Brilliant Various Ducati Tech Articles - Ducati.ms - The Ultimate Ducati Forum
Patriot Powersports
Old Mar 9th, 2007, 3:42 pm   #1 (permalink)
JEC
JEC's Avatar
Here:
http://ducati-upnorth.com/tech/techlib.php
Articles by Larry Kelley and other Duc gurus on everything from crankcase ventilation to rectifier failure. Invaluable stuff for the mechanically inclined.
'97 916
MBP collets, Surflex clutch, 996 rotors, FBF slip ons, Senna EPROM, SPS mono tail, SPS carbon-fibre undertray, Corbin seat, black powder coated frames-wheels-swingarm, Ohlins shock
'84 Honda VF750F Interceptor (gone)
'04 Suzuki SV650 (gone)
'87 Honda VFR400R NC24 (gone)
'85 BMW K100RS (gone)
JEC is offline   Reply With Quote
Old Mar 11th, 2007, 1:53 pm   #2 (permalink)
teriffic link, I joined that one, also!
2004 ST3
1964 Peugeot 404 berline
1985 Peugeot 505s
Life Coach
http://coachingtoconquest.com
ducaati is offline   Reply With Quote
Old Mar 15th, 2007, 2:46 am   #3 (permalink)
JEC
JEC's Avatar
I'm going to post some of the more pertinent ones up as separate threads.
'97 916
Old Jan 17th, 2009, 1:48 pm   #4 (permalink)
Humble
Chuckracer's Avatar
Images: 2
bump
Old Jan 17th, 2009, 8:13 pm   #5 (permalink)
I was pretty stunned! I was hoping for something insightful and informative, but I'm pretty seriously disappointed.
I only picked two articles, I'm not currently servicing my own bike as its still in warranty but I've been looking at upgrades, so I picked lightened flywheels and carbon fibre wheels.
Lightened flywheels; This article seems to be scaremongering about wheelspin and glosses over or ignores the major benefits in removing drivetrain inertia.
First off, I'm skeptical about the risks outlined within the article, while a lightened flywheel does allow revs to flare more quickly it also means that the engine is more responsive to throttle input, allowing the rider to deal with the problem more rapidly and accurately as well.
Additional to this the author makes a false statement about removing a kilo from the rotating mass of the engine being equivalent to removing a kilo from anywhere else on the bike, this is false. The engine (depending on gear) rotates between 4 and 10 times faster than the rear wheel, the engine inertia is also multiplied by this factor, so in first gear, for instance, removing a kilo from the flywheel would have a significantly greater effect than fitting lighter rims.
Stalling issues were also highlighted as a major drawback... if the engine starts without throttle then stalling by definition can't be an issue at higher RPM. The bike would be markedly more susceptible to rough operation of the throttle but would not spontaneously stall.
Driveline shudder would be reduced as a problem, not increased. Driveline shudder at traffic speed (in my experience) is simply related to slack in the driveline being taken up, then effectively causing a springing effect between the road and the engine, reducing engine inertia would reduce this effect.
Bike turning/Stability would be positively effected by reducing the rotating mass of the engine in exactly the same way as lightened wheels.
Yet another issue poorly misrepresented was the impact of a lightened flywheel on shifting. Lowering the engine inertia means two things; first, it is easier to match revs due to a more responsive engine and second that if you do stuff up it is easier for the rear tyre to accelerate or decelerate the engine, reducing wheel hop.
Another nice benefit of reduced rotational inertia within the engine is less likelihood of compression lockup and reduced effect when it does happen. This is because the compression of the engine can momentarily cause traction loss at the rear wheel, having lower inertia gives the back tyre more hope of getting it back. Its not exactly a slipper clutch, but it helps.
Carbon fibre wheels; This one isn't so much of an essay as being stunned by the fact that this guy seems to be basically exercising xenophobia against a construction material. It stuns me that this guy is crapping on about the fatigue properties of carbon fibre when he's using aluminium or magnesium as the baseline, especially when referring to shock loading or fatigue issues.
Drew79 is offline   Reply With Quote
Old Mar 22nd, 2010, 8:58 pm   #6 (permalink)
Thanks for the link!
fairplayinc is offline   Reply With Quote
Old Jul 7th, 2010, 10:13 pm   #7 (permalink)
ltsnipe's Avatar
thanks for the link, lots of great info
ltsnipe is offline   Reply With Quote
Old May 1st, 2012, 1:03 pm   #8 (permalink)
very awesome info, will enjoy reading these. thank you
99duc996s is offline   Reply With Quote
Old May 24th, 2012, 3:56 pm   #9 (permalink)
a lot of useful information, though--sadly--some of the links no longer work.
Ferrolanoman is online now   Reply With Quote
I've Lost All Faith In Ducati LC996 Ducati Motorcycle Chat 35 Mar 30th, 2007 10:37 pm
NEW!!! 1098 Specs Info and New Pics!!!!!!! Harry Superbikes 54 Nov 10th, 2006 11:15 am
Ducati VS MV Agusta: The Real Story badass916sp Ducati Motorcycle Chat 102 Apr 26th, 2006 10:30 am
