Name these metal bits (aka, how worried should I be?) - Ducati.ms - The Ultimate Ducati Forum
Old Jan 8th, 2012, 9:07 pm   #1 (permalink)
Cunning Linguist
greggers's Avatar
Decided to change the oil on my new (to me) Sport 1000 today. The oil didn't look too dirty in the sight but I wanted to know for sure that it was good stuff in there. When I took the drain plug out, there was a small amount of shavings/gunk on the magnet, which I was expecting, but then there were also 3 small metal chunks which I'm not so sure about. Two of them are about 4mm long and the other is about 2mm, all measuring about 1mm in the other directions. They all have small grooves running long ways on one face. It looks like all the pieces came from the same thing. I tried to take a picture as best I could, they are pretty small and I don't have a great camera right now.
Hoping one of you gurus can ID what they might be.
Side note, anyone have any tips for getting the oil filter off without buying some expensive specific tool? I got a K&N one to swap on so after this change I'll hopefully be able to make due with a socket, so I'd rather not spend $20 or $30 on a tool I'll just use this once. I was hoping to use one of those rubber strapped tools for loosening pipes which I already have, but there was no good way to get leverage, at least without removing the entire header, so I just left the filter that's on there in place for now.
2008 Ducati Sport 1000 Biposto
2011 Royal Enfield G5
greggers is offline   Reply With Quote
Old Jan 8th, 2012, 9:27 pm   #2 (permalink)
sportbob's Avatar
Disturbing to be sure. they look like gear teeth but I couldn't say from where exactly. As to the the filter, the tool is $10-$15 from Pro Italia and the OE filters aren't expensive either. Especially considering you'll only use 1 or 2 a year. The K&N has that "nut" sticking down another inch just begging for a rock! One mans opinion.........
Durango, Colorado
"Old dog learns new trick"
Currently-'07 1000s ...some mods.....
Previously-
'80 Ducati 900ss, Bevel
Benelli 750 sei
Ducati 860 GT
Norton 850 Commando
60's Triumph Daytona
71 Yamaha 650 (OUCH!)
sportbob is offline   Reply With Quote
Old Jan 8th, 2012, 11:17 pm   #3 (permalink)
some cheaper strap wrench is about 7 bucks.
or just get the biggest groove joint plier and destroy the old filter
oil filter plier is handy but if you are using k&n from now on , you'd only need that tool once. which is a waste but certainly good to have.
e
'07 GT 1000
'06 M620 D
Some mods.
www.ericchangdesign.com
erichan8757 is offline   Reply With Quote
Old Jan 9th, 2012, 12:08 am   #4 (permalink)
Are those pieces straight or curved?
Old Jan 9th, 2012, 12:26 am   #5 (permalink)
Cunning Linguist
greggers's Avatar
They look pretty straight on all sides
Old Jan 9th, 2012, 5:39 am   #6 (permalink)
Images: 3
on another bike, I remember piercing the filter with an old screwdriver and using that to unscrew it....
As for the metal bits, think of how much weight you are saving..
Did you happen to remove the oil screen too??
2008 Sport 1000 biposto with Termignoni slip ons and Ducati Performance ECU.
Oberon 29mm clutch slave.
999R Forged Aluminium Marchesinis
749 Rear rotor and caliper.
999 front rotors
Brembo Monobloc Radial Calipers
Ohlins Forks
Rear spacer kit from Fast Frank Racing.
Michelin Pilot Road 2 tyres.
Fleda Tail unit
mikedsilva is offline   Reply With Quote
Old Jan 9th, 2012, 7:12 am   #7 (permalink)
CU3RVO's Avatar
Images: 8
They do look like teeth from a gear.... Hmm, I would recommend getting it checked... I would crap myself if I saw those teeth in my drain plug...
CU3RVO
2006 Monoposto, Yellow...
When asking a Ducati owner if he had any problems with his bike, his response was:
"The only problem I've had is attractive women divesting themselves of their clothing and rubbing their naughty bits on my leg while they lick the gas tank. Makes it hard to pull away from a red light,...... sometimes."
CU3RVO is online now   Reply With Quote
Old Jan 9th, 2012, 9:33 am   #8 (permalink)
Cunning Linguist
greggers's Avatar
No I didn't but maybe I should have? As I understand it you need a deep socket to pull the cover on that without damaging the sensor, and it has another crush washer to refresh, neither of which I had so I left it alone.
Old Jan 9th, 2012, 9:55 am   #9 (permalink)
Wiskey Tango Foxtrot OVER's Avatar
Is the starter working well ? they look to me like the spraig gear bits ?
I took the "Short bus" to school because they told me it was faster.......What did they tell you ?
Torque.....it's what they feed you till the horsepower arrives !
Wiskey Tango Foxtrot OVER is offline   Reply With Quote
Old Jan 9th, 2012, 10:19 am   #10 (permalink)
Cunning Linguist
greggers's Avatar
I haven't noticed any issues with starting, it usually takes a few (2-4 depending on how cold it is out) "cycles" before the engine starts, but never any failures.
Rossi: We are quite worried SpeedLimit? Road Racing 305 Aug 31st, 2011 7:06 pm
QD exhaust-now I'm a little worried mmcannava Multistrada 3 Apr 9th, 2011 10:57 am
I'm getting worried.. All this talk about reliability!! Duchead Sport Classic 23 Apr 15th, 2010 9:16 am
Coolant in oil, should I be worried? phat_dub Superbikes 8 Sep 2nd, 2008 3:22 pm
A little worried?Purchase? billas749s Ducati Motorcycle Chat 19 May 2nd, 2007 7:18 am
