What the FORK is That? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 20 (permalink) Old May 3rd, 2016, 8:26 pm Thread Starter
Official Sponsor
SPORT_CLASSIC_SPECIALTIES's Avatar
Took the following for a side by side comaprison
SC Marzocchi, Ohlins S4RS, Ohlins M1100, Sport Classic Ohlins
L to R
Marzocchi Bitubo Conversion, PS-Ohlins (corrected from:M1100) Ohlins, Stock Marzocchi, S4Rs
L-R
Stock Marzocchi, SC Ohlins, S4RS
and side by side mounted
Have a look at the gallery here for the basics
Fork Comparison Marzocchi, Ohlins S4RS, M1100, Sport classic Ohlins
unedited gallery has much more info
unedited S4Rs / M1100 / PS ohlins / Marzocchi / Marzocchi Bitubo conversion
and Radial caliper with Stock Spokes wheel will clear but it is too clsoe for riad use. if you ride gently it may never hit
but the spokes will eventually hit the caliper
mikethepole likes this.
jc@jcpakbikes.com
sportclassicspecialties.com
JCPAKBIKES.COM
FACEBOOK JC/PAK BIKES
FACEBOOK GT1000
FACEBOOK PS1000LE
FLEDA TRON LEGACY
ALPINA WHEELS USA
AELLA-CASUNO / NCR / DISCACCIATI / CARBON DRY / BITUBO / MUPO
SPORT_CLASSIC_SPECIALTIES is offline
post #2 of 20 (permalink) Old May 4th, 2016, 12:11 am
unM0derator
RedST's Avatar
Images: 3
Are you sure those M1100 forks are from that bike? I have a set and they are radial mount brakes and TiN coated. Those look like the standard PSLE forks. Pic for reference.
Geoff
RedST is offline
post #3 of 20 (permalink) Old May 4th, 2016, 12:44 am
swoardrider's Avatar
I think you are right redst, I don't think those are off a monster. I think they are the Paul Smart Ohlins.
swoardrider is offline
post #4 of 20 (permalink) Old May 4th, 2016, 1:05 am
Geoff
1100S are radial from what I remember. A direct swap same as the S4RS, just slightly longer tube (let it stick up a little above top triple, to retain same geometry). Radial mount brakes, with the fender mounting in new superbike fashion (2 in front).
2007 1098S (Track Bike)
2006 Sport Classic 1000 (Sold)
Agro is online now
post #5 of 20 (permalink) Old May 4th, 2016, 3:50 am
i was waiting for this post since a long time ! Thanks a lot JC, it's just perfect !
For sure, the second fork on the 1st and 2nd pictures is a Paul Smart OEM Ohlins and not a M1100 Ohlins
The radial fork with radial caliper is clear with OEM spok wheels but very near of the spok ... in a hard ride or hard brake, for sure the spok will touch the caliper
My question : is there a difference in size between different radial calipers ? maybe one model would be more slim and let more space with the spok ?
Brizio is offline
post #6 of 20 (permalink) Old May 4th, 2016, 10:26 am Thread Starter
Official Sponsor
My Bad, it was in the unedited link
The longer one with the radial is the Monster 1100
jc@jcpakbikes.com
JCPAKBIKES.COM
FACEBOOK GT1000
FACEBOOK PS1000LE
FLEDA TRON LEGACY
ALPINA WHEELS USA
post #7 of 20 (permalink) Old May 4th, 2016, 10:32 am Thread Starter
Official Sponsor
The second from teh left is a PS ohlins. I added shots of the M1100.
The Radial Claipers I have had in hand so far all seem to share the same dimensions. I think this is would be a standard for OEM use
jc@jcpakbikes.com
JCPAKBIKES.COM
FACEBOOK GT1000
FACEBOOK PS1000LE
FLEDA TRON LEGACY
ALPINA WHEELS USA
post #8 of 20 (permalink) Old May 4th, 2016, 10:48 am
Any idea if there's internal differences between the 3 different Ohlins? Stroke, spring rates, valving, etc?
post #9 of 20 (permalink) Old May 4th, 2016, 11:12 am Thread Starter
Official Sponsor
I have been told the internals for the Paul Smart is not the high end stuff from Ohlins. I suppose it may be the same with the S4RS.
Nevertheless
I have never had a bad experience with most forks if adjusted properly
Although.....
I test ride lots of customers bikes and there have been times that the stock Marzocchi has surprised me. Maybe it was built on wednesday? And the Paul Smart forks rode like crap.
With proper set up and adjustments any suspension can be made to be a little better. It takes patience and effort with suspension. It has never been a immediate change because too many factors to work with.
Riderjeff likes this.
jc@jcpakbikes.com
JCPAKBIKES.COM
FACEBOOK GT1000
FACEBOOK PS1000LE
FLEDA TRON LEGACY
ALPINA WHEELS USA
post #10 of 20 (permalink) Old May 4th, 2016, 2:00 pm
unM0derator
RedST's Avatar
Images: 3
Nevertheless
Although.....
FYI: the M1100S is one of the most precise and smooth Ducs I've ever ridden. The forks seemed very well set from the factory and the SC is very close in weight and geometry, so wouldn't expect much difference with just a swap and new brakes. The critical dimension, by the way, for radial mounts is the disc diameter and needing spacers to increase radius. They all share the same lateral offset if memory serves, and that was one of the goals for the switchover.
Geoff
RedST is offline
Human Verification
Fork upgrade questions psyopper Supersport 16 May 25th, 2016 7:20 pm
Motion Pro and Race Tech Fork Tools moto Motowheels 2 Apr 24th, 2016 8:20 pm
Motion Pro and Race Tech Fork Tools moto Motowheels 1 Feb 17th, 2016 10:16 pm
ATHENA Front Fork Seals: Ducati moto Motowheels 1 Dec 25th, 2015 4:04 pm
Multistrada 1200S DES Fork Bleeding johnnysneds Suspension and Tire Tech 2 Dec 20th, 2015 9:43 am
