab, Continuous Reel ($0.18/each)
AMP #282110-1 Connector Receptacle Contact ($0.12/each)
AMP #880810-1 Cover Cap Two Way ($2.51/each)
AMP #880811-2 Rubber Boot ($3.66/each)
Image not included due to the rules... It's a freakin rubber boot and it looks like the image above.
It's not that expensive to build a kit as Gregor did. My main goal was to find a reasonably priced crimping tool. The high end tool is well over $200! If you want this in the stickies, that would be fine, otherwise search for Electrical Plumbing Info when you forget about this thread in a week!
"Oh My!" thread link... FFS!
Old Oct 26th, 2010, 9:37 pm   #2 (permalink)
Expand the mind. Not a fuel tank
Wonway's Avatar
Great info. Thanks for the post Bill! My shop is actually in the market for connectors and I am going to look into your link.
Tom
Wonway is online now   Reply With Quote
Old Oct 26th, 2010, 10:03 pm   #3 (permalink)
Steve C's Avatar
Thumbs up
Thanks, good info to have in the old tool box. IIRC this is the style connector the tail/brake light uses, seems like the turn signals are different. One of my winter projects is the redo the front signal wiring, thanks to the butthead PO and his wire chopping activity.
Steve C
www.hamptonbengals.com
2008 Hyper 1100
2008 GSXR 750 Track Bike
1972 TM 250J-"Roger DeCoster"
Steve C is offline   Reply With Quote
Old Oct 29th, 2010, 12:19 pm   #4 (permalink)
Gilly's Avatar
Images: 17
Addition AMP Brochure Images/Part Number
I did some more looking and found a listing of the AMP Superseal 1.5 Part Numbers. Also one tidbit from TOB on a plug for the instrument panel on a Monster. Can't verify this, but it's still info.
AMP Superseal 1.0 26 Pin/4Rows Plug
AMP Superseal 1.5 Cover Page - Pretty Colors!
AMP Superseal 1.5 Receptacle Contacts
AMP Superseal 1.5 Tab Contacts
AMP Superseal 1.5 Single Wire Seals & Cavity Plugs
AMP Superseal 1.5 Rubber Boots
AMP Superseal 1.5 Connectors - Plug Housings
AMP Superseal 1.5 Connectors - Cap Housings
Old Oct 29th, 2010, 4:26 pm   #5 (permalink)
sakurama's Avatar
Hey Bill,
You've done me one better. Nice job pulling all that together. There's nothing better than having the right tool and the right part.
Thanks,
Gregor
photographymotorcycles
sakurama is offline   Reply With Quote
Old Oct 29th, 2010, 9:37 pm   #6 (permalink)
Gilly's Avatar
Images: 17
Fuel Line Quick Connect o-rings
Found some info on TOB on this. I have not verified this, but if you do some McGoogling, you come up with the same results that it is 99% a sure thing... Buy a bag, if they are the proper size, you will never have to purchase an o-ring for as long as you live. More importantly it sucks when you have to tell someone, "Sorry, I can't go, my o-rings are chaffed, and I'm waiting on replacements"
Again, I recommend people download any info from this post and save it locally.
Old Oct 30th, 2010, 10:43 am   #7 (permalink)
Steve C's Avatar
Dang Bill, you hit one out of the park again, nothin' worse than riding 'round with chaffed o-rings
Steve C
2008 Hyper 1100
Old Nov 5th, 2010, 7:26 am   #8 (permalink)
Images: 13
FWIW, mcmaster.com sells a similar "weatherproof low voltage DC pin and socket connector", no special tools required.
I used one under my tail and am happy.
McMaster-Carr
'03 Monster 620 Dark: Bought it, rode the piss out of it, sold it, binned it. (Yes, in that order.) RIP
'01 748 Red: Bought it, met a girl and left San Francisco for Syracuse, now longing for Bay Area roads...
crozzer is offline   Reply With Quote
Old Nov 6th, 2010, 6:20 pm   #9 (permalink)
Gilly's Avatar
Images: 17
McMaster-Carr
Nice addition! Also had the extractor tool. I do like the manner in which they have the parts listed. ++ on that for sure. While they are not AMP connectors, if you are doing something custom and not concerned with it, it is a good option to have. Thanks for adding that on!
ADDITIONAL INFO!!!
McMaster.com also has Rivet nuts! So if you strip out one of them on your bike and wondered how the hell to replace/fix it. They have some that may do the trick! Some refer to them as threaded brass inserts. I don't know if that is proper, but in any case they can fail.
http://www.mcmaster.com/#rivets/=9ltu8u
Old Jan 14th, 2011, 5:02 am   #10 (permalink)
k749s's Avatar
Thanks for the info
k749s is offline   Reply With Quote
Electrical Plumbing Info Gilly StreetFighter 14 Nov 1st, 2010 2:48 pm
Electrical Plumbing Info Gilly HyperMotard 5 Oct 31st, 2010 6:18 pm
Fuel pump plumbing? TrojanHorse Superbikes 1 Apr 11th, 2009 2:16 pm
Under seat oil breather plumbing twowheelcossack Superbikes 7 Apr 9th, 2007 1:55 pm
