Guys,
I've been pouring over the suspension threads this past week and I haven't seen any of them mention using a 748 or 749 top triple clamp (53mm) with 748 forks. If they have mentioned it, the threads have been light on info. I was planning on shimming the lower 1mm up to 54mm in order to use the stock SC lower clamp. I am not comfortable boring out the top from 50 to 53mm for fear of stressing the metal as it might fail unexpectedly at some point (I've had a front brake lever break apart on me unexpectedly... nearly squeezed a diamond out). I was wondering if anyone had used a stock 749 or 749 top triple on an SC? Things that I suppose would prevent its use would be:
- stem diameter
- width of front fork bores center to center (different from SC?)
- way in which the stock SC stem attaches (press or thread) into the 748/9 top triple
- overall dimension of 748/9 triple (maybe it won't fit?)
Has anyone tried this? Success or failure?
Anything that I'm not considering?
Funds are severely limited, technical skills are limited and machining skills are nonexistent. I appreciate any input you fellas may be able to lend.
I guess I should also ask whether or not the stock 748/9 forks are any better than stock S4 forks (which are direct swap). I had read a comment that said the S4 forks weren't much better than the SC forks. Main reason for looking into the 748/9 option is much better availability than S4/S4R/ST forks.
