New Clutch, Decisions, Decisions ... - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > Mechanical Tech Discussion > Hall of Wisdom
Old Aug 31st, 2007, 10:36 am   #1 (permalink)
Shazaam's Avatar
It’s a common scenario. You’ve worn out your clutch pack and your clutch basket fingers have been deeply notched by the plates. So, do you replace them with stock parts, or do you take this as an opportunity to install an aftermarket clutch? For significantly more money, you can install a slipper clutch, but is it worth it - and are there disadvantages?
Let’s assume that you ride your bike on the street mostly, but you’ve signed-up for a riding school and some club track days. You’ve also heard that a slipper clutch will help you to go faster on the track and ride safer on the street.
So, what should you know before you decide?
Ducati Clutches
The Ducati dry clutch on most models use steel plates, hub and basket. It’s noisy and it’s heavy, compared to aftermarket units, but it’s pretty durable and the friction material lasts at least as long as aftermarket plates. The reason that they’re noisy is that each time you shift, the edges of the plates hammer the fingers of the basket, causing each to deform, causing the gap between them to get larger, causing higher impact forces, and causing more rattling noise when the clutch is disengaged. So they get louder and louder until the plates and basket are replaced.
You’ll need to replace the plates when the thickness of the friction material gets too thin to prevent slipping. You’ll notice a little slippage first when starting-off in first gear, but when it starts to slip in top gear it’s time for a new clutch pack. Depending on the mileage and the depth of notching, you will probably will want to replace the basket at the same time. A notched basket will be louder, but I’m not convinced that it makes it any more difficult to for the plates to separate when disengaging the clutch. But replacing just the plate stack, which then has to engage the basket notch pattern worn-in by the previous plates, will possibly affect your ability to shift smoothly.
If you shop eBay, you’ll want to see a close-up picture of the wear in this area.
The price of the Ducati original equipment manufacturer (OEM) parts varies from dealer to dealer, so shop around. In the US the cost of a clutch pack is around $180, a basket is about $140.
The 999 comes with an aluminum basket that works on the older bikes. It retails for $324, about $25 more than an alloy aftermarket part.
Aftermarket Clutches
Aftermarket clutch components are marketed as performance items with unique features that are intended to address design deficiencies in the OEM clutches. Foremost is lighter weight.
Aluminum drive and friction plates, basket, hub and pressure plates combine to reduce rotating mass as well as overall bike weight. Less rotating mass in the engine allows it to change rpm more quickly and less overall bike weight improves acceleration, braking and handling.
However, the reduced mass offered by an aftermarket clutch alone is not very significant because the clutch turns about once for every two revolutions of the flywheel. Consequently, it is accelerated half as quickly as the flywheel, so rotational weight reduction at the flywheel, gram-for-gram, will give you a greater effect than weight reduction at the clutch. Reducing the flywheel and clutch weight often will adversely affect drivetrain smoothness (so unlike lighter wheels, for example) this is not necessarily an overall improvement for the street.
The weight savings from an aluminum clutch basket and plates is about 3.5 pounds, less than 1% of the overall bike-plus-rider, so any improvement in performance is not really of major importance in deciding to change to an aftermarket unit.
Clutch durability is another area where aftermarket clutches are marketed as an improvement over stock clutches. Clutch life varies widely from rider to rider but all direct comparisons suggest that the Ducati OEM clutch plate friction material has outlasted the clutch plates from aftermarket manufacturers. In one case 25K vs. 16K miles. So, at roughly the same price, the OEM plates seem to be the better deal.
There has been some innovation to try to address the durability issue associated with the plates impacting and notching the basket.
For example, STM and Sigma (UK) has tried to overcome this problem by increasing the number of tabs on each plate (and the number of basket fingers) from the stock 12 to 48 tabs. The intended result is to distribute the impact loads over a larger tab-basket contact area (lower psi) to reduce notching to the clutch basket fingers and mushrooming of the plate tabs. Only STM and Sigma offer a 48-tab clutch pack, however.
Nichols Manufacturing designed their CNC-machined aluminum basket with wider basket fingers that results in larger finger contact area and consequently lower impact stresses, particularly when combined with their Barnett aluminum clutch pack where extra care has been taken to initially minimize gaps. Basket: $299, clutch plates: $139.
Another option is a Barnett aluminum basket with stainless steel inserts to protect the basket fingers. About $225.
Keep in mind that when you mix steel and aluminum, the softer metal deforms preferentially and clearance gaps suffer, more than for steel-to-steel. So if you have a steel basket, stick with steel plates.
Slipper Clutches
Slipper clutches are an innovation that allow your rear wheel to move freely whenever it tries to turn faster than the drivetrain. When engine braking reaches a certain reverse torque level, the clutch disengages and allows the rear wheel to move freely, much like on a bicycle when you pedal in reverse.
Under normal circumstances, the clutch remains engaged and the engine provides a reverse torque to slow the bike when the throttle is cut. But if you downshift to a lower gear before you have reduced your speed sufficiently, the clutch disengages. Consequently, a slipper clutch will allow only a limited amount of engine braking. This is seen as a safety benefit if you accidentally downshift to too low a gear, especially while cornering on a V-twin. Not just at the track, but on the road as well. We’ve all done it.
