Rear Brake (rearset) help on Biposto to Mono - Ducati.ms - The Ultimate Ducati Forum
Old Feb 1st, 2012, 6:26 am   #1 (permalink)
LondonDutch's Avatar
Hi All,
Sorry to bore you with this again... but I am finally getting ride of my "ugly black triangles" and have ordered some aftermarket rearsets to fit on my Biposto. (and some Mack hangers from JC)
They are made for an SC mono (also 900ss) so for one of those they are a direct swap, but I am pretty sure I will need some kind of bracket to remount my rear brake M/C, mono-style (or maybe also ss style?)
Please can any of you who have fitted rearsets to your mono, or upgraded your biposto rearsets to mono-style, please look at these photos and tell me what parts I am missing to do this swap in a single day's work, so I'm not left with a bike that has no back brake while I source parts.
These are the rearsets from all angles:
Current setup:
Monoposto EM setup:
There is clearly some kinda bracket holding the M/C onto the crankcase below the brake lever. This may be generic to a few Ducs? (I'm assuming I can res-use my M/C in a new location?).
I'm also assuming the gearbox side is fine?
LondonDutch is offline   Reply With Quote
Old Feb 1st, 2012, 6:49 am   #2 (permalink)
Yikes - I need heel plates too!
I also found this on ebay: From a 916 but looks identical in shape to the PS?
http://www.ebay.co.uk/itm/DUCATI-748...item35b920c0d2
Old Feb 1st, 2012, 7:31 am   #3 (permalink)
I just found this post from my earlier thread - with pics from JC
and the Right side you would also need the brake pedal assembly and bracket
It helps a bit... But practical advice is still needed.
Old Feb 1st, 2012, 8:35 am   #4 (permalink)
rapete's Avatar
Images: 5
Hmm, where to start...
as you figured out already the gearing side is simply plug &play. A bit tricky seems the right side. You will need the bracket, bought it off ebay. furthermore you pretty much need all the conundrum which is in line with bolt#27 plus bolt#15. even the spring isnīt exchangeable. the master cylinder and periphery is fine and can be reused.
good luck!
rapete is offline   Reply With Quote
Old Feb 1st, 2012, 10:32 am   #5 (permalink)
good luck!
I was kinda hoping that the spacers, washers and even the spring would be similar to those already used with the rear brake pedal in the biposto setup? - and that all I would need is that bracket...
Hmmmm....
They may all be quite cheap as new parts, but knowing Ducati....
I was also wondering about the rear brake light switch?
Anyone got the parts mircofiche of the Biposto set up, so I can see what's missing?
Old Feb 1st, 2012, 10:57 am   #6 (permalink)
Ask JC and one shall receive.
Thanks dude.
Now, what's missing....
Old Feb 1st, 2012, 11:15 am   #7 (permalink)
Unleaded caffeine please...
petrole's Avatar
DUCATI 748 916 996 BREMBO REAR BRAKE MASTER CYLINDER AND BRACKET | eBay
It should work. I used the M/C bracket from my 748, as well as brake lever.
What you'll need is the collar bolt (#27 in the rear brake assembly diagram) and spring (#21). ~ $30 & 8 USD respectively.
That reservoir tube might not be long enough.
Does that rearset kit come with bolts/washers/o-rings?
Most of the bolts can be sourced from hardware store.
Nope, the spring is different.
As for the rear brake switch - seems to be quite a stretch. I've seen pics were people have rerouted to the outside of the rear reservoir, but I wasn't able to do this, had to route onto the underside of the downtube. I'll post pics. (This is if you're running Zard exhausts)
petrole is offline   Reply With Quote
Old Feb 1st, 2012, 11:24 am   #8 (permalink)
749/999 mount fits the SC and is a standard bit on the Smart and monos mate-I ordered one new from the shop-about the same price as one on ebay plus shipping-dont forget the little grab/plug for the brake spring-I did
gusman77 is offline   Reply With Quote
Old Feb 1st, 2012, 11:29 am   #9 (permalink)
Petrole - that is a superb help. Thanks you so much.
I think the rear set kit I have bought is just whet you see in the photos, so I will have to source the generic bits.
I like it's simple looks, and it was easier to find than a monoposto OEM setup in good condition - and no more expensive either.
Old Feb 1st, 2012, 11:39 am   #10 (permalink)
rapete's Avatar
Images: 5
I just checked properly...regarding the last pic of parts catalogue PS, here is what you still need...
#15
#19
#20
#21
#23
#24
#27
#28
#31
Also itīs true as you can buy a used bracket off a 999/749. I did and it fits perfectly.
regards
wtb xx9 rightside rearset,rear brake lever robob Parts and Accessories 2 Oct 12th, 2010 10:39 am
Mono to biposto .. Oberon Sport Classic 1 May 12th, 2010 4:09 pm
WTB: Stock rearset for Sport Classic Mono WFOAlways Parts and Accessories 7 May 5th, 2010 8:01 pm
Rearset for SC Biposto koucki Sport Classic 1 Jun 1st, 2009 6:36 pm
Biposto to Mono DucNCover Superbikes 4 Nov 22nd, 2007 8:48 pm
