GT Fuel Tank Capacity - Ducati.ms - The Ultimate Ducati Forum
Old Jul 28th, 2006, 6:43 pm   #1 (permalink)
Jeff_Quan's Avatar
Well, I pulled a brainiac today and ran out of gas. By my estimates, I should have gotten quite a bit further, but when I pushed the bike to a gas station and filled it up to the brim, it measured 12.75 L (3.4 US Gal.). The spec'd capacity is 3.9 US Gal. I don't know about you guys, but to me that seems like quite a discrepancy (over 10%). I've never run bone dry before. Anyone have any ideas aside from me being a looser?
Jeff
Red GT1000: - Termis (sans baffles), DP chrome bar-end mirrors, Clay Carrier fork protectors, Motovation frame & fork sliders, Dietrich's gauge brackets (these rock), Front turn indicator spacers removed, 1.0 kg/mm fork springs, Fork Oil: 7 wt.comp, 5 wt.reb, DP grab rail / luggage rack & bag, 15/44 F/R Sprockets, Gold DID Chain, Chain guard removed (to show off the chain)...
Jeff_Quan is offline   Reply With Quote
Old Jul 28th, 2006, 7:45 pm   #2 (permalink)
dietrichpfeifer's Avatar
Did you try flipping the petcock over to reserve? Should find your other half gallon.....
Metric gallon discrepancy?
dietrichpfeifer is offline   Reply With Quote
Old Jul 29th, 2006, 1:27 am   #3 (permalink)
Jeff_Quan's Avatar
Umm, at the risk of sounding stupid (yet again), I don't think the GT has a petcock - at least not one that I could find either on the bike or in the manual. I thought that it only has the low fuel light as an indicator. Please correct me if I'm wrong - which I hope I am.
An Imperial gallon (no such thing as a Metric gallon) is ~4.54 L whereas a US gallon is ~3.78 L. Not that it matters 'cuz the spec. for the fuel capacity is given in L and in US gallons explicitly and the conversion is pretty close to correct - at least close enough that it's not the problem.
Thanks.
Jeff
Old Jul 29th, 2006, 2:26 am   #4 (permalink)
Sorry, I was joking about the petcock, it went the way of the carburators I believe.
Thanks for straigtening me out on the imperial gallons, I know it comes up when people are comparing fuel economy figures from different countries.
Wonder if anyone else has any ideas about the discrepancy? Are the gas tanks that much diferent between the sport and the GT? Maybe that's where the error came from, but you'ld think it would be larger for the GT anyway.
Old Jul 29th, 2006, 6:11 am   #5 (permalink)
Jeff_Quan's Avatar
Oh, sorry. I missed that one 'cuz the '04 Bonneville I had did have a petcock still.
All fuel economy ratings in miles per gallon will be in US gallons. All of Europe (including the UK I believe) use litres per 100 km. I don't know of anyone that used imperial gallons in figuring fuel economy.
Not sure where the discrepancy comes from but I am curious.
Jeff
Old Jul 29th, 2006, 6:17 am   #6 (permalink)
ducman123's Avatar
Welcome to the world of Ducati fuel tanks. On my Multi even though the specs say 5 gal. I have not been able to get more than 3 in it. On this one, the light goes on and that silly km trip meter starts count down. After 30 km's of that it still only takes 3 gal.
ducman123 is offline   Reply With Quote
Old Jul 29th, 2006, 9:34 am   #7 (permalink)
Moderator
geospencer's Avatar
Did it still have carburetors?
geospencer is offline   Reply With Quote
Old Jul 31st, 2006, 10:56 pm   #8 (permalink)
Guzzilla's Avatar
12.75 liters? That's it? Rather disappointing. This means that I can only go about 135 miles (225 km) between fill-ups. Does this sound right for a bike with the Termignoni kit?
Guzzilla is offline   Reply With Quote
Old Aug 1st, 2006, 2:56 am   #9 (permalink)
Jeff_Quan's Avatar
I'm getting less than 200 km per tank with the Termi's. Maybe I need to loose some weight
Jeff
Old Aug 6th, 2006, 11:13 am   #10 (permalink)
hawc's Avatar
I'm on a Sport 1000 with Termis and getting about 120km (75miles) to the tank (to the point where the fuel light starts coming on and off)! It's a real PITA because on any ride at all I'm usually filling up at least once. I do like to let the bike rev up to 5000rpm now and then though.
hawc is offline   Reply With Quote
Repairing a leaking SS tank Rainman Supersport 58 May 10th, 2012 5:46 am
Repairing leaky rusted steel tanks Rainman Hall of Wisdom 14 Jan 6th, 2011 11:31 pm
Fuel tank capacity of 748 goober Superbikes 4 Apr 29th, 2006 8:55 pm
