Shifting into neutral - Ducati.ms - The Ultimate Ducati Forum
Old Jan 9th, 2012, 3:34 pm   #1 (permalink)
I have been riding my forst sportclassic for a few days now and I find it a little difficult to find neutral. It takes me a couple times when stationary. It is relatively easy when moving. I also read the manual and it says "neutral with automatic return". Here it is:
The gearchange pedal has a central position N, with
automatic return, and two directions of movement:
downwards = push down on the pedal to engage 1st gear
and to shift down. At this point the N warning light on the
instrument panel will go off;
upwards= lift the pedal to engage 2nd gear and then 3rd, 4th,
5th and 6th gears.
Now what does "automatic return" mean and is there an easier way to find the neutral?
Thanks in advance.
07' SportClassic 1000s
04' Harley Sportster 1200
cafesforlife is offline   Reply With Quote
Old Jan 9th, 2012, 6:21 pm   #2 (permalink)
YMRacing's Avatar
Change your clutch fluid, bleed the line. Many times neutral is elusive because the clutch is not fully disengaged.
YMRacing Road Race and Rider Schools
Garry W. Bird, Owner/Mgr
YMRacing is offline   Reply With Quote
Old Jan 9th, 2012, 6:29 pm   #3 (permalink)
Retirement is on the horizon
ncgt1000's Avatar
Images: 3
Originally Posted by cafesforlife View Post
. . . It takes me a couple times when stationary. It is relatively easy when moving. . .
This is typical. Engage neutral just prior to the bike stopping. Or, rock the bike back and forth while searching for neutral. A little movement often helps.
Also, what YMRacing says.
Official Ol' Man Rider & ECM 2012 Survivor.
Over 49 years riding - Over 62 years old!
ncgt1000 is offline   Reply With Quote
Old Jan 9th, 2012, 6:41 pm   #4 (permalink)
good advice from ncgt1000
....automatic return is referring to the shift lever returning to it's central
location after making each shift .
super-single is offline   Reply With Quote
Old Jan 9th, 2012, 6:51 pm   #5 (permalink)
Ah, got it. So is everyone else with these bikes able to find neutral pretty easy?
Old Jan 9th, 2012, 6:55 pm   #6 (permalink)
Clutch fluid does look a little murky. It was changed 1000 miles ago. Does it get dirty so quickly? I have STM Billet clutch slave cylinder. I was told another full service isn't due till another 4000 miles.
Old Jan 9th, 2012, 7:41 pm   #7 (permalink)
Air_Cooled_Nut's Avatar
Images: 2
Yes, it's normal/typical for the fluid to look darkened.
I don't have any issues finding neutral.
Toby
2006 Ducati Sport Classic 1000 monoposto(click me) | '72 VW Squareback, 2007cc, GB 5-speed, rag top | '76 VW Riviera Sundowner 2.0L, family camper | '95 VW Jetta GL 2.0L, Close-ratio tranny, LSD, modified engine
Air_Cooled_Nut is offline   Reply With Quote
Old Jan 9th, 2012, 8:01 pm   #8 (permalink)
Cesare57's Avatar
+1. The clutch fluid gets dark quick. For a while I was changing mine every 500 miles or so, but finally just learned not to sweat it. Once or twice a year is usually sufficient unless you really put on the miles.
Finding neutral is pretty easy on mine, but did involve a little more of a learning curve to get the feel of it than some bikes I've had.
'07 GT1000 - rosso
-CRG bar end mirrors
-Fat Duc O2 Manipulator
-National Cycle F-16 Sportshield
-14T front sprocket
-2nd tank (not the "bling" I'm most proud of)
Cesare57 is offline   Reply With Quote
Old Jan 9th, 2012, 9:47 pm   #9 (permalink)
sportbob's Avatar
+2 ........the clutch hydraulic components move further than the bakes so there is more surface abrasion....I think. Brake fluid is cheap. I flush the brakes once a year and the clutch twice. No problem finding neutral coming to a stop. I occasionally find it between 3d and 4th but only driving hard out of a corner. A bit annoying!!
Durango, Colorado
"Old dog learns new trick"
Currently-'07 1000s ...some mods.....
Previously-
'80 Ducati 900ss, Bevel
Benelli 750 sei
Ducati 860 GT
Norton 850 Commando
60's Triumph Daytona
71 Yamaha 650 (OUCH!)
sportbob is offline   Reply With Quote
Old Jan 10th, 2012, 8:38 am   #10 (permalink)
YMRacing's Avatar
Don't just change the fluid. Actively bleed it like you would brakes. You will not feel any real change at the lever, you'll just be looking to make sure all air bubbles are out of the system. Pay attention to the fluid level in that itty bitty reservoir!
1-2-Neutral shifting issue drdave39 Multistrada 7 Aug 15th, 2011 9:46 am
Engine stalls when shifting from neutral 2005 749D actionong Superbikes 5 Jul 11th, 2011 1:04 pm
shifting into neutral between 4th and 5th kensteele Supersport 7 Sep 24th, 2008 2:33 pm
GP shifting (reverse shifting) with stock linkage? DanTheMan Superbikes 27 Oct 30th, 2007 4:28 am
Shifting whoas :999R False Neutral MuddyDuckati Superbikes 13 Aug 9th, 2007 10:09 am
