GT1000: Clutch Not Disengaging Fully - Ducati.ms - The Ultimate Ducati Forum
Old Feb 3rd, 2012, 9:50 am   #1 (permalink)
Tmnstr's Avatar
Jumped on my bike this morning and noticed that clutch wouldn't fully disengage when pulling in the clutch lever in first gear. Neutral felt 'free' but 1st gear, with clutch lever pulled in, had noticeable 'dragging'. Decided not to ride it till I get it sorted.
Does anyone know why this is happening? She was perfect a week and a half ago
Note: Bike always garaged, always dry. Clutch and brake fluid changed 600 miles ago. Evoluzione slave cylinder. Pazzo levers.
Thanks for any help/info in advance.
Cheers,
Tmnstr
Tmnstr is online now   Reply With Quote
Old Feb 3rd, 2012, 10:37 am   #2 (permalink)
sounds like you've either got air in your clutch line, either your slave/master is bad, or your clutch plates are sticking together, which rarely happens with a wet clutch, but it does happen
arbakken is offline   Reply With Quote
Old Feb 3rd, 2012, 11:02 am   #3 (permalink)
YMRacing's Avatar
Bleed it first. If that doesn't seem to help put the front wheel against a solid surface...a tree works, start the bike and put it into first gear. If the plates are sticking a little this will free them. If it truly is dragging it will kill the engine.
If it breaks them loose, take it for a ride to warm it up good then change the oil and the filter.
YMRacing Road Race and Rider Schools
Garry W. Bird, Owner/Mgr
YMRacing is offline   Reply With Quote
Old Feb 3rd, 2012, 1:53 pm   #4 (permalink)
Tmnstr's Avatar
Thanks for the advice. I just had all fluids and filters done 600 miles ago, so I'm going to see if my shop will re-bleed it/diagnose it without charge. Fingers crossed
Tmnstr
Old Feb 5th, 2012, 9:30 pm   #5 (permalink)
Tmnstr's Avatar
Bike Wisdom Update: Talked to Mark S @DucShop and after a lengthy phone diagnosis suited up and took her out to see if she would not go into neutral/pull along in first with the clutch in at a stop sign/red light.
Result: No drivability issues at all (!) Seems that she needed to be taken around the block to loosen her up.
Should've known
Know I know,
Tmnstr
2009 gt1000 looking for advice on fully adjustable rear shocks paul f Sport Classic 11 Dec 12th, 2010 3:48 pm
Clutch not fully disengaging and oil leak at Slave snlsmith Supersport 3 Sep 9th, 2010 9:12 am
new clutch - won't fully disengage.. WRW Superbikes 11 Feb 25th, 2008 11:37 am
Clutch does not disengage fully... stan23 Superbikes 8 May 30th, 2007 8:57 am
Clutch not disengaging when hot kannon Supersport 2 Nov 25th, 2006 2:52 pm
