Testastretta Valve clearances - Ducati.ms - The Ultimate Ducati Forum
Old Jan 6th, 2010, 11:24 pm   #1 (permalink)
BrianG's Avatar
Be advised of new settings by Ducati made in 2007 retroactive to all testas:
.002” for closers and .005” for openers
2005 999S
I try to take one day at a time, but sometimes several days attack me at once.
BrianG is offline   Reply With Quote
Old Feb 19th, 2010, 8:49 pm   #2 (permalink)
that is incorrect there tare two seperate valve clearance specs. assembly and inspection and they are not set values they are min and max values.
mr-x is offline   Reply With Quote
Old Mar 3rd, 2010, 10:54 pm   #3 (permalink)
RatFink749's Avatar
Images: 5
Soo.. Maybe instead of saying "you're wrong!" you could help the rest of us out and post said values and the difference between the assembly and inspection readings? Just a thought...
RIP my Dark. Are you lookin at my "S"?? Many more track days to come!!!
RatFink749 is offline   Reply With Quote
Old Mar 4th, 2010, 9:48 pm   #4 (permalink)
kaos's Avatar
i think the .002-.005 are the numbers to strive for when doing your clearance's.ducatis origial specs had a pretty big range that was great for not needing adjustments ,but flawed for optimum performance
giallo 949- impractical,irrational,irresistible ,09 gasgas raga,11-12 gasgas cervantes 250- all in all ,my version of garage nirvana
kaos is offline   Reply With Quote
Old Apr 5th, 2010, 6:46 pm   #5 (permalink)
jsrussell's Avatar
Images: 3
sounds about right
Jon Russell
Commerce Twp, MI
Ducs Unlimited - Michigan's Ducati Club
'06 Yellow Sport Thou
'01 Grey Monster S4
Lots of Extra Bike Parts
jsrussell is offline   Reply With Quote
Old Apr 6th, 2010, 6:42 am   #6 (permalink)
MultiDoc's Avatar
Images: 49
Any chance someone posts the clearances in milimeters ? Both optimum and the whole range ?
N3R Team #166
DP: Full Termi 57mm+filter+ecu, belt rollers, racing seat, monoposto tail, rear hugger, rear sprocket, ram-air covers, keyguard, carbon fuel cap, titanium reservoir covers, billet clutch & sprocket covers, monoposto subframe, MBP collets,STM: 48T clutch basket & plates, clutch slave cylinder, Suter Racing slipper clutch, Öhlins: forks+shock+steering damper, BrakeTech iron rotors f/r, R&G sliders f/r, ValterMoto rear axle sliders, SpeedyMoto: under-body sliders & water pump cover, Samco hoses, AFAM X-ring chain, Fabbri screen, Evoluzione throttle, PT levers, Marchesini forged mag rims, Woodcraft clipons, ProGrip's, FrenTubo kevlar lines f/r, Rider's Racing rear caliper bracket
MultiDoc is offline   Reply With Quote
Old Apr 6th, 2010, 12:18 pm   #7 (permalink)
RatFink749's Avatar
Images: 5
Multiply (inches meausrement) X 25.4 = MM
Old Apr 7th, 2010, 12:53 am   #8 (permalink)
MultiDoc's Avatar
Images: 49
Thank you.
So optimal clearances are for openers: 0.05mm and for closers: 0.127mm
Right ?
N3R Team #166
Old Jul 4th, 2010, 8:05 am   #9 (permalink)
Images: 5
My factory service manual gives the following clearances for the standard Testastretta head:
Opening rocker arm
Intake Clearance:
Nominal 0.20 mm
Operation 0.18–0.23 mm
Check 0.10–0.25 mm
Exhaust Clearance:
Nominal 0.20 mm
Check 0.10–0.25 mm
Closing rocker arm
Intake Clearance:
Nominal 0.15 mm
Operation 0.13–0.18 mm
Check 0.10–0.25 mm
Exhaust Clearance:
Nominal 0.15 mm
Check 0.10–0.25 mm
The manual gives three values:
Operation - Installation Value
Check - Value when checking during normal services
Nominal - Mean clearance which would be the spot-on clearance
The Nominal for Openers is: 0.20mm (.008")
The Nominal for Closers is: 0.15mm (.006")
Both could be within a range of 0.10mm ~ 0.25mm (.004"~.010"). My understanding is this clearance assures extended periods between adjustments (not a bad thing for the street rider who racks up more than 6,000 mi. per year) and assures, as the valves get hot and change length (as they do on the street), they still have a bit of lash in the valvetrain.
'08 Monster S4Rs tricolore
12guage is offline   Reply With Quote
Old Jul 4th, 2010, 3:04 pm   #10 (permalink)
Ductor's Avatar
valve adjustment testa
Ok, now I am all f**d up.
the manual states something different. when did Ducati come out with the new numbers and where?
also, when you guys do your Testa valves, do you take measurments like the Ducati manual shows? I am doing one today and taking numbers from the opening and closing rockers and cam lobes like Ducati shows in the book..Am I wrong?
thanks,
Ductor is offline   Reply With Quote
Testastretta Opener Valve Adjustment BrianG Superbikes 7 Jan 7th, 2010 9:28 pm
Valve clearances and how they change jsheerin Superbikes 10 May 21st, 2009 2:06 pm
valve clearances testastretta kaos Superbikes 5 Oct 29th, 2007 9:33 pm
Testastretta valve clearances... galaxy Superbikes 15 May 5th, 2007 12:26 am
desmoquattro valve clearances 916Hoon Superbikes 4 Mar 25th, 2007 1:06 pm
