What is the rear shock length? ( Ohlins ) - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Jan 18th, 2012, 10:20 pm   #1 (permalink)
ConnorB's Avatar
Hi all, I recently picked up an old Norton Commando that I'm gonna be doing a full cafe treatment to. I want to put some twin Ohlins shocks on the rear, and was wondering if the SC shocks happened to be the correct length. That would be great, then all I would need to do is find a used set
Would someone be able to measure their shock length for me? From top mount to bottom, preferably with the rear wheel off the ground so it's at full extension. I'm hoping its close to 12.75-13" but if not oh well! Would really appreciate the favor!
Cheers,
Connor
1999 Ducati 996 SPS #417
ConnorB is offline   Reply With Quote
Old Jan 19th, 2012, 5:24 am   #2 (permalink)
Official Sponsor
JCPakBikes's Avatar
funny a Norton question in the sport classic section
Nevertheless
I believe there is a Ohlins shock for the older Ducati that may work
I'll find out and get back to you
If thet remove this thread
email me and I can email you back the info
JC
Cheers,
Connor
jc@jcpakbikes.com
JCPAKBIKES
sportclassicspecialties.com
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Old Jan 19th, 2012, 8:53 am   #3 (permalink)
ConnorB's Avatar
Thanks, yes a Norton question I guess but the audience that could answer my question is you guys so hopefully this is okay. I think i found one type that may fit, called a PRCLB. Would be great if an OEM shock from another bike (like your sport classics) would fit because then I could buy used.
Thanks,
Connor
Old Jan 19th, 2012, 9:45 am   #4 (permalink)
Official Sponsor
JCPakBikes's Avatar
A good source for information would be contacting the Socalnorton.com
or go to the socal norton Facebook page.
Thanks,
Connor
jc@jcpakbikes.com
JCPAKBIKES
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Old Jan 19th, 2012, 10:40 am   #5 (permalink)
Official Sponsor
JCPakBikes's Avatar
Ohlins does have a 900ss shock 331.5 mm
We can get these
and
The DU707 is for the GT and Sport and NCR new blue
We can have custom shocks made to spec for most
Pricey... after all it is a Ohlins
but
If you are on a budget..... talk to a Norton owner, they are good a scrounging for bargains
jc@jcpakbikes.com
JCPAKBIKES
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Old Jan 19th, 2012, 10:55 am   #6 (permalink)
Official Sponsor
JCPakBikes's Avatar
BTW the du707 is 378mm
jc@jcpakbikes.com
JCPAKBIKES
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Old Jan 19th, 2012, 11:49 am   #7 (permalink)
ConnorB's Avatar
Thanks for all the info! I've got some searching and research to do!
Old Jan 19th, 2012, 2:44 pm   #8 (permalink)
thoroughly addicted
Sport Classic shocks are too long.
If you go with Ohlins on the rear you're going to be really unhappy with the stock Norton forks. Most Commando owners, being rather frugal in nature, just throw on a set of Hagons and call it good. But it's been said that the cheapest part on a Norton Commando is the nut the connects the handlebars to the seat!
There are other things you should look at upgrading before dropping big coin on shocks - new isos, upgraded headsteady, maybe a steering damper. Do a full rebuild and make everything right before getting into a lot of mods. Make sure the frame is straight. Also the fork tubes (they are probably bent). Hook up with your local Norton owners club. These bikes are pretty straightforward to work on but there are things you need to know about so you don't make expensive mistakes.
Post some pics. Check out accessnorton.com and start reading back posts. Tons of info there.
good luck,
Debby
72 Combat
74 850
plus a few non-Nortons...
In the garage:
07 GT1000, gray
Previously in the garage:
65 250 Scrambler
02 998 Mono
07 Hyper S
97 900 SS/CR
67 250 Scrambler
debby is offline   Reply With Quote
Old Jan 19th, 2012, 5:51 pm   #9 (permalink)
ConnorB's Avatar
Thanks Debby. The bike is actually almost complete from a restoration done by a friend who lost interest. Rebuilt engine, new Iso mounts. It is pretty well gone through. All it really needs is to be assembled, but I want to change it up quite a bit.
My plans are to take modern sportbike inverted forks and twin disc brakes and fit them to the Norton. Probably need to reinforce the steering neck. I was tossing around the idea of doing a monoshock conversion in the rear, but I think I just want to go the twin shock route with upgraded pieces, like Ohlins. Want to put some Excel wire wheels on it. Probably going to do a chopped rear subframe to get that tiny cafe racer seat look.
FS: 996 Ohlins Rear Shock mito_gp Parts and Accessories 1 Mar 16th, 2011 10:01 pm
F/S: Ohlins rear shock for 749/999 delirious Parts and Accessories 4 Jul 20th, 2010 10:49 am
LTB ohlins rear shock for st3/st4 redbandit91 Parts and Accessories 0 May 19th, 2010 12:41 am
Ohlins Rear shock cb4265 Sport Touring 25 Feb 19th, 2010 2:01 am
Ohlins rear shock eye to eye Gizmo Sport Classic 5 Aug 15th, 2008 12:33 pm