Setting up a slipper to release properly and launch smoothly is sometimes time-consuming, and naturally the friction material will wear out more quickly depending upon the amount of times it releases. Also, unlike a standard design, the slipper release mechanism need to be cleaned and lubricated periodically to prevent wear and to provide a smooth release.
Slipper clutches are being offered by more manufacturers (including Ducati on some new bikes) as original equipment these days.
Shazaam is offline   Reply With Quote
Old Dec 1st, 2007, 1:22 am   #2 (permalink)
1098 clutch questions
Thank you for the detailed discussion . i'm new to dry clutches, and bought a 2008 1098 in august. i had 2000 miles on the bike by mid sept. and had fried the clutch. this was a surprise to me since on my '98 cbr900rr i had 80k miles on the bike and never had to replace the clutch. the mechanic showed the worn clutch to me; the basket had warped preventing the plates from moving freely. the 1098 clutch basket looked to be aluminum; do you know if a steel basket from an older model ducati would fit the 1098? i only did a couple of canyon runs and one track (took it easy since i didn't want to risk pitching my new 1098 down the track), most of the miles are from commuting to work. i think what toasted the clutch is the low speed (less than 12 mph) traffic situations where i'm not able to speed ahead or split lanes. in these situations i would use the clutch lever to "roll" along, since the bike stalls at any speed less than 12 mph and it's not practical to keep shifting into neutral.
mgoff is offline   Reply With Quote
Old Dec 2nd, 2007, 2:51 am   #3 (permalink)
redzedx7r's Avatar
Hi newbie to Ducati and dry clutchs, your post was very informative.
Which relates to my problem I thibnk that in the course of last friday's track day in Dubai UAE I burnt out my clutch plates on my 2001 996s.
The bike doesn't accelerate as it should and at 7000rpm I am getting no drive.
The bike has 10,000kms (5000mls) and is fitted with a OEM clutch with a closed cf cover.
What I want to know is
a) given that I am in a warm dry climate area (the middle east/ persian gulf region) should I get a vented or open clutch cover?
b)should I spend the dough on a slipper clutch? $1500+ or just buy a new set of plates and maybe a new basket? $500+
c) i was looking at the motowheels slipper for $1100 with 4 springs is that a good slipper clutch?
I do mostly 'canyon' riding with the odd track day (maybe 4 or 5 this season)
thanks & cheers
2001 996S
2001 ZX9R
redzedx7r is offline   Reply With Quote
Old Dec 2nd, 2007, 3:56 am   #4 (permalink)
safetyfish's Avatar
Some people reckon it is a good thing having a vented clutch out here - the heat we see is a lot more than what other people are used to or have experience with. I would recommend a vented cover to help get rid of the heat buildup inside of the clutch.
The reverse argument is that you may get dirt in there which can wreck your clutch - not really an issue in my opinion only but you will have to decide.
thanks & cheers
I dont think that Jebel Hafeet counts as canyon riding. This coming from a guy who gets to ride in a country where the highest point is a sand dune measuring a staggering 80 meters above sea level....
Sorry, the rest of the questions I am not able to answer
SF
999R
998 Bayliss
safetyfish is offline   Reply With Quote
Old Dec 2nd, 2007, 6:00 am   #5 (permalink)
redzedx7r's Avatar
SF
that's why I used the inverted commas, I was using the US vernacular
2001 996S
2001 ZX9R
Old Feb 9th, 2011, 11:25 am   #6 (permalink)
ZDM
Super Senior Poster
Remember that the clutch is a "wear" item, there's no magic package that last's forever. On a Ducati even more so as it is a dry clutch. No matter what basket you buy or what plates you use it will wear out. If it's a slipper this will happen, as stated, more quickly....I decided to go from standard to a DP slipper clutch....my standard clutch was a Paulimoto basket, Barnett clutch pack, TPO springs w/ titanium screws.....always worked perfectly!
It took alot of fiddling w/ my DP slipper to get it to launch properly and not slip or jerk...considering my 999 is street only (although I'm thinking of a day or two at NJMP this year).... if I had to do it all over again I should have definitely stayed w/ a standard clutch....
ZDM is offline   Reply With Quote
Old May 19th, 2011, 9:00 am   #7 (permalink)
I went with the EVR and while it's still new, I'm not impressed .....yet. I guess they have to wear in before working properly. I asked here, but nobody seems to have much experience setting them up for track use. I don't ride on the street that much so for it to have to "wear" in for a few hundred miles before tracking is a bitch. It is doing a little better after 50 miles but still no where near the release I want. So we'll see how it works out.
like2lean is offline   Reply With Quote
Ducati and After-market Clutch Master and Slave Cylinders Shazaam Hall of Wisdom 24 Sep 6th, 2012 10:06 pm
Installed Pazzo Clutch Lever...now the clutch doesn't disengage 100% koolio Superbikes 11 Aug 18th, 2007 4:31 pm
2004 999 Clutch slipping (Pictures Inside) UltimateMoto Superbikes 26 Jul 13th, 2007 6:12 am
Another clutch question---long vmuth Superbikes 19 Dec 18th, 2006 3:57 pm
Pressure Plate, Springs and clutch cover kit moto Motowheels 4 May 27th, 2006 1:56 am
