Lightweight Flywheel - Pros and Cons - Ducati.ms - The Ultimate Ducati Forum
Old Sep 13th, 2007, 8:44 am   #1 (permalink)
Shazaam's Avatar
Why You Have a Flywheel
A lightened flywheel is one modification to a STREET bike that will have more negative than positive effects. I left mine stock. Here’s why.
An engine makes the least torque at idle and low rpm, especially when cold (when there are more misfires.) So when you release your clutch a little too fast, the engine torque is too small to overcome the bike's inertia, and it stalls. If you have a flywheel, the stored momentum augments the engine's torque allowing you to use a lower rpm starting-off. Without a flywheel you'd need a higher idle speed, or constantly need to start-off at a higher rpm in order to raise the engine torque output enough to avoid stalling the engine.
As you ride at lower rpm in traffic, you are constantly changing between acceleration and deceleration. Engine torque levels are still fairly low at these speeds, so slack in the drive train needs to be smoothed-out with a flywheel. Otherwise, on-off throttle transitions have a jerky effect, giving a less comfortable ride and causing you to use smaller throttle inputs (which is not always easy to do.)
At higher speeds a flywheel slows the rate at which an engine rpm changes, so cracking the throttle open or closed results in a smoother transition in torque being applied to the drive train and tires. Again, without a flywheel more careful throttle transitions are needed. The key to faster track times is reduced wheel spin so a light flywheel works against you by making it more difficult to modulate wheel spin, even though it helps lap times by producing more acceleration in the straights.
So in effect, a flywheel slows an engine's ability to change rpm producing drive train smoothness and drivability. It also reduces the engine's ability to match it's rpm with the drive train's rpm making it more difficult to downshift without producing wheel-hop.
And, when you miss a shift you’ll be glad you have one ...
The weight of the stock flywheel is derived by Ducati test riders to provide an overall balance between performance and smooth drive train behavior. That's why Ducati selected the flywheel weight that they did. Did you think that they meant to purposely cripple the bike's performance by using a too-heavy flywheel?
When you remove weight from the flywheel (and to a lesser degree, from the clutch) the effect on the engine’s ability to more quickly spin-up is indistinguishable from increasing your engine’s torque (and consequently horsepower) output.
But only in neutral. In any other gear, there’s little benefit at all.
Obviously, your bike’s ability to accelerate faster through the gears is enhanced by reducing the overall weight of the bike as well as the inertia of rotating components. The crankshaft, pistons and connecting rods, transmission gears, drive chain and sprockets, wheels and tires, clutch and flywheel are all candidates.
However, the overall weight of the bike and rider completely overwhelms any reduction of rotational inertia produced by a lighter flywheel. A two pound lighter flywheel on a 600 pound bike-plus-rider will accelerate only 0.3% faster. F=ma.
Of course every 0.3% helps a racebike. When you reduce weight you’ll get faster acceleration, and faster lap times - IF - you can modulate your wheel spin driving out of corners. Factory racebikes make so much power, for example, that transmitting the power to the road effectively becomes the limiting factor - so heavier flywheels actually become a benefit. Fear the high-side.
The ability of an engine with a lightened flywheel to SPIN-UP more quickly is often pointed-to as a benefit when you bang a downshift and wheel hop is reduced. In this situation, it can be said you have LESS ENGINE BRAKING. However, if your riding “style” makes this an issue, a slipper clutch may be a better alternative than a lightened flywheel; at least that’s what the factory racers think. A lightened flywheel is like a poor man’s slipper clutch in this situation.
Conversely, a heavier flywheel will provide more protection for the engine being over-revved in a ham-fisted downshift.
The ability of an engine with a lightened flywheel to SPIN-DOWN more quickly is often pointed-to as a benefit if you want the revs to die as fast as possible when you lift the throttle for a corner. In this situation, it can be said you have MORE ENGINE BRAKING. Under normal street riding conditions we tend to prefer less engine braking so we tolerate a less efficient situation where the motor then has to work harder to put more momentum into the flywheel. When racing, you don’t care about storing momentum, you just want to get around the track as fast as possible.
This enhanced ability of the engine to spin-up and spin-down also makes it less critical to match engine and drive train rpm for smoother shifts. That is, the heavier the flywheel the longer the engine rpm will hang between shifts requiring a need to release the clutch more slowly to avoid lurching forward when quickly engaging the next higher gear.
