Crankcase Ventilation System - Ducati.ms - The Ultimate Ducati Forum
Old Jan 12th, 2008, 10:27 am   #1 (permalink)
Shazaam's Avatar
Blow-By
Piston rings act as a seal between the high pressure created in an engine’s combustion chamber and the lower pressure in the crankcase. Blow-by occurs as the rings become worn - or fail to seal properly when new - and they allow a small fraction of combustion gases to leak into the crankcase.
The consequences is accelerated contamination of the engine oil, as well as excessive release of hydrocarbons to the atmosphere - unless a crankcase ventilation system is used to route the gases back to the engine intake to be burned.
On Ducati engines, excessive blow-by can cause unusually-large amounts of entrained engine oil to be forced through the crankcase ventilation system and into the airbox. It’s not unusual however, to occasionally see a light deposit of oil in a Ducati airbox.
A small number of Ducati 998's, maybe one percent, have been reported to build up so much crankcase pressure at high revs that excessive entrained oil is forced/sucked into the airbox through the crankcase ventilation system, resulting in excessive oil consumption.
Blow-by occurs in all engines to varying degrees as they wear, but when it becomes excessive, an engine rebuild with new piston rings is in order.
Crankcase ventilation is used for three reasons:
It reduces crankcase pressures to nearly atmospheric pressure in order to avoid oil leaks from seals and gaskets.
It reduces crankcase pressures at the bottom of the pistons to provide an increase in the differential pressure across the piston compression rings, and consequently provide an increase of torque and horsepower. A larger differential pressure across the piston oil rings also aids in control of oil consumption.
It reduces pumping losses. In a running engine, the size and shape of the crankcase boundary changes with the movement of the pistons. Ventilating the crankcase reduces parasitic horsepower losses involved in compressing and moving this air volume about, so net power output is increased.
The larger the crankcase volume, the less-compressed the gases it contains become, so the lower the losses. If you vent directly to the atmosphere - through a sufficiently large vent hole - the crankcase can’t attain positive pressure, even at the highest engine rpm. Further, if you create a vacuum in a crankcase, the effect on pressures is the same as increasing the crankcase volume.
It’s interesting to note that in the automobile performance world that there have been performance gains using crankcase ventilation systems that create a vacuum in the crankcase using pumps and extractors.
Ventilation Systems
The simplest way to ventilate the crankcase is to create crankcase openings to the atmosphere large enough to permit any combustion gases that have made it past the piston rings (called blow-by) to rush out. In this case, a filter element is needed on the opening to prevent dirt from entering the engine. This system was used on engines for many years until environmental laws required a modification that prevented direct release of this effluent to the outside air.
Gary Milcheck Photo
The design result of such laws is a positive crankcase ventilation (PCV) that uses the lower-than-atmospheric pressure that normally exists in the engine intake tract to extract the crankcase gases. These are then are burned along with the normal mixture of air and fuel. This system has a one-way valve that allows outward flow only, and a oil separator that acts like a maze for any entrained oil droplets that try to leave the crankcase. This (normally) small amount of oil then drains back into the crankcase instead of entering the engine intake.
On Ducati street bikes the one-way reed valve is located at the engine case opening. During certain conditions of high engine rpm and light load, more oil is entrained so the reed valves’ small drain holes have difficulty returning the additional oil to the sump quick enough. The oil separator can fill with oil and get sucked into the intake tract. Higher compression engines or worn piston rings have more blow-by, so the likelihood of oil being puked into the airbox is greater.
Because of this, and to gain about a two horsepower increase, race bikes that live at high-rpm use a somewhat different arrangement than the street bikes. A much larger oil separator box is used to effectively increase crankcase volume that reduces pressures and pumping losses.
To allow the oil to drain back more quickly, the reed valve with its small drain holes is removed from the crankcase location.
Gary Milcheck Photo
The corsa box is connected to the crankcase with a large diameter hose and located a greater distance away from the crankcase opening, under the tail. The one-way reed valve is now located at the airbox connection of the 3/4-inch vacuum line running to the oil separator. This design reduces the chances of contaminating your intake charge with oil. It also provides a large enclosed system that safely contains the oil if an engine blows.
