In this tutorial I'm going to cover the entire process of upgrading any Ducati with a dry clutch to Barnett components.
Here is everything we are going to be installing. A whole new clutch pack, basket, springs/spring retainers, and pressure plate. They also offer a clutch cover, but I'm not going to be running any cover.
Here is the pressure plate. I got it in red but it is also available in black or gold. The design is a stronger reinforced design, which also helps protect the clutch in the event of a crash. Note the bearing and pin are also included.
Here is a close up of the basket. You can see it has a stainless steel insert that helps to stop grooving from the tabs on the clutch plates. It is also available in the same colors as the pressure plates.
Another picture of the basket.
The springs are black powercoated gloss black for a great, durable look. The bolts are stainless so they wont rust, and the caps are also available in an assortment of colors.
The clutch includes everything you need.
Now to begin the install. Here is the tired old looking setup that was on the bike.
First, remove the clutch cover from the bike.
