Jan 29th, 2012, 12:09 am
new chain and sprocket suggestions..
hey guys in need of some advice. im just about to change out my chain and i was told that by the looks of it i might need new sprockets, im not necessarily on a budget but just need some suggestions on whats out there, this is my first chain driven bike and im ignorant on the subject..
thanks for your time and advice, - F.B.
Jan 29th, 2012, 1:22 am
I use a Supersprox rear sprocket, it has a aluminum center for light weight, & a steel outer ring for durability. For even lighter weight you might want to try a 520 chain set-up.
Aloha Alex
Jan 29th, 2012, 4:21 am
It's always wise to replace the sprockets at the same time as the chain - they tend to "wear together". Putting a new chain on worn sprockets will knacker the chain mucho quickly.
Don't want to recommend brands as I'm in the UK - I've always gone for B&C but don't know if they're available across the water.
Ian.
Jan 29th, 2012, 4:46 am
1000 GT/Sport/Paul Smart 06-10 Sprocket Center
Does this help?
I bought a set from here after I did a 999 wheel conversion... but i went for a 520 size chain setup...
2008 Sport 1000 biposto with Termignoni slip ons and Ducati Performance ECU.
Oberon 29mm clutch slave.
999R Forged Aluminium Marchesinis
749 Rear rotor and caliper.
999 front rotors
Brembo Monobloc Radial Calipers
Ohlins Forks
Rear spacer kit from Fast Frank Racing.
Michelin Pilot Road 2 tyres.
Fleda Tail unit
Jan 29th, 2012, 5:20 am
I just ordered the 520 Supersprox kit from JC. He gives a good discount. Also if you are getting other than stock gearing there is a chart that shows what the best combinations are for wear purposes .
Parabellum, Hyperpro, Hagon, Staintune, Rossi Hugger
Jan 29th, 2012, 6:43 am
I also purchased my chain/sprocket set from JC. Good price, great service, and he is the sponsor of this forum.
I went with the 520 versus the stock 525. the 520 is both lighter and less expensive.
I am not sure which SC you have, but the stock gearing on the Sport 1000 is 15/38. Most folks go down one tooth is the front to a 14T. It will transform your bike, making it easier to start off from a dead stop. I also went ahead and increased my rear sprocket to 41T. That gives you even faster acceleration, but at the cost of ultimate top speed. But it will also give you more use of all your gears, meaning you will actually be able to use 5th and 6th gear.
Blinged out Yellow '06 SportClassic Sport 1000 Monoposto: Termi 2:2, Ceramic Coated Exhaust, DP Race ECU, Ducshop Hyperstacks, PCIII, SpeedyMoto Clutch Bling, Yoyodyne Clutch Slave, SpeedyMoto Sprocket Cover, Rizoma Timing Belt Covers, DP Bar Risers, Pazzo Racing Levers, Rizoma Billet Grips, Rizoma Bar Ends and Mirrors, Rizoma Reservoirs, National Cycle Fly Screen custom painted, DP Tank Bag/Bra, Storz-Ceriani Steering Damper, Sato Rearsets, Custom Brake Lever Peg by FFR, Nichols Engine Mount Bolts, Nichols Crankcase Cover, GP Fork Cartridges and suspension "magic" by CRST, SuperSprox 14-41 Sprocket/RK 520 Gold Chain Conversion, Alpina STS Tubeless Spoked Wheels, Brembo Gold Line 4 Piston Front Brake Calipers, Feroda Platinum Pads, Galfer Wave Rotors, SSR CNC Gas Cap and Oil Cap, DPCARS Fender Eliminator Kit, Cox Racing Group Oil Cooler Guard.
Red '99 750 Supersport Half Fairing: Sil-Moto CF Slip-ons, Evoluzione Clutch Slave, 14T Front Sprocket, Corbin Seat, Storz-Ceriani Steering Damper, otherwise stock.
Black '12 Honda CBR250R: (Keeps me entertained until I find the Black 749 that I am searching for) Too new to even have any mods, so totally stock.
Certified Peet's Coffee Junkie
Jan 29th, 2012, 7:44 am
CHT hard anodized aluminum + RK chain
Jan 29th, 2012, 4:39 pm
Official Sponsor
520 or 525
Full kits from Supersprox are
Free shipping (usa) and a Free t-shirt
If you get the drive kit there is a Lifetime guarantee on the rear sprocket
Here are some recommended tooth counts
14/39 14/41 15/42
Jan 29th, 2012, 11:24 pm
thanks for all the feed back guys, i really appriciate it.
i dont track my bike or do any hard racing ( though id like to) so i was looking for stock suggestions since its my daily ride
jc thanks i will either order directly from supersprockets or be emailing you soon there are some other things id like to get from you,
once again thanks for the feed back, you guys are awesome.
Jan 29th, 2012, 11:46 pm
.....i dont track my bike or do any hard racing ( though id like to) so i was looking for stock suggestions since its my daily ride.....
IMHO, re-gearing the bike (going down on the front sprocket and/or up on the rear) DOES make the bike more user friendly as a daily ride, and the gearing more usable overall (otherwise you will rarely need to get into even 4th gear).
