fuel pump on the cheap 916/996/748 and other models edition - Ducati.ms - The Ultimate Ducati Forum
Old Mar 18th, 2010, 8:18 pm   #1 (permalink)
Das Borgen's Avatar
This is specific to my 748 but it applies equally to other bikes.
The fuel pump on my 748 had failed and I was browsing the classifieds for a used pump and I thought to myself:
"There is no reason Ducati made Bosch make an exclusive pump for them. They probably got an off the shelf part"
So I pulled my pump and took it out from the fuel pump assembly. I then looked at the Bosch Part Number 0 580 453 408.... Then I googled and found the essential specs:
pressure 3.0 bar (43.5psi)
Looking around and no local store had the Bosch part...... I had a sad on my face But google revealed that Airtex (E8229), Carter, AC Delco (EP389) all make emulations of the part with the SAME proportions, specs etc
So I went out and bought the Airtex part from Ebay (NAPA, Autozone Advance Auto had them too) for only 42 bucks (yes 42) Local stores had em for 130+
http://cgi.ebay.com/ebaymotors/NEW-E...Q5fAccessories
Only thing that is needed is to take the plastic pickup tube from the old pump by removing the metal circlip/snapring (this is a pain) and transferring the pickup tube to the new pump with a new circlip/snapring from Lowe's ($1)
total tab: 43 bucks
pics:
Bosch pump on right, Airtex on left (same connector layout)
plastic pickup tube transfered over and snapring installed. (the one pictured is the old one from the Bosch but I got a brand new one from Lowe's because the old one had lost its "snapiness" during the removal struggle. I recommend to NOT reuse)
my understanding is that Honda, Mazda at least have used this specific Bosch pump on the civic, miata, mx-6 and maybe even more makes and models but don t quote me on that
just thought I'd share
feel free to comment/ask question/google your heart out
edit:3/19/10
for reference go here
http://www.showmetheparts.com/airtex/#
click on "part search" and enter E8229 to find out what other vehicles apply this same pump
the list is GIANT
where to get fuel pump O-ring
Originally Posted by anotherfourm
Back in November, I recall that 1 OEM o-ring was $12, and you can buy 5 of them through McMaster-Carr for $10.30 plus shipping (about $15-$17). I installed one in my '98 ST2, and it is holding up very well (3000+ miles later).
www.mcmaster-carr.com
9464K548 Viton O-Ring, AS568A Dash Number 247
According to McMaster-Carr, they are 0.139" thick with dimensions of 4.609" ID x 4.887" OD (converted, I get 3.5mm thick and 117mm ID x 124mm OD).
or better yet $5.50 for the O0ring from desmotimes
http://www.desmotimes.com/product31.htm
http://www.DesmOhio.com - Ducati Owners Club of Ohio
-Rich-
Das Borgen is offline   Reply With Quote
Old Mar 18th, 2010, 8:23 pm   #2 (permalink)
94CobraR's Avatar
Images: 5
Good post...I think Walboro makes something very similar too!
Jimmy
Go Gators
www.g8rduc.com
94CobraR is offline   Reply With Quote
Old Mar 18th, 2010, 8:32 pm   #3 (permalink)
Old Cafe Racer
Images: 63
Toyota Corrolla 1998-2002 ( Toyota p/n 23211-46070 & 23221-21020)
Mazda 626 1992-1994
Aftermarket: IFP Indiana 912 or GE 043
I didn't want to post this before as it could affect some site sponsors who supply pumps, but now it's general knowlege here is some more info as this is what I fitted to the 748 over the wet season refit.
Also the filter I took out was a Mahle KL145 (BMW I think) they are cheaper than the Ducati part but identical)
I didn't replace it as I fitted the filter externaly, so now I don't have to worry about scratching the tank when replacing it,
davy
fuel pump on the cheap 916/996/748 and other models edition-p1000766.jpg   fuel pump on the cheap 916/996/748 and other models edition-p1000767.jpg   fuel pump on the cheap 916/996/748 and other models edition-p1000768.jpg   fuel pump on the cheap 916/996/748 and other models edition-p1000775.jpg
davy.j is offline   Reply With Quote
Old Mar 18th, 2010, 10:02 pm   #4 (permalink)
Das Borgen's Avatar
I find it absurd that used Bosch fuel pumps go for 150 bucks in the classifieds when even the Bosch original can be found in so many other vehicles
-Rich-
Old Mar 18th, 2010, 11:34 pm   #5 (permalink)
Old Cafe Racer
Images: 63
Knowledge is power.
More power to you.
Old Mar 19th, 2010, 7:57 am   #6 (permalink)
Evil moderator
amullo's Avatar
Images: 260
This thread coppied from Superbikes
See full discussion fuel pump on the cheap 916/996/748 and other models edition
//amullo
//Anders
-10 Multistrada 1200S Sport - Fast by Hypertrick
amullo is online now   Reply With Quote
