749/999 EOBD light error codes - Ducati.ms - The Ultimate Ducati Forum
Old Aug 2nd, 2007, 7:51 pm   #1 (permalink)
Images: 3
The 749/999 EOBD dash light illuminates when there are certain electrical errors, errors in the injection system and errors in the ignition system. It will also light up if engine temp is greater than 124 degrees Celsius (255.2 degrees Fahrenheit). Additionally, if the EOBD light lights up together with the 'CODE' symbol on the LCD, the ECU is in the 'block engine' state.
If the EOBD light has illuminated because of an error, to troubleshoot the problem, you can retrieve the error code/s generated as follows...
While holding down the left hand dash button, turn the ignition on. Keep the button held down throughout the 'start up' dash sequence, then any stored error code/s will be displayed on the LCD. The error codes will be displayed as "EFl Error". At the same time, the error code number will be displayed in the bottom right hand corner of the screen. If there is more than one stored error code, the display will scroll through them automatically.
See below for error code numbers:
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Lo
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to powersupply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Can Line error
'05 999s
TORC is offline   Reply With Quote
Old Aug 5th, 2008, 11:01 pm   #2 (permalink)
HELP!!! I am getting 37.3 serial disconnected. I don't even know where to start to look for the problem.
jcctx is offline   Reply With Quote
Old Sep 24th, 2008, 5:25 pm   #3 (permalink)
theWanderer's Avatar
hmm have you checked out the factory service manual?
theWanderer is offline   Reply With Quote
Old Jan 2nd, 2009, 12:48 am   #4 (permalink)
Vanduc749
Vanscott's Avatar
Thanks 4 the error codes ! Will save ALOT of time.
749s bi to monoposta, Termi half system, PC111 USB (Mapped), Braking Wave Disks, Paulimoto Clutch Pressure Plate & Basket ,TPO springs & Surflex Plates, Lotz C/F Bitz: (Keeper !)
900 ss. High Comp. Pistons .Sold
Pantar 600 SL Mint !, Race Glass , K&N Pods, Marzocchi Shocks , Tri colour (Keeper !)
Pantar 500 K&N Pods Sold
500 Parallel Desmo ss . Custom 750SS Fairing,(First bike, New! 30yrs ago) Sold
Vanscott is offline   Reply With Quote
Old Jan 3rd, 2009, 9:18 am   #5 (permalink)
This is great information hopefully I 'll never need it but, I'll sure know where to go.
renodezrat is offline   Reply With Quote
Old Jan 18th, 2009, 12:48 pm   #6 (permalink)
So... anyone ever had the light come on, but the left-dash-panel-button trick doesn't bring up any error codes? The battery was really low, and the light only comes on when I stop and let it idle for a second... the charger is on it now, so, that is probably the problem... still, I'd love to know what I am doing wrong as this is a great diagnostic tool.
Matt
valheru21 is offline   Reply With Quote
Old Jan 18th, 2009, 2:02 pm   #7 (permalink)
Vanduc749
Vanscott's Avatar
Matt
I discovered that if my bike was in neutral at stop, no light, in gear (after a few moments) light on. Realised it was the fact that the micro-switch on the Clutch leaver was not being activated due to the fact it required the leaver to be pulled all the way to the grip which i wasn't doing. Maybe this could be the issue.
Old Jan 18th, 2009, 4:30 pm   #8 (permalink)
I've already shimmed the brake lever for a similar problem - I'll examine this when I get back from church. Thanks again.
Matt
Old Oct 23rd, 2010, 8:57 am   #9 (permalink)
actionong's Avatar
I got the yellow light on for the entire duration of a 5 mile ride. Light was off on the 2nd start up. Bike runs fine.
go figure.
actionong is offline   Reply With Quote
Old May 25th, 2011, 11:20 am   #10 (permalink)
Reset code?
I got the speed sensor fault code while loading my bike onto the trailer. Any idea of how to reset this code to see if it was just a fault? The ducati dealer can't even get me in to read the code and clear it for 3 weeks. Any help would be great!! Thanks!!
triple 9 is offline   Reply With Quote
eobd light??? 2fasst Ducati Motorcycle Chat 1 Jan 31st, 2007 2:20 am
EOBD light on 03 999 jmurph648 Superbikes 4 Sep 23rd, 2006 12:01 am
light reflecting back in 749/999 is this right? rustysrustyduc Superbikes 9 Aug 28th, 2006 8:13 pm
EOBD light ? bjclay Sport Touring 4 Aug 14th, 2006 7:44 pm
'05 ST3 EOBD light stays on whatsit1 Sport Touring 15 May 6th, 2006 11:59 am
