1098 Front Fender on SC ... Does it Fit? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Jan 17th, 2012, 7:01 am   #1 (permalink)
Hey guys,
I noticed a few SCs have the 1098 front fender, however it's not listed on any of the direct fit lists I've seen.
I like the smooth front and rear curves of this fender, similar to stock and the nice guard. I prefer it over the busy Y frame of the monster fenders, or the squared off rear of the 748.
Is this a direct bolt up to the stock forks with the plastic hangers ... or how much work needs to be done to make this work?
Thanks,
Guy
2009 Ducati SportClassic Sport 1000 Biposto Black
GuyBFF is offline   Reply With Quote
Old Jan 17th, 2012, 11:08 pm   #2 (permalink)
it will fit. direct swap. but you need different fender collars (ones from monster)
or you can just use some nuts to lock it in place
'07 GT 1000
'06 M620 D
Some mods.
www.ericchangdesign.com
erichan8757 is offline   Reply With Quote
Old Jan 18th, 2012, 8:43 pm   #3 (permalink)
efiniGTX's Avatar
interesting
I'll have to find out when I take possesion of my 1098s. The carbon front fender would look bad ass!
09 CBR 600RR track slut
07 Ducati Sport Classic
07 Ducati 1098s
efiniGTX is offline   Reply With Quote
Old Jan 19th, 2012, 1:03 am   #4 (permalink)
I'm still undecided, but I'm trying to decide on a simple smooth fender which blends in with the Sport Classic, eliminates the ugly silver fender hanger and adds a bit of protection. I like the DP diversion and stock s4r fenders, however there lines are both sharper than stock and lack protection. The 748 is nice but too square in the back. This 1098 is interesting, I need to see it in person.
Old Jan 19th, 2012, 3:02 pm   #5 (permalink)
Images: 3
When I upgraded to Ohlins forks, my stock front fender with aluminium mounts would not line up with the mounts on the forks. I would have had to splay them wider to get them over the mounts.. so I bought an 848 carbon fender which bolted on perfectly... my results tend to contradict that a 1098/848 fender would be a direct swap....
1098 Front Fender on SC ... Does it Fit?-dsc00016.jpg   1098 Front Fender on SC ... Does it Fit?-dsc00013.jpg
2008 Sport 1000 biposto with Termignoni slip ons and Ducati Performance ECU.
Oberon 29mm clutch slave.
999R Forged Aluminium Marchesinis
749 Rear rotor and caliper.
999 front rotors
Brembo Monobloc Radial Calipers
Ohlins Forks
Rear spacer kit from Fast Frank Racing.
Michelin Pilot Road 2 tyres.
Fleda Tail unit
mikedsilva is offline   Reply With Quote
Old Jan 19th, 2012, 8:21 pm   #6 (permalink)
efiniGTX's Avatar
look closely
the reason why your stock fender didn't fit is because your Ohlin's are radial mount fork bottoms. Stock forks are not radial mount, So the 1098 fender might still work.
07 Ducati 1098s
Old Jan 20th, 2012, 5:18 am   #7 (permalink)
I like the 848 fender in your pictures. The legs are a bit thicker than I prefer, but I guess that lends more protection. The top is smooth and simple.
I'm probably just going to need to try something and see how it looks. I have a basic black SC with 999 rims and brakes. Trying to avoid anything that looks tacky.
Old Jan 20th, 2012, 5:28 am   #8 (permalink)
Images: 3
I wasn't so sure about the 848 fender at first... but if I paint it the same as the tank and leave the centre stripe bare carbon, I think it will look fine.
I don't know how to explain exactly, but no, the stock aluminium mount wont fit the ohlins dimensions. I dont think it is because of the radial mount. It's because the mounting tabs are in a different position to the plastic tabs on the stock forks.
I'll try to upload a photo...
Also, the 848 guard protects the fork legs from stone chips etc...
999 front rotors
Ohlins Forks
Fleda Tail unit
Old Jan 20th, 2012, 5:34 am   #9 (permalink)
Images: 3
here's a pic
1098 Front Fender on SC ... Does it Fit?-dsc06823.jpg   1098 Front Fender on SC ... Does it Fit?-dsc06824.jpg
999 front rotors
Ohlins Forks
Fleda Tail unit
Old Jan 22nd, 2012, 4:41 am   #10 (permalink)
I think mikedsilva might be on to something. I was thinking about the issue with the wheels and brakes from the 999 on the sport classic, how they need to by modified 5mm per side, or have rotors with 5mm less offset... then I remembered that the triple clamps on the Superbikes have a 10mm wider centre.
I think I could get the fender to bolt up to the fender mounts on the sport classic, possibly requiring a longer screw and a few washers per side to take up the 5mm ... but I wonder if the upper fork tubes would be excessively close or rub the fender.
Has anyone put a 1098 fender on a bike without Superbike forks?
Maybe I'm stuck with the 748 or Monster Fenders :/
848/1098/1198 front fender black. $60 shipped. monster front fairing CF, chipped erichan8757 Parts and Accessories 0 Oct 26th, 2010 10:08 pm
08 1098 oem front fender red danrduc Parts and Accessories 4 Aug 9th, 2010 9:00 pm
WTB: Stock 848/1098 Front Fender Da_Bull Parts and Accessories 2 Jun 20th, 2010 5:17 pm
WTB OEM 1098/848 front fender Monstermash Parts and Accessories 1 Dec 27th, 2009 11:43 pm
My 1098 carbon front fender pic Mrgrn Superbikes 2 Feb 11th, 2009 5:49 pm
