Replacing A Worn Clutch Step By Step (pdf). - Ducati.ms - The Ultimate Ducati Forum
Old Jan 28th, 2010, 3:08 pm   #1 (permalink)
james0133's Avatar
Images: 2
Smile Replacing A Worn Clutch Step By Step (pdf).
Here's an updated version of a step by step guide I put together for replacing your clutch.
Enjoy
2006 Ducati 999S (So Much Fun)
1994 Ducati 916 Strada (Regrettably Sold)
james0133 is offline   Reply With Quote
Old Jan 29th, 2010, 1:40 am   #2 (permalink)
Fasduc's Avatar
Nice write up and thanks for the pics. I wish more people would document their work with photos....they're worth a thousand words.
Fasduc is offline   Reply With Quote
Old Jan 29th, 2010, 7:25 am   #3 (permalink)
veteq's Avatar
Images: 9
thank you for documenting the process. I will give it a try when the time comes.
veteq is offline   Reply With Quote
Old Jan 29th, 2010, 8:48 am   #4 (permalink)
Evil moderator
amullo's Avatar
Images: 260
This thread is found WORTHY!
Moved to the Hall of Wisdom.
//amullo
//Anders
-10 Multistrada 1200S Sport - Fast by Hypertrick
amullo is online now   Reply With Quote
Old Jan 29th, 2010, 11:10 am   #5 (permalink)
Official Sponsor
JCPakBikes's Avatar
Well Done!!
jc@jcpakbikes.com
JCPAKBIKES
sportclassicspecialties.com
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Old Jan 29th, 2010, 1:12 pm   #6 (permalink)
snlsmith's Avatar
Images: 4
Handy Hint: Not sure if applies to the dry clutch also, but on my wet clutch: Don't pull the clutch lever while the plates are off!* Not a huge thing, but when I went to put the cover plate on, I could not get it to sit all the way on. Turns out the pin had pushed out a little when i pulled the lever, so I just had to push a little on the plate to seat it back down.
*After taking the clutch apart, I realized I had the wrong pack. I set the cover back on and went to change the front sprocket. It was in neutral, so I went to put it in gear ad pulled the lever. As soon as I did it, I remembered "Oh yeah, I've got no clutch".
snlsmith is offline   Reply With Quote
Old Jan 31st, 2010, 4:47 pm   #7 (permalink)
Stupid question, but should I drain the oil first? It says to use locktite on the basket bolts, to prevent oil from leaking in from the crankcase. I just don't want to make a bigger mess than I already have, if oil were to come through the bolt holes.
Great write-up by the way!
dutchthrone is offline   Reply With Quote
Old Feb 1st, 2010, 4:55 am   #8 (permalink)
james0133's Avatar
Images: 2
You do not need to drain the oil. It is only under engine running conditions, with high crank case pressure that oil can leak out.
Mind you I wouldn't go tipping the bike on its side with the basket off and it is better not to leave the basket bolts off for a long time as you could get condensation in your engine, especially in winter.
Old Dec 18th, 2010, 6:04 pm   #9 (permalink)
Corse1's Avatar
Images: 2
Oh yeah thanks. Pulled the seal without checking orientation. You instruction has saved me :-)
Corse1
03 ST4s ABS (2006 -)
07 Tuono 1000R (2011 -)
03 Aprilia Tuono RSV 1000 Racing (2011-2011 Crashed)
06 1050 Speed triple (2009-2011)
Corse1 is offline   Reply With Quote
Old Dec 18th, 2010, 10:26 pm   #10 (permalink)
Ducatierv's Avatar
Great write up!
1199 Panigale Tricolore
996RS Corse - Ben Bostrom's #155 Vance & Hines Racebike
05 1122R Ducshop stroked 999R "Big Meanie" Racebike
08 D16RR
03 999R #171
06 999R Motocorse Racebike
95 916 x 4 [Varese Bikes]
00 996SPS "Roxanne" #1418Racebike
00 996SPS Rebuild in progress
99 996SPS
98 916SPS #904
98 916SPS #640
98 748SPS RS spec NCR racebike
00 748RS
93 888SPO
99 748 with 853 kit 700miles from new
05 749S CCS Racebike
00 984R next project!
Bimota YB11 Attack Race Motor
MV Agusta F4 ORO #293
05 MV Agusta F4 1080 CCS Racebike
96 944SS extensive mods(nearly finished)
92 944 CCS Racebike rebuild in progress
88 Paso 750 Limited
90 851 SuperBike
99 996 Biposto FOR SALE
01 996 Biposto
06 749D
99 Laverda 750 Formula
Ducatierv is offline   Reply With Quote
Repairing/replacing a Desmoquattro sprag clutch Desmogod Hall of Wisdom 9 Feb 15th, 2011 5:34 am
HELP clutch plates order 999 Musa Superbikes 9 Jan 23rd, 2010 6:01 pm
rear sub frame removal step by step part two Karlr HyperMotard 4 Dec 23rd, 2009 6:11 pm
748 Clutch Upgrade - "How To" and pics HawkDucati Hall of Wisdom 23 Mar 31st, 2009 7:09 pm
STM slipper install guide for your HM. desmoworks HyperMotard 14 Oct 23rd, 2007 7:46 pm