Photos courtesy of killer bee
Except for the larger oil separator volume, the advantages of the corsa system can be implemented in the stock system by hollowing-out the reed valve to remove the constriction on drainage. Alternatively, STM valveless breather connector can be used. Then use a one-way reed valve at the airbox connection. A 748RS remote breather valve works well here.
(Ducati part # 59310192A.)
Photo by DukeDesmo
More conversion photo can be found here:
http://public.fotki.com/garymilcheck...se_cb_install/
K&N Breather Conversions
The K&N breather is sold on the premise that venting to the infinite volume of the atmosphere - instead of the vacuum in the airbox - increases horsepower. It eliminates the one-way valve so it needs an air filter to prevent dirt from entering the crankcase under a negative crankcase pressure differential (pulse) when a piston is on an upstroke. Under positive crankcase pressures, the K&N device simply vents oil droplets direct to the filter medium - and beyond when it becomes saturated.
People usually buy them because they look trick mounted on the engine case. Therein lies its main disadvantage. Its location on the engine case is directly upstream of the rear tire. Since its installation also eliminates the oil separator, the increased chance of an oil mist being released onto the rear tire makes this location an unwise choice. Avoid overfilling the oil sump and wheelies with this arrangement.
Consequently, some owners have plumbed to the K&N element located in the tail where, at least, any effluent is away from the rear tire.
Here’s what the experts say ...
The following is a earlier post by BCM Ducati:
What is different about Ducati streetbike breathers in general is that the reed valve is mounted directly in the case. The breather box location and volume are good.
The reed valve location is good for emissions but not for engine power and crankcase breathing. What happens is that under certain conditions, under high rpm and light load, the oil doesn't run back because of the reed valve and it builds up in the tube above the reed.
The simplest solution is to hollow out the reed assembly and leave it internally open but still hitched to the volume bottle. This allows the volume of the breather bottle to perform its function and usually gives a slight horsepower increase also.
Then, use either a 748RS reed valve in the airbox at the end of the breather hose, OR, use a Ford diverter valve (in-line one way) just before the airbox.
The following is a earlier post by Jon Nichols:
We firmly believe the best system is the stock system. Let me expand on this. The only part worth replacing is the breather itself, and only if it is leaking or if you want to dress-up your bike. We see many Ducati's with the K&N filter attached to the breather hose. This is simply not a satisfactory replacement or alteration to replace the stock system. The stock system is less restrictive because there is more volume making it less restrictive.
Part of the problem with this modification is that the only efficient replacement systems made were made for race circumstances. This was accomplished by increasing the tank volume into which the engine pumps. On the early bikes, 851, 888, 955 in the 851/888 chassis Ducati had a very large carbon fiber tank which was connected to the engine crankcase without any breather. The tank was mounted in the tail section of the bike. This effectively doubled the crankcase volume and was responsible for an additional 3 to 5 HP at high RPMs.
This type of system is also available for the 748/916/996 chassis. This type of system is not available for Monsters or SS models, unfortunately. Therefore, the system that allows you the largest volume to pump into is the stock system. This system pumps into the airbox and has the added benefit of a collection/separation tank between the crankcase and the airbox.
Old Jan 10th, 2012, 11:29 am   #2 (permalink)
outstanding info. Thanks, Shazaam!
tsal998 is offline   Reply With Quote
Old Feb 24th, 2012, 10:29 am   #3 (permalink)
Humble
Chuckracer's Avatar
Images: 2
Photo's replaced - Shazamm, please let me know if I've screwed this up somehow!
Ducati Cooling System Shazaam Hall of Wisdom 3 Nov 20th, 2010 10:26 am
oil vapor recovery system Flip998FE Superbikes 5 Jan 13th, 2008 11:32 pm
F L E D A Dual Row System: PAKBIKES JC/PAK Bikes 2 Apr 27th, 2007 3:22 pm
999 cooling system TORC Superbikes 11 Jan 6th, 2007 10:18 am
Cooling System Overheating rob Hall of Wisdom 1 Jul 18th, 2006 2:42 pm
