Spark Plug Gaps - Ducati.ms - The Ultimate Ducati Forum
Old Oct 1st, 2007, 11:09 am   #1 (permalink)
Shazaam's Avatar
Spark Plug Gaps
Manufacturer Spark Plug Gap
A spark plug part number might fit hundreds of engines, and although the factory will typically set a gap to a pre-selected setting, this gap may not be optimum for your particular engine, and may not take into account modifications that you may have made to the engine.
Spark Plug Gap – Bigger is Better
The larger the spark kernel that is generated by a spark jumping the electrode gap, the more likely and complete the fuel burn will be, and the smoother the engine will run. That is, the larger the spark gap that’s exposed to the air/fuel mixture, the easier it is to initiate combustion. This translates directly into improved throttle response.
So, the larger the plug gap you can run (without misfires) the better.
Unfortunately, the greater the plug gap, the higher the voltage requirement to jump the gap. The difficulty lies in that, any added gap creates more strain on the other ignition parts. Coils, for example, may not have enough stored energy to cross the gap, creating a misfire. Old plug wire insulation can break down at the higher voltages required to fire a larger gap.
The stock Ducati coils are good enough to fire a 0.044-inch plug gap. Any gap larger than this will likely result in more misfires (there’s always a few) and subsequent power loss. The correct new plug gap is specified at about 0.024-inch (0.6mm). But, remember, as a plug wears, the gap opens up further.
If you use conventional sparkplugs, start with the recommended gap and try opening the gap up in 0.002-inch increments. You should note a progressively smoother throttle response if not more power. When the bike begins to lose power, go back 0.001 - 0.002 inch and this will be your optimum gap.
I don't know offhand what the DCPR8E plug comes pre-gapped at but as a good rule-of-thumb, if you go more than 0.008 inch over the out-of-the-box gap you won’t maintain parallel surfaces between ground and the center electrodes. So if you reach that point, change to a plug that starts at a larger gap. The NGK dash 9 series starts at a 0.9mm (0.035-inch) gap, and is used for that reason.
If you run iridium or platinum electrode plugs, start with the 0.035-inch gap that they are shipped with. Don't run them at smaller gaps or you'll loose throttle response.
If you have a older bike, you may arc over the plug wires before you can reach the optimum plug gap. If the spark plug wires have inadequate insulation, the wire cannot maintain a high enough voltage across the insulation and will arc to ground before firing the plug gap. The factory spark plug leads are stranded wire covered with an EPDM jacket and although the wire itself will last a long time, the jacket will start to break down after a couple of years which is why most good aftermarket wire is insulated with silicone rubber.
If this is the case, replace the stock spark plug wires with a set of Magnecor or similar quality wires. This will allow running a larger plug gap without a concern for insulating the higher voltage needed to jump the gap. Ducati 916 Magnecor #2549 wires, for example, run $67.
Ignition Amplifiers
Running a larger gap is the main benefit of installing an ignition amplifier, such as the one sold by Evoluzione for Ducati's.
The Evoluzione ignition amplifier increases the primary voltage to the stock Ducati coil from the existing battery voltage to either 16 volt or 18 volt (user selectable). A higher primary voltage means you get a higher secondary voltage applied to the wires and plugs. The higher the secondary voltage - the larger gap it will jump across. Evoluzione recommends that for best throttle response, you run a 0.060 inch plug gap.
One reservation that I have about ignition amplifiers as a group is that they could possibly cause overheating and eventual failure of the stock coils or wires. This reliability consideration has to be balanced against improved performance. An independent test by Road Racing World magazine on a GSXR 1000 saw only about a 0.2 HP improvement, but throttle response is the major benefit.
Old Oct 1st, 2007, 1:54 pm   #2 (permalink)
2fasst's Avatar
Awesome write-up, as always! Do you have any comments on the $50 Surface Discharge plugs? Thank you...
2fasst is offline   Reply With Quote
Old Oct 1st, 2007, 3:20 pm   #3 (permalink)
Bobaganoosh
Synergy's Avatar
Good info. I have been running the Denso Iridiums in a few Ducs. For the 748-996 The cross-ref calls for a IXU24. I run a IXU27 its a little hotter electrode and I have no complaints.
For shits and giggles the IXU27 is the same plug for Ferrari 456's and 550 Maranellos
In a Michigan State University study that ranked 34 major countries by their citizens' acceptance of the theory of evolution, the United States ranked second to last (thank you, Turkey). 39% of our adult population rejects the concept.
Synergy is offline   Reply With Quote
Old Oct 1st, 2007, 4:42 pm   #4 (permalink)
Shazaam's Avatar
Surface Gap Plugs
http://speedzilla.com/forums/ducati-...-benefits.html
998 Spark Plug Removal Problems 998Pilot Superbikes 8 Jul 3rd, 2007 6:57 pm
Spark Plug Socket ducsbill Sport Touring 9 Feb 1st, 2007 10:22 am
fuel quick connects and spark plug questions! =) dragknt Superbikes 4 Oct 31st, 2006 9:20 pm
Spark Plug Socket size/brand for 996? Desmo Soundtrack Superbikes 4 Oct 5th, 2006 3:08 pm
Uh Oh I goofed...socket in horizontal spark plug hole.... grendels_arm Superbikes 6 Aug 18th, 2006 11:30 am