So, the purpose of the flywheel is to store momentum, reduce vibration and smooth out the loads transmitted to the drive train. It takes energy to first store this momentum, so if the flywheel is lighter it takes less energy and it accelerates up to speed faster. There is an opposite effect when you lift off the throttle and momentum is given up, so the revs drop slower for a heavier flywheel.
Because the engine will spin-up more quickly with a lighter flywheel, when you loose traction, modulating the throttle (especially in the rain) will be more difficult. Especially if your throttle position sensor, idle and CO are not adjusted properly. A light flywheel seem to exacerbate a poorly tuned fuel injection system. If you make 100 horsepower it’s less of a issue. Make 130 hp and it will matter a whole lot more.
The amount of weight removed from the flywheel and inner hub is proportional to this effect, although if you remove most of the weight from the outer rim area, the effect is stronger. Different after-market manufacturers of flywheels offer different weights and geometry. If lightweight is good, ultra-lightweight is better - just doesn’t apply here. Too light a flywheel can make the bike a handful to ride so a two pound flywheel for the street seems to be a good compromise to preserve some ride-ability.
A cold engine runs rough until there’s enough heat to vaporize the fuel, so until then, a lighter flywheel will be less effective in preventing stalls, especially pulling away from a uphill stop. You’ll need to rev the engine a little higher to compensate and you may find it’s a little ornery when running at light loads (3,500 rpm) in the lower gears around town. Often, your idle speed will need to be raised to around 1,300 rpm to help minimize stalling.
Often they seems to let the engine kick-back much harder, which I expect will do starter clutch damage.
With all that said, you’ll find plenty of owners that will praise the effects of a lighter flywheel on their bike - but perhaps one that’s different than yours. Not every bike will respond well to a light flywheel, mainly because the flywheel is just part of the overall rotational inertia of the crankshaft, connecting rods and alternator.
So, if you have an old alternator SP/SPS with the lighter crankshaft and titanium connecting rods, the effect of removing 1kg from the end of the crank will be very noticeable, because the total mass is much lower to begin with. A non-SP or 2-valve bike has more crank/rod weight, so the effect is less pronounced.
For example, on a 916, or any model with a single pick-up and older version alternator, you can just remove the flywheel weight and run the starter clutch hub. Inexpensive, and makes them quite responsive.
However, a late-alternator bike with the heavier full-counterweight crankshaft and standard rods has significantly more weight in the alternator assembly and machining the same 1kg from the flywheel will have less of a negative effect, again - due to the higher initial combined mass of the set up.
Lightweight Wheels Instead
Lightweight wheels don't have the stalling and drivability drawbacks of a lighter flywheel. Also, since the wheels have a much greater rotational inertia than a flywheel, weight reduction here results in a much greater improvement in acceleration (and braking) with an added benefit of reduced gyroscopic forces for improved handling. Lighter front rotors have a similar benefit. There’s even a significant difference in tire weights between brands to consider.
Old Feb 8th, 2008, 4:04 pm   #2 (permalink)
goyaohboyajr's Avatar
what?
goyaohboyajr is offline   Reply With Quote
Old Feb 13th, 2008, 12:06 pm   #3 (permalink)
Life is too short to worry !
Gearbox's Avatar
So the explanation needed from someone is why do all the Aftermarket makers of clutches go for/push the lighter weight of their products ?
Should we not at least be offered the option of better quality without the loss of weight and its beneficial effect on the engine ?
(This is a subject am taking an interest in as I will probably need a new clutch Hub/Basket in the next 12 months and want to establish the best route to go)
Ref the tyres , there is a significant difference between Michelins and some other makes and they give this as one of the benfits of their tyre construction.
Gearbox is online now   Reply With Quote
Old Feb 13th, 2008, 1:03 pm   #4 (permalink)
DukeDesmo's Avatar
Images: 144
I had toyed with the idea of fitting a lightweight flywheel to my 916, mainly out of curiosity and have read & heard both good and bad reports but decided to try it out for myself.
So I recently bought an MPL flywheel, which is identical in appearance etc to the stock flywheel but made of Aluminium not Steel and weighs 575g compared to 2010g of the Ducati flywheel so a not insignificant 1435g (3lb 2 oz) saving.
I went with the MPL flywheel as it retains the TDC timing marks as per stock and because most bad reports I had heard about light flywheels were about really light or no flywheel, so I figured that keeping some weight might be a good thing and I can always machine it down for less weight or just remove it completely for minimum weight if required, plus I have some other MPL parts and the quality of their work is outstanding.
