Oil Change Interval - Ducati.ms - The Ultimate Ducati Forum
Old Aug 18th, 2007, 12:41 pm   #1 (permalink)
Shazaam's Avatar
Oil Change Interval
Oil Change Interval
The oil drain interval that is specified in the owner's manual is for what is called normal service. Normal service is defined as the engine being at normal operating temperature, at highway speeds, and in a dust-free environment. Stop and go, city riding, trips of less than 10 miles, or extreme heat or cold puts the oil change interval into the severe service category, which has a shorter recommended change interval.
When the manufacturer gives a mileage/time criteria for oil changes they're telling you that if you drive every day, but (say) for only short trips to work, your driving habits put you into the severe service category and you should use time, not mileage, as a guide. So you may go 100 miles a week but do it in ten trips.
Motorcycle riding is often different. You usually ride for pleasure, but maybe only once a week outing for 100 miles, one trip (normal service.) So you should use mileage, not time as your change criteria.
Further, manufacturers are saying to change your oil even more often than the mileage interval stated in the manual because your motorcycle rarely experiences only normal service conditions.
The central dogma of motorcycle oil manufacturers and distributors has always been that motorcycles put different demands on their lubricants than do automobiles. In particular, they point to the facts that motorcycles run at higher temperatures and use the same oil in their transmissions as in their engines. The transmission gears supposedly put extreme pressures on the oil molecules, thus causing the long oil polymers to break down. High temperatures can have the same basic effect, as well as additional effects such as the increase in oxidation products.
When the size of the oil polymers decreases ("cut up by the transmission gears," as at least one manufacturer claims), the oil thins. In other words, its viscosity decreases, as well as its ability to lubricate properly. For example, what started out as a 40-weight oil could effectively become a 30-weight oil, or even a 20-weight, after prolonged use.
The viscosity of synthetic-based oils generally drops more slowly than that of petroleum-based oils in the same engine.
Here's the result of one test.
Castrol GTX, a non-synthetic car oil at 800 miles showed a relative viscosity of 0.722, meaning it had retained 72% of its original viscosity. Or, if you want to look at it the other way, the Castrol had lost 28% of its viscosity after 800 miles of use in the motorcycle.
Just for comparison sake, they also tested the viscosity drop of the same Castrol GTX oil after use in a 1987 Honda Accord automobile. At 3,600 miles of use, the Castrol GTX showed a relative viscosity of 92%.
So a motorcycle is definitely a more severe operating environment than a car so the oil change mileage interval should be shorter than for a car.
In the same test, since Mobil 1 car synthetic oil had retained so much of its viscosity after the 1,500 mile test, it was the only oil allowed to run longer in the motorcycle. After 2,500 miles, the Mobil 1 recorded a relative viscosity of 79%.
One more point. If you buy a motorcycle-specific synthetic oil it's no guarantee that you can extend your change interval. There were two motorcycle oils tested, Spectro 4 (petroleum based) and Honda HP4 (petroleum/synthetic blend). Both the Honda HP4 and Spectro 4 had lost over 30% of their viscosity at 800 miles, and over 35% at 1,500 miles.
So, because I ride infrequently for 200 mile jaunts - my choice - is to change my Mobil 1 15W-50 automobile-specific synthetic oil at 3,000 mile intervals.
Your mileage may vary, as they say.
Old Aug 26th, 2007, 4:51 am   #2 (permalink)
safetyfish's Avatar
I may be less informed than the average rider, but when you say oil change, do you mean drain the oil and throw a new batch in to the engine every so often?
Or do you mean drain the oil and change the filter?
Wessel
999R
998 Bayliss
safetyfish is offline   Reply With Quote
Old Aug 28th, 2007, 5:13 am   #3 (permalink)
mals900ss's Avatar
Images: 20
Hey Shazzam..
Can you tell us if the motorcycle used in testing was wet or dry clutched?? I'd be very interested to see if there was much difference between wet and dry becuase there are so many threads where people believe wets degrade to oil much faster.
You have some great posts here.. I have to wonder if I 'know' you... hmmmm
Safetyfish.. Most of the owner manuals say the filter every second change.
In accordance with the prophecy...
Mal
insert witty comments here...
mals900ss is offline   Reply With Quote
Old Aug 28th, 2007, 10:07 am   #4 (permalink)
Shazaam's Avatar
In terms of viscosity retention, the important issue is that motorcycles usually lubricate their engine and transmission with the same oil supply. The cutting of the long-chain oil molecules into shorter pieces by the transmission gears is the reason that the viscosity drops faster than when the same oil is used in an automobile engine.
The contamination from abrasive clutch material particles was not addressed in these tests, but you can be sure that wet clutches send some nasty stuff through your engine, so frequent oil changes are prudent for these bikes no matter what.
For the record, each of the oils tested was run in the same motorcycles: (1984 Honda V65 Sabre) under as near to identical conditions as possible.
See:
http://www.xs11.com/stories/mcnoil94.htm
Old Sep 12th, 2007, 3:54 pm   #5 (permalink)
$20/quart Motul competition oil better be way damned better than $7/quart mobil 1 car oil.
bbagdan is offline   Reply With Quote
6,000 vs 10,000 Mile Valve Maint. Interval Sanfu! Duc-OT Sport Touring 8 Mar 26th, 2007 9:57 am
quick change or not to quick change? jamesmorgan Superbikes 5 Mar 5th, 2007 10:32 am
Advice on rear sprocket change for a 998 matchman Superbikes 5 Sep 22nd, 2006 3:01 pm
New Oil Change Record Darkness Superbikes 2 Jun 10th, 2006 9:46 am
Oil change interval oldguy Sport Touring 15 Mar 23rd, 2006 10:51 pm
