Nov 26th, 2006, 7:09 pm
Converting a SuperSport 1000DS to a Naked Sport Classic?
A friend of mine wrecked his 2005 SS1000DS (very happy that he escaped with just blue shoulders - his dainese gear and arai did their job) - while he is trying to find what the salvage value.. I am thinking about the possibilty of buying it and making it a project bike.
I am not looking for suggestions or project ideas - I know what I want - a proper 2up, air cooled DS1000 engined, naked, rational seating position, bike. I deal would be a cross between a sport1000(tank) and a GT1000(seat and side panels) - no chrome, 5 spoke marchesini wheels, with a mono shock and etc..
So few questions?
1. Are the SuperSport (2005) and SportClassic frames (reasonably) that same? ( I am not concerned about rear shock mounts as I prefer the SS mono and swingarm setup)
2. Can the a GT1000 seat be fiited along with Sport1000 Tank on the frame?
3. What needs to be done to make it a naked? just battery, wiring, & new headlamps?
4. Can a Monster S*R Single Side Swing arm be fitted?
Current Bikes: 1995 Monster 944, 2000 996, 2004 FJR 1300, 2010 StreetFighter S
Nov 26th, 2006, 7:34 pm
I cannot answer all your questions, just throw in a few thoughts. I am doing a retro styled ST2. you might look over AirTech's web site. they have bunches of vintage glass parts including seats and 1/2 fairings. might be worth looking at for a few ideas. I am sure the frames are different as at least the shock placement is totally diff. print off a few photos and study them for a while.
Nov 26th, 2006, 8:57 pm
Why not just check out one of the websites that has Ducati parts lists on it and see if the frames have the same or different part numbers?
Dr.D
'06 Paul Smart 1078LE (too many mods to list)
'01 Aprilia SL 1000 (RSV Swingarm, RSV Shock/Dog-Bone, RSV Steering Damper, Renegage Airbox Mod, Heated Grips, Heat-Troller for Heated Gear, Tigcraft 80mm Titanium Exhaust/ECU, Custom Paint)
'89 Honda GT650 Hawk
'98 YZ400F (seized crank, still needs fixin')
Nov 26th, 2006, 10:28 pm
ROF
http://www.ducati.com/en/bikes/servi...l?family=parts
Nov 26th, 2006, 10:32 pm
I think the frames are quite different. I'm also sure that the forks and shocks on the SS were far superior to what is on the Sport 1000 (not so compared to the PS). The brakes are also better. You also obviously don't have the spoked wheels.
Depending on how "true" you want to be, it would seem fairly easy to convert the SS to a cafe racer, albeit it won't be the same as a SC, for the reasons stated above.
I'd simply add a DP rear seat cowl for the SS, which I'd guess would be similar to new Sport 1000 Biposto. Peel off the fairings. Leave the clip ons. Then all you'd be shopping for are bar end mirrors, headlight, and instrument cluster.
Blinged out Yellow '06 SportClassic Sport 1000 Monoposto: Termi 2:2, Ceramic Coated Exhaust, DP Race ECU, Ducshop Hyperstacks, PCIII, SpeedyMoto Clutch Bling, Yoyodyne Clutch Slave, SpeedyMoto Sprocket Cover, Rizoma Timing Belt Covers, DP Bar Risers, Pazzo Racing Levers, Rizoma Billet Grips, Rizoma Bar Ends and Mirrors, Rizoma Reservoirs, National Cycle Fly Screen custom painted, DP Tank Bag/Bra, Storz-Ceriani Steering Damper, Sato Rearsets, Custom Brake Lever Peg by FFR, Nichols Engine Mount Bolts, Nichols Crankcase Cover, GP Fork Cartridges and suspension "magic" by CRST, SuperSprox 14-41 Sprocket/RK 520 Gold Chain Conversion, Alpina STS Tubeless Spoked Wheels, Brembo Gold Line 4 Piston Front Brake Calipers, Feroda Platinum Pads, Galfer Wave Rotors, SSR CNC Gas Cap and Oil Cap, DPCARS Fender Eliminator Kit, Cox Racing Group Oil Cooler Guard.
Red '99 750 Supersport Half Fairing: Sil-Moto CF Slip-ons, Evoluzione Clutch Slave, 14T Front Sprocket, Corbin Seat, Storz-Ceriani Steering Damper, otherwise stock.
Black '12 Honda CBR250R: (Keeps me entertained until I find the Black 749 that I am searching for) Too new to even have any mods, so totally stock.
Certified Peet's Coffee Junkie
Nov 27th, 2006, 5:52 am
Moderator
Function-wise that'd be true, but it'd take a good deal more to get the appearance issues solved.
One of the successes of the SportClassic series (which remains well hidden) is how much attention was paid - and the clever solutions found - to hiding the working parts needed on a modern mass production motorcycle. Big air boxes. Electrical this and thats. Tubes. Hoses. What nots. Old machines didn't have these things (God bless 'em!). The SCs do and so do the SSs.
You can view a Sport Classic in profile and not see them. Remove the fairing from an SS and you do. That's, quite frankly, half the function of the plastic -- to hide those unsightly parts.
My older SS has far less of that stuff than the newer model. But when I view her naked the first thing that comes to mind is "Darling, please put on your cloths or turn off the lights." Not so with the GT1000. What she elicits is "Why don't you finish that apple my Dear and come lie with me in the grass."
-don
DUCeditor
Ducatis Unlimited Connection
www.duc.bz
"If I knew what an iconoclast was I'd probably be against that too." -Chabis Yadofsky
`07 GT1000 "Sommessa Donna" (Quiet Lady)
`93 900SS "La bella Rossa" (The Beautiful Red)
Nov 27th, 2006, 6:45 am
Good point about exposing all the hidden wiring, coils and other unsightly parts when you remove the SS fairings, but isn't that part of the fun - figuring out how to make it look like you want it to look?
I don't think anyone on this forum will have a "pat" answer to your questions on this project. You'll need to assemble the chosen parts and have at it.
Nov 28th, 2006, 4:50 pm
So few questions?
4. Can a Monster S*R Single Side Swing arm be fitted?[/QUOTE]
1. Reasonably...yes. Both are tubular steel.
2. Yes, if you can weld and fabricate tabs onto the frame, which you can with a steel frame. Watch a chopper show, you can do anything with a steel frame.
3. Depends on your definition of naked. Some folks idea is much cleaner than others. Look at some "Streetfighter" websites for bolt on headlight ideas.
4. Depends again on your wrenching skills.
I like your ideas, and won't offer any project suggestions. But If I were you, I'd do a naked/streetfighter bike and not try to make it look like a classic. Post pics here whatever you do.
Metal Minutia
96 916
09 Bonnie
86 CH250
08 CRF230L
Nov 29th, 2006, 10:46 am
Banned
check in the supersport picture threads there are a few pics of street fightered ss's in there and a really good one with a ps fairng on it.