Anyway I fitted it last week and tried it out for the first time on Sunday, I have found the following;
Idle is unaffected it feels like before with no stalling @ 1000rpm idle speed, (my bike has never stalled) and I didn't have to noticeably rev harder than before to start off so none of the possible expected downsides on that front.
It revs up a little quicker but not as much as I was perhaps expecting and after 10 minutes or so it just seemed 'normal' again except, occasionally on gear shifts where I had the revs slightly mis-matched due to it picking up/slowing down quicker but after an hour or so with my brain/wrist recalibrated that is not an issue anymore.
There does seem to be a slightly greater tendency to hook up the front on exiting a bend but as the roads here are still wearing winter grime/salt I didn't try that one too hard, maybe it would be a little less tractable in the wet but, at my age, I wouldn't be pushing so hard on a wet road anymore so I'm not worried about that and perhaps, as Shazaam suggests on a 130hp bike it may be an issue but not on a 916.
In summary; a little more 'zest' than before but not as much as I expected, maybe a little more ride time will show me otherwise but I can say that I have not noticed any downside.
Was it worth the expense and time to fit? well for the changes I've noticed I'd say yes, probably and I do enjoy doing this kind of work on my bike but if I had to pay someone to do it then maybe I'd think twice.
Although the weight lost from the bike, combined with a lighter rear brake disc I fitted at the same time giving a total of 1.8kg is always a good thing - (me eating less would be a bigger benefit though )
916 & M944 'project'.
DukeDesmo is offline   Reply With Quote
Old Feb 13th, 2008, 3:08 pm   #5 (permalink)
Lifetime Premium
John's Avatar
Images: 15
Good report Duke. I heard another rider describe a bike with and a bike without as "different".
No advantage either way and much of that could be based on different mods eventhough both bikes were 916s.
I think the possibility of stalling when trying to negotiate a tight parking lot turn keeps me from getting an ultra light flywheel. I hate it when you or your bike stalls at 2mph when your in a full wheel lock turn. All of a sudden the bike becomes 450 lbs.
03 FLHRI Road King
03 999R #189
09 1125CR Buell (sold)
07 1100S MTS (sold)
04 999S (sold)
95 916 (sold)
01 900SS (sold)
05 Honda 600RR (sold before I crashed it)
05 Honda 600RR (full Yosh, PC, totalled it)
Ducati-Owners-Group of Sacramento region.
John is offline   Reply With Quote
Old Feb 13th, 2008, 6:12 pm   #6 (permalink)
I just installed one in my HM and will dyno it in the next few days to compare it to the last dyno run to see if it shows any diffrence and will post a copy. For now the throttle response is much quicker, raining hard so can't ride it right now.
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline   Reply With Quote
Old Feb 25th, 2008, 12:47 pm   #7 (permalink)
Flavor of the Month
Bravo51's Avatar
Images: 3
I just got a lighter flywheel in the mail and will be installing mine soon too. I'm also changing the spockets to 14/41 on my 748, so I'm thinking it's going to be a totaly new animal.
Sam 'MF' Brandt
2000 Ducati 748
2006 Yamaha YZ450F (SCARY!)
2008 Suzuki DRZ-70 pit bike
2008 Ducati HyperMotard S
Bravo51 is offline   Reply With Quote
Old Mar 7th, 2008, 12:07 pm   #8 (permalink)
Gearbox's Avatar
Question
What about noise ?
Old Mar 10th, 2008, 11:56 am   #9 (permalink)
DukeDesmo's Avatar
Images: 144
Originally Posted by Gearbox View Post
What about noise ?
Noise is unchanged.
Old Mar 12th, 2008, 7:23 am   #10 (permalink)
Darkside's Avatar
Nice to read actual first hand experience as opposed to a theoretical analysis. Am thinking I will proceed with lightening mine.
Darkside is offline   Reply With Quote
Exhaust Wrap / Coating - Pros & Cons Doody Superbikes 10 Jul 2nd, 2007 6:12 pm
Exhaust options: Alu, Ti, CF: pros and cons waterwindsail Sport Touring 9 Mar 3rd, 2007 8:01 pm
Pros and Cons of Dry Cluth? Yodi Superbikes 23 Aug 28th, 2006 8:08 pm
Slipper clutch/ pros and cons thisnjducquacks Ducati Motorcycle Chat 8 Jul 11th, 2006 11:53 am
Pro's & Con's of the ST4s TZ250 Sport Touring 10 May 15th, 2006 7:33 am
