Better Headlights - Ducati.ms - The Ultimate Ducati Forum
Old Oct 31st, 2007, 8:33 am   #1 (permalink)
Shazaam's Avatar
Better Headlights
The headlights on your Ducati are the result of a number of design compromises and legal restrictions. So, before you go changing them let me list a few points to consider first.
The light patterns of high and low beams are legally restricted, because otherwise the light from oncoming vehicles can blind you and you can blind them. So reflectors and bulbs are designed in combination such that there is a sharp cut-off to the light pattern to prevent this glare.
The color of the our headlight beam affects our ability to see. The more yellow and less blue the beam, the better we can SEE WITH IT at night. The more blue and less yellow the beam, the better it can be SEEN during the day. This is a function of the way our eyes work. (See comments below)
The brightness of the headlight increases as the electrical current through the bulb is increased. Bulbs with a higher wattage rating are brighter. But, given that the heat and electrical demands on the charging system and wiring increase with higher wattage bulbs, 55 watt bulbs have become standard on most vehicles. High wattage bulbs will melt adjacent plastic parts.
You can't get something for nothing. Some headlight bulb manufacturers advertise getting the equivalent of 85 watts of light while consuming only the standard 55 watts of electrical power. They do this trick by concentrating the light beam more at the center and less at the edges so you can't see objects to the side as well.
True high intensity discharge (HID) lighting systems are more efficient than halogen gas-filled bulbs so for the same wattage used they produce a brighter light. But, they're also bluer in color. These expensive systems first appeared on high-end luxury cars that use a government-mandated self-leveling system to avoid blinding oncoming traffic. It's illegal to fit these lights to your car without the leveling devices for a good reason.
The blue-colored light from true HID's has created some confusion in the marketplace that is being exploited by headlight bulb manufacturers. True HID's use an entirely different arc-discharge (like a movie projector) technology to produce their brighter light, but because the resultant light is bluer (higher degrees Kelvin) buyers naturally think that blue light is brighter so they switch to blue bulbs in an attempt to get brighter lights.
To add to the confusion, the term HID is often seen on packaging of standard halogen bulbs that have simply been given a blue dye coating. The coating absorbs light so they may be bluer but they're NOT AS BRIGHT as the same bulb without the coating.
Short of a true HID system there IS a better bulb available that increases the usable light output by pressurizing the bulb with a higher percentage of the gas Xenon. The BimmerXenon 30% Xenon bulbs for example, use this technology.
http://www.bimmerxenon.com/
Old Oct 31st, 2007, 10:57 am   #2 (permalink)
Chest2Tank's Avatar
How much extra wattage can one add to the system before it fries? I will most definitely replace my bulbs with Xenon ones, but I also want to add fog lamps.
Chest2Tank is offline   Reply With Quote
Old Oct 31st, 2007, 11:27 am   #3 (permalink)
Shazaam's Avatar
Additional Wattage
http://www.ducati.ms/forums/showthre...372#post304372
Old Oct 31st, 2007, 3:18 pm   #4 (permalink)
Chest2Tank's Avatar
awesome Shazaam. I've been researching this, and I have a question that maybe others around here wonder:
Do I need a different balast for every bulb or can one balast run, let's say, high beam, low beam, and a pair of fog lamps?
Old Nov 1st, 2007, 7:30 am   #5 (permalink)
mals900ss's Avatar
Images: 20
Shazaam,
Do you know what system is on the SSie?
If the std bulb is 55w/60w, do I risk a lot by using 80/100? Using the on /off calculations above I think I save almost enough because I use 5w indicators and 1w led number plate and park light.
Because I'm not great at maths, IF you have your brake and tail light on, isn't that 26 watts and indicators plashing would be 22 wats because there are two plus the warning bulb? I could well be missing something.
Thanks
Mal
insert witty comments here...
mals900ss is offline   Reply With Quote
Old Nov 1st, 2007, 8:23 am   #6 (permalink)
Shazaam's Avatar
There have been several reports of 100W bulbs melting adjacent plastic parts and the high current causing heat-damage to the wiring insulation and damage to the light switch. This would be my main concern.
Old Nov 1st, 2007, 2:20 pm   #7 (permalink)
DukeDesmo's Avatar
Images: 144
I use a 100w bulb in the high beam of my 916 but have fitted a relay (previously went through the switch) and heavy duty wiring.
916 & M944 'project'.
DukeDesmo is offline   Reply With Quote
Old Nov 1st, 2007, 3:43 pm   #8 (permalink)
Dark_Daddy's Avatar
Images: 10
Hid
I belive HID lights were originally designed to be used with projector type headlights such as the xx9 bikes, as well as Audi's and BMW's, etc. etc. I have a 5-6K bulb in my lowbeam but I bought mine here for 65.00 shipped from a guy that decided not to convert both bulbs. If I was going to buy one new I would not go any thing more than 4K a bulb. Is it legal to use HID on an xx9, I really don't know but with projectors the cut off is perfect for HID and does not seem to affect oncoming traffic. The plus to this is that I have been told that I am more visible with my HID low beam by several cagers that stopped to look at my bike when I stop.
Chris
2006 749 Tricolore FOR SALE
Dark_Daddy is offline   Reply With Quote
Old Apr 23rd, 2008, 1:33 pm   #9 (permalink)
clenart50's Avatar
Before buying these bulbs, please read my review of them and save yourself some money.
clenart50 is offline   Reply With Quote
Old Jul 14th, 2008, 11:44 pm   #10 (permalink)
Cal
Or you can pick up an H3 and an H1 Xenon bulb (for a 996) for about $20-50 for both high/low at 8000K light temp./
Cal is offline   Reply With Quote
xenon headlights 749. manso72 Superbikes 8 Aug 13th, 2008 2:33 pm
Had some downtime, cleaned my headlights! sethmo Superbikes 2 Jul 29th, 2007 5:15 am
running and headlights lemurfart Superbikes 20 Sep 24th, 2006 2:38 pm
Tape on the headlights ademo749 Superbikes 10 Jul 8th, 2006 9:23 am
