Gas tank fuel line quick disconnect replacements / upgrade - Page 2 - Ducati.ms - The Ultimate Ducati Forum
Old Jun 22nd, 2011, 7:33 pm   #11 (permalink)
FFWD's Avatar
Originally Posted by surfguygrif View Post
WHAT YOU NEED TO ORDER.
2 x LCD10004 - 1/4 NPT Valved CPC Coupling Body (LCD10004) = $21.10
2 x LCD23006 - 3/8 Hose Barb Valved Elbow CPC Coupling Insert (LCD23006) = $21.78
Be sure the get the valved models so no gas leaks out during your servicing and the barbed hose couplings.
Great info! I've been scratching my head on the CPC site trying to figure out which part numbers to order.
The valved elbows (LCD23006) currently show as "temporarily unavailable", but the non-valved ones (LC23006) are in stock. Does having the valves on both ends completely eliminate fuel leakage during disconnection, or does some still squirt out?
2002 998 w/Termi slip-ons
FFWD is offline   Reply With Quote
Old Nov 2nd, 2011, 12:02 pm   #12 (permalink)
rule62's Avatar
quickcouplings.net = excellent customer service
I had a plastic coupling on my 1998 748 fail last Saturday night. The previous owner had already replaced one of them with a non-valved metal one.
<Incidentally, when the valve on the failed plastic one closed, it caused the in-tank fuel line to pop off of the top of the pump, but that's a different thread. The lines in there were a mess.>
I just ordered a set of valved LCD23006 couplings from, quickcouplings.net, the link in the first post. (I guess they're available now.) When I placed the order, I hadn't read enough about the importance of viton o-rings. I went back to the site. My order had already shipped. I sent a message via the "contact us" link on the website to ask if the viton rings were available. John from quickcouplings emailed me back to let me know he placed two of them in an envelope for me and sent them on their way.
A+ for quickcouplings.net
I can't wait for the parts to arrive so that I can get the 748 back in working order.
rule62 is offline   Reply With Quote
Old Nov 9th, 2011, 12:20 am   #13 (permalink)
rule62's Avatar
748 lives again
The couplings arrived today. Fitted them with the viton o-rings. In the meanwhile, I replaced the fuel filter with one from NAPA, replaced the in-tank fuel hose from the pump to the filter and the filter to the base with some Gates 30R10 line (at $25 per foot), and the in-tank vent hoses with some 30R7 (at $1.50 per foot).
I turned the key on a few times to let the fuel pump send gas through the lines, pushed the starter button and the old 748 fired right up.
I hope the 30R7 line holds up okay for the in-tank vent lines.
Old Jan 10th, 2012, 3:39 pm   #14 (permalink)
great post. this is an upgrade i'll be taking care of this winter since i almost snapped off one of the cheap plastic qd's since i didnt realize they were plastic the first time i took the tank off!
tsal998 is offline   Reply With Quote
Old Jan 20th, 2012, 10:43 am   #15 (permalink)
r71
r71's Avatar
Images: 9
Thanks for the tip. I just pulled out my 998 out of the storage and fuel started to spray out the side of the tank. I knew right away what it was. I just ordered the last 3 male fittings so if anyone is looking, they are all out.
04 998S FE
96 ZX-7RR(Track-Life long project-Still in restoration)
06 ZX636(Track)
06 KTM 200 XC-W(Dirt)
r71 is offline   Reply With Quote
Old Feb 25th, 2012, 3:54 pm   #16 (permalink)
questions
does anyone know if this is a straight up swap (metal qd's for the plastic qd's) on the 998? my dealer was just telling me that the 998 is the only model that you CAN'T swap out the plastic male qd's - he stated they are molded directly into the fuel line and told me NOT to cut the fuel line. doesn't make much sense to me, but i haven't taken the tank off yet to look.
also, can anyone tell me which NAPA fuel filter to use? is it the NAPA Gold 3032?
Tony
Old Mar 7th, 2012, 6:39 pm   #17 (permalink)
Super Duper Member
CptFunnypants's Avatar
Is there some sort of sealing washer or thread sealant I'm supposed to use when I put these on the fuel pump base plate? I have the couplings already but just want to make sure before I put them on.
Thanks!
Kansas City, KS
1998 Ducati 748 Mono
CptFunnypants is offline   Reply With Quote
Old Mar 7th, 2012, 9:49 pm   #18 (permalink)
Super Duper Member
I figured it out. This stuff....
It's resistant to fuel, oil, water, etc. Just put a little bit on the threads and screw it in. Pretty sure after using this it won't come out again, but don't see a reason for it to need to come out again, and it'll be totally sealed.
Kansas City, KS
Old Mar 8th, 2012, 12:43 am   #19 (permalink)
Super Duper Member
Okay, so I've cleaned the threaded holes as best I can. They look fairly clean, but I can't screw these all the way in. Are they supposed to go all the way in? I'm seeing about 3 threads still showing. This can't be right. Thoughts?
Kansas City, KS
Old Mar 8th, 2012, 2:44 pm   #20 (permalink)
Stick's Avatar
If these things really are 0.25" NPT, they should be a bit of a tapered thread--narrower at the tip (of the male thread), and a bit wider as you go up on the thread count. That said, as you thread a NPT male into a NPT female, thing should get progressively tighter. The NPT female should be wider at the opening, and tapered down deeper in the thread bore.
If you go "too tight", you run the risk of cracking the female hole, especially since this (female) one is made of aluminum.
So if you're threading these things in, and all of a sudden the bottom out (before becoming snug), then there's something wrong.
It should be a progressive feeling of "tighter and tighter", as you thread them in.
There's NOTHING WRONG with a few threads showing. Take a look at any black-iron piping in a house (usually found on natural gas installations). Always see some threads showing.
You should be using a fuel-proof thread sealant, made for "pipe threads". Or you can use teflon tape, but the former would be the wisest choice.
I'm finding it a bit difficult to believe that Ducati would use a plastic fitting that was 1/4" NPT. It should be a metric fitting, I would think.
I've never had the pleasure of dealing with the QD's, since the ST2 and ST4s have none of these on the pump/fuel flange.
Stick
Other brands (past):
Gas tank fuel line quick disconnect upgrade. surfguygrif Ducati Motorcycle Chat 5 Aug 16th, 2011 3:16 am
Clutch - Brake line replacements - Upgrade mry999eryk Superbikes 3 Apr 20th, 2010 8:23 pm
Fuel tank quick disconnect - thread sealant? loren.betts@gmail.com Superbikes 3 Jul 9th, 2009 2:22 pm
Fuel Line Disconnect Help migg750 Superbikes 9 Sep 15th, 2006 4:50 pm
Quick Disconnect Broken - Fuel Tank R1blade75 Superbikes 5 Aug 31st, 2006 10:03 pm
