Hi Guys and Gals!
Warm weather is coming, and many of you will be rolling your bikes out of storage to discover a weak or dead battery in your motorcycle.
I did, so I decided to research the Ducati.ms archives for some candidates for a replacement.
The Odyssey PC680 looked good on paper, so I bought one from my local battery retailer and took it home to see if I could get it to work in my stock battery box.
With some subtle modifications, it will work.....here's what I did to make it fit:
My original battery box, with small (post 2001?) battery. You can see that the original battery is resting on a spacer block:
I removed the original battery, the spacer block, and relocated the relay cluster to the outside of the battery box:
Since the Odyssey battery is slightly wider than the OEM unit, I had to cut off the 'hook' at the bottom of the battery box to do a mockup. Here is the Odyssey battery test fit:
Since I removed the existing 'hook' at the bottom of the battery box, I had to fabricate a replacement. I used a scrap of 1/8" thick aluminum, and riveted it to the battery box:
The remainder of the 'extra' room in the battery box was filled in with a piece of 1" square foam gasket material:
The result is a snug fit in all directions:
The top hold-down bracket had to be flattened out to work with the new battery:
The result is a fairly clean installation:
The new battery just barely clears the inside of my fairing! However, my 2002 has the flat sided fairings, so your results may differ.
With the new battery the bike fires right up, coming to life almost instantly!
All in all, a very worthwhile upgrade!
Mike
