The engine update and frame editions to my Cafe.. - Ducati.ms - The Ultimate Ducati Forum
Old Jan 9th, 2012, 8:26 am   #1 (permalink)
BlackKat's Avatar
Well I haven't had anything toooo exciting to update, but a few of my pals here have given me some stink about some new pics..
I'll start by saying I keep forgetting how many pieces a Ducati can be broken down into...
So I finally split the cases last week..... it was UGLY!
So, thank goodness I had a magnetic drain plug, Otherwise all this would be floating around inside my engine.
Oh wait..it reached its capacity and all that STILL was floating around my engine.
Here are the bearings that I found...the other is all the shrapnel throughout.
So glad I ordered a new crank, ALL bearings, rods and pistons...
After 3 hours in the parts washer I was able to finally get all the crap out of the cases. Reassembly will start next week.
NOW... The fun stuff. As I mentioned previously, I was going to repowder coat the frame. In having her completely taken apart, I am also going to do the swing arm satin black to match the Ohlins. Obviously since its a Cafe inspired project, I took the time to modify the frame a bit to fit the part.
First, passenger pegs, exhaust bracket and side cover brackets have been shaved. Easy stuff, right?
But the big thing I wanted was the retro style hoop for the rear of the bike and some simple mounts for turn signals. A good pal of mine is quite the fab guy and he offered to help me out.
An early on "resting in place" mock up.
His work is done. This is a pic of all the welds and he replaced my plastic liner with a nice steel one...Yes, that does say "THUG LIFE"... strangely ironic seeing how cracker white I am. I feel its not necessary to show the picture on the bottom of the tray... when 2 good buddys have 4 good beers and a sharpie while I'm not around, bad things happen. hahaha
The welds are wonderful and need very little clean up before priming and paint.The modifications were designed for all wiring to be inside the frame. The turn signal mounts are threaded for an M8 internally so I can run just about anything I want to put there. The idea is something small that won't be wider than the outside edge of the seat.
The final decision on the color of the frame is the champagne color used on the 1098R/S frames. I really wanted RED, but someone made a good point. It would look like a stock 695 Monster. All other color options would either look like crap with the painted tank and tail or would clash horribly with the Ohlins.
She's getting there. I'm finally starting to see light at the end of the tunnel. We really have no idea what caused the bearing failure. All oil ports are clean. Oil pump is fine. The only thing we have right now is that it was an existing problem when I bought the bike and then when it went on the dyno, That was enough to put her over the edge.
BlackKat is offline   Reply With Quote
Old Jan 9th, 2012, 10:56 am   #2 (permalink)
It looks like you're making great progress. Good thing you took a peek inside that motor!
JackN is online now   Reply With Quote
Old Jan 9th, 2012, 11:04 am   #3 (permalink)
looking great! what tail cover are you using? about to tear mine apart and looking for inspiration...
shrews is offline   Reply With Quote
Old Jan 9th, 2012, 11:34 am   #4 (permalink)
GTRossi's Avatar
nice!
...ask me about huggers
'06 S1K - with a few mods...
Carbie DS1000 cafe project in progress
GTRossi is offline   Reply With Quote
Old Jan 9th, 2012, 1:54 pm   #5 (permalink)
Riderjeff's Avatar
I love the tail treatment, especially the retro-correct loop on the frame. Very nice work, make sure she's ready for spring! And post pics!
Riderjeff is offline   Reply With Quote
Old Jan 9th, 2012, 3:40 pm   #6 (permalink)
BlackKat's Avatar
Thanks guys! The tail section is a rolled aluminum one I had made. Just trying to keep her different.
Old Jan 10th, 2012, 8:59 am   #7 (permalink)
DucBeak's Avatar
Thanks for sharing. Now back to work!
DucBeak is offline   Reply With Quote
Old Jan 10th, 2012, 1:52 pm   #8 (permalink)
Incredible! Looking forward to hopefully seeing that thing in person one day man!
Adam
adamld83 is offline   Reply With Quote
Old Jan 10th, 2012, 7:57 pm   #9 (permalink)
BlackKat's Avatar
Adam
Well, certainly she won't be together by then, but we will actually have an 1199 in the store on the 25th of this month. Its a Wednesday and we'll be having a gathering to celebrate it...Might be worth the 2 hours north for ya. I think we'll be the FIRST store in North America to have one on the floor.
Accept my invitation! C'mon up Adam!
Kev
Old Jan 11th, 2012, 12:07 pm   #10 (permalink)
Kev
Really ?! Heck I just might. Depends on work and school though. PM sent...
860 GT/900ss cambelt engine, cafe racer Desmohog Vintage 1 Jul 20th, 2011 1:09 pm
2004 Cafe Racer 999s engine 749s chassis $7200 TheRC30Guy Bikes 13 May 10th, 2011 11:44 am
Cracked engine case update ak57 HyperMotard 4 Sep 16th, 2008 2:27 pm
Frame sliders, causes frame and/or engine case damages?? 08hyper HyperMotard 4 Jan 6th, 2008 8:53 pm
