Removing the spacer on the clip ons - Ducati.ms - The Ultimate Ducati Forum
Old Oct 5th, 2008, 9:17 pm   #1 (permalink)
So I've had my SC 1000s for a few weeks now and I have to say the end of every ride leaves me wanting more. I'm getting used to the aggressive riding position but have to admit, the bars being just a "bit" higher and not as long a reach would make the fit so much better. I'm going remove the spacers to raise the clip ons and from what I can tell, this will require the bars to be pulled back a bit to avoid hitting the faring. I'm also concerned with the adjustment required to keep the bars from hitting the tank, the end result being less turning radius.
Will this change make enough of a difference to improve the comfort or is the effort a waste of time.
Thanks....
Hedly
Hedly is offline   Reply With Quote
Old Oct 5th, 2008, 11:18 pm   #2 (permalink)
Greg_S's Avatar
Thanks....
Hedly
yes
2004 749R #0065
2008 Hyper S - Sold
2007 SC 1000 S - sold
2005 999 S - SOLD
2006 KTM 950 SM - SOLD
Greg_S is offline   Reply With Quote
Old Oct 5th, 2008, 11:27 pm   #3 (permalink)
mooner's Avatar
What he said. I left the roll pins in place after removing the spacers, to help correctly position the clip-ons.
2008 Hypermotard S
mooner is offline   Reply With Quote
Old Oct 5th, 2008, 11:33 pm   #4 (permalink)
jcsport's Avatar
Images: 12
With the roll pins left in the stock bars will still be in a very "flat" position and still have a long reach. I pulled the roll pins too to bring them back a tad but then ended up tossing them altogether and installed SC Risers - luxury
2008 Sport Classic 1000s
2007 HD FXDCI
2008 Mercedes Benz E500 Avantgarde
2009 Holden SS
Gone but not forgotten;
1994 SS900
1982 Darmah 900
1980 MHR900
1979 SS900 (Black/Gold)
1982 Pantah SL600 (Hailwood)
jcsport is offline   Reply With Quote
Old Oct 5th, 2008, 11:45 pm   #5 (permalink)
Images: 4
The decreased turning radius is a non issue and tight u-turn maneuvers are not a problem.
When adjusting the steering stops so the bars clear the tank, also leave some room for your thumb between the grip and the tank at full lock. But don't reduce the steering radius too much or you won't be able to turn the key to the lock position when parked.
JASON_ALT is offline   Reply With Quote
Old Oct 6th, 2008, 6:23 am   #6 (permalink)
DADDA's Avatar
I removed the pins and raised the bars to the top within 2 hours of owning the bike! It makes a big difference. The bars have to come in a bit so they don't hit the front of the fairing at full lock, and you then have to adjust the steering stops to ensure they don't hit the tank.
When adjusting the steering stops - wear your normal riding gloves when checking for clearance to ensure your thumb doesn't get squashed. I learned this the hard way....
The loss of steering lock is minimal, not really an issue except when moving the bike around in the garage.
The difference in comfort is massive!
The Ducati Sport Classic is like the perfect wife. She's a classic and sporty. Oh, and my wife IS perfect.
DADDA is offline   Reply With Quote
Old Oct 6th, 2008, 2:52 pm   #7 (permalink)
Exactly the end result I'm looking for however, after a visit to my local Ducati dealer(s) both suggested this modification was "unsafe" based on the function of the spacers are to keep the clip ons in place and prevent them from rotating "should something happen". Allan bolt coming loose ? I dunno...From what I'm reading a number of SC 1000s owners have done this. Anyone had a bad experience or is the dealer just being overly cautious ?
Thanks,
Hedly
Old Oct 6th, 2008, 3:19 pm   #8 (permalink)
Monstyr's Avatar
Your dealer is a condescending prat.
Go and ask him if any of the superbikes have these fitted? Its a vertical spacer, the clamp bolts hold the clip ons in place,both vertically and rotationally,if 'anything' happened that was enough to shift them then the spacers would probably ping out and hit you in the eye,but then,that would be the least of your worries in that case.
"The problem with quotes on the Internet is that you can't tell whether or not they're genuine" - Abraham Lincoln
Monstyr is offline   Reply With Quote
Old Oct 6th, 2008, 4:49 pm   #9 (permalink)
jcsport's Avatar
Images: 12
Thanks,
Hedly
Your dealer is talking shite, it was my dealer that actually removed my spacers before i even rode the bike out of the shop. I took out the roll pins myself about 2 weeks later. So long as you follow torque specifications there is no way that clip-ons will move.
2007 HD FXDCI
2009 Holden SS
1994 SS900
1982 Darmah 900
1980 MHR900
Old Oct 6th, 2008, 8:26 pm   #10 (permalink)
Images: 4
12k and mine haven't budged.
You could always double check the bolts at each oil change or apply some blue loctite and forget about it altogether.
Clip ons What size for 03 999 indetrucks Superbikes 4 Aug 5th, 2008 5:55 am
Polishing clip ons jcsport Sport Classic 12 Jun 9th, 2008 5:52 pm
sport 1000s clip ons desmopowertwins Sport Classic 1 Apr 21st, 2008 1:07 am
998 V's 999 Clip ons rocka Superbikes 2 Apr 8th, 2008 11:43 am
