Questions come up regularly about recommended sprocket changes and the required chain lengths for superbikes. Here's my recommendations for general street and track use.
http://home.san.rr.com/shazaam1/Recommended.jpg
Some of you are missing an important point about gearing. Different Ducati models have different different red-lines, primary drive ratios and different transmissions. So they require different sprockets.
For example, 916’s and 996’s both have the same standard-ratio transmission, but the 916 has a 2:1 primary drive ratio where the 996 has a 1.84:1 ratio. So the answer to the initial question about the best gearing will be different for the 916 and the 996.
So a positive result with a particular sprocket combination on (say) a 998 doesn’t often translate to a model other than a 998.
There's a "sweet spot" - around 4,600 RPM @120Km/hr in 6th gear for liter displacement superbikes, a little higher for 74X's. Obviously, faster tracks will require rear sprockets with fewer teeth, slower tracks more teeth (and possibly longer chains.)
I strongly recommended NOT changing the stock front sprocket or chain size for safety reasons. Just my opinion.
