EVerything you need to know about heated gear - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Apparel and Accessory Chat
Old Dec 10th, 2010, 10:43 am   #1 (permalink)
A while back I asked a fellow biker and copywriter I know to help me write an article about heated gear to help educate people. I think it's a great read and answers most of the questions people have. Feel free to ask any questions you feel are unanswered.
FYI - I removed links to our product pages so this isn't viewed as a "sales pitch" of some sort. Hope that's okay.
Taken from our Street Wise Blog
Heated Motorcycle Clothing – The Best Way to Extend Your Riding into the Winter Months
The battle against Mother Nature has long been a struggle for those who ride motorcycles. For most, the extreme temperatures of summer and winter have been where they call it quits. For the summer extremes, it is often short lived and once the noon day sun has gone away, the riding can resume. However, when it gets cold, it stays cold in many areas and will stay cold for months at a time. For riders in these climates, they can hope for a warmer day to take a quick ride or simply winterize their motorcycle and give up riding. However, this is changing with the introduction of heated clothing from a couple great manufacturers. The times of wearing multiple bulky layers to stay warm on a cold day are over by using the bike’s electrical system to keep the occupant warm with active heating, rather than through the use of layers of insulation.
How Heated Clothing Works
Heated Motorcycle Clothing actually works in a very similar manner to the heated motorcycle grips and seats that many motorcyclists have become accustomed to; it is just scaled down and built into the clothing itself instead of the motorcycle. The difference primarily is in the material used to create heat. In all of the heated clothing, carbon fibers are used. They are durable and flexible, both required for any garment used for motorcycling. Heat is produced when electricity passes through the heating elements on these garments and the resistance of the carbon wires creates heat. The typical garment draws from 15 watts for a pair of gloves to 65 or 90 watts for a jacket or vest. All manufacturers have provisions to wire together the individual pieces so integrating an entire body solution is easy.
Concerns About Heated Clothing
One of the most commonly cited concerns about heated clothing is the electrical draw necessary to power all the clothing. In most cases, the rheostat, or temperature controller module, is attached directly to the motorcycle’s battery. During normal operation, even a sport bike’s small generator or alternator should be able to keep up with the draw of a typical heated clothing setup. However, to be safe, using a 65-watt, versus 90-watt version of the jacket liner is recommended for those who worry about the current draw. However, with a little math, it is easy to estimate any motorcycle’s maximum wattage output. All modern motorcycles operate at or right around 12 volts, with charging systems that vary in their amps of output. A typical cruiser will put out about 48 amps. By multiplying the amps by the volts, the wattage output for the bike can be had, in this case, 576 watts. Even with the draw from the bike, there is still plenty of output for an entire system. Sport bikes have smaller charging systems, but with modern bikes needing a strong spark to start up, even some sport bikes have bigger alternators or generators than their counterparts from a couple years ago. One of the newest liter class bikes has a 34amp setup, good for 408 watts. If there are concerns, checking with a motorcycle service department to get the charging specs for a specific bike, as well as the typical load, is only a phone call away.
Controlling the Temperature
All companies that make heated clothing have done so with comfort in mind. For the liner pieces (in other words those that go under other layers like the feet, chest and legs), they are all designed to be, as they say, “heat neutral” when the system is off. This means that while another layer, they aren’t going to have an insulative effect if left on all day. A rider can unplug and wear the liner all day underneath their other clothing if they choose.
While on the bike though, plugged in and riding, both companies put the control of temperatures in the user’s hands, just in different ways. Both systems offer adjustment; it is the level of adjustment that riders need to consider. In some cases, the rheostat is built into each piece and has three separate heat settings available. The upside to this is that each piece heats more independently. The downside is that it is very possible to need a little more or a little less heat that will not be available. The controllers available for the other brands are completely variable. They are available as single or dual controllers and if need be, more than one could be used. By being completely variable, the exact right amount of heat can be had on any piece. These parts are available as portable units or as permanent or even semi-permanent mounted pieces that can be easily integrated into any motorcycle. The use of a rheostat is absolutely vital to being comfortable and safe with the use of heated clothing.
The Benefits of Heated Clothing
While it may be possible to be warm on a motorcycle at freezing temperatures without heated clothing, heated clothing offers a couple huge benefits. For anyone who has ridden with a heavy coat or even a number of layers of clothing on, they know that those layers impede the movements of the rider. Taking a heavy leather jacket that is oversized and stuffing it with poly-fill, wool or other layers will keep the rider warm but at the cost of being able to maneuver their motorcycle in the manner they are used to. These layers can affect head movement as well, compromising the ability to check blind spots or even watch for cars that should be stopping at an intersection. On top of making the rider more comfortable and potentially safer, the addition of heated clothing can extend the temperature in which a motorcycle can be ridden. A cold day can become a colder night and turning up the heat setting is the perfect solution for getting home comfortably.
For commuters who may have to work extra hours to touring riders who are unabated by cold weather, heated clothing is the best choice for staying warm.
BikerHiway is offline   Reply With Quote
Old Dec 11th, 2010, 3:34 pm   #2 (permalink)
Great stuff. Let me relay my 1st hand experience.
I bought heated gloves & jacket liner last year. They don't just work, you have to be really judicious about "full hot". A bunch of times I was riding in the mid thirties on up and would end up sweating. I was a little concerned the Duc would have some electrical difficulties but not a blip. I'm in northern Virginia and aside from Snowmageddon I was able to ride to / from work & recreationally until other issues stopped me - too much road debris from Snowmageddon on the pavement, so cold my faceshield was set to "perma-fog", etc.
You'll want something for your neck like a scarf or the like.
Smurfslayer is offline   Reply With Quote
Heated Gear john sbraga Multistrada 36 Nov 29th, 2010 6:06 am
Heated gear while Touring DuckMan Sport Touring 32 Sep 3rd, 2010 12:07 pm
Heated gear DrD Sport Classic 14 Sep 1st, 2009 8:11 pm
Heated gear question jquattro Sport Classic 4 Aug 10th, 2009 7:54 pm
Heated Riding Gear breakdown HyperMotard 5 Mar 11th, 2009 7:11 am
