Mayo Condensation in Oil? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 7th, 2012, 3:12 pm   #1 (permalink)
In the last 3 weeks I noticed the window on my oil case getting more cloudy. Passed it off as just condensation or something of that like and it usually cleared up by rides end. But today I go out and check the the oil again and really take a long look in the window to notice it's seriously cloudy. I pop the plug and find more of the gunk inside. I've done a couple of internet searches and responses indicate it's mainly due to a lot of short Winter runs. Is it indicative of any other issue and is it still safe to drive? On another forum someone said to check and make sure the crankcase breather hose is not obstructed.
Mayo Condensation in Oil?-cimg2645.jpg   Mayo Condensation in Oil?-cimg2644.jpg
2007 GT1000 Red
bpreynolds is offline   Reply With Quote
Old Jan 7th, 2012, 3:19 pm   #2 (permalink)
zvez's Avatar
short rides seem to be the main culprit, I only experienced on my 996 which I didn't ride much, all my others ducs it was no issue as they're ridden a lot.
Clean the gunk off, change the oil, and see if you can take it out on regular longer rides.
Chris
12 1199 Panigale......May 26th.....May 30th?????????
10 Ducati Streetfighter
2011 Aprilia RSV4-R APRC
05 Goldwing
zvez is online now   Reply With Quote
Old Jan 7th, 2012, 3:23 pm   #3 (permalink)
Thanks much for the response. I ride the bike around 33 miles roundtrip 4-5 days a week. And for much of that ride the bike is in the 4-7k rpm range. Engine temp gets up to about 135-150 in the Kentucky Winter. But I guess it's still not getting burned off.
2007 GT1000 Red
Old Jan 7th, 2012, 4:55 pm   #4 (permalink)
jrt
I'm surprised. I would have thought that the bike would warm up more than that. Is it very humid in Kentucky this time of year?
I ride Guzzi's and this a real common issue for them. Zvez's advice if fine, I don't have much to add except maybe ride faster ?
'03 ST4s
Literally a ton of Moto Guzzis
jrt is offline   Reply With Quote
Old Jan 7th, 2012, 6:53 pm   #5 (permalink)
Brian,that scares the he'll out of me,I've only seen things like that in a water cooled engine when it blows a head gasket,I don't know what's going on there.I would get that bike hot and change that shit out right away!
mouse action is offline   Reply With Quote
Old Jan 7th, 2012, 7:01 pm   #6 (permalink)
NExE's Avatar
I get the white foam after a fresh oil change. My commute it 12 miles (one way). So I never get the temp above 205 summer/190 winter.
I have learned to go for a good long ride after I change the oil to burn off the condensation and don't have a problem after that.
Sport 1000 Biposto:
Paul Smith Fork Guard & Oil Cooler Guard, GTRossi Touring Hugger, Fat Duc O2, Fastbike Fork Frame Swingarm Sliders, Desmo Case Saver, Gerhart Gauge Lowering Bracket, Kuan Steering Damper, AG Hammer Fork Brace, Dobeck EJK, caCW Air Filters, TPO Idle Air & Crankcase Breather, Aella EVO.
The Past:
2004 BMW R1100S BoxerCup Prep
2003 BMW R1150R
1996 BMW R1100GS
NExE is online now   Reply With Quote
Old Jan 7th, 2012, 7:04 pm   #7 (permalink)
NExE's Avatar
White residue in oil sight glass?
A good thread to read.
Sport 1000 Biposto:
The Past:
2003 BMW R1150R
1996 BMW R1100GS
Old Jan 8th, 2012, 1:01 am   #8 (permalink)
I would change the oil.
Old Jan 8th, 2012, 2:49 am   #9 (permalink)
Cunning Linguist
greggers's Avatar
I saw something similar when I got my bike not too long ago, I started reading around on bike forums and apparently it could mean a leak in a gasket if it just won't go away. Mine did after some longer rides, and I think if you aren't getting the engine above 150 it's tough to burn that off. Some low speed/high rev riding in traffic for 30 min to an hour should get the engine nice and hot and hopefully burn it off
2008 Ducati Sport 1000 Biposto
2011 Royal Enfield G5
greggers is offline   Reply With Quote
Old Jan 8th, 2012, 3:28 am   #10 (permalink)
+1 on changing the oil, that looks pretty rank to be honest... an oil change wont hurt the engine anyways!
** Remove your oil filler cap when you get back after a ride, this will let the crankcase vent & help the moisture & other gak escape. Put the cap in a clean old aerosol cap on top of your bikes gas cap so you don't forget to replace it.**
Any sign of water droplets in the engine? This would indicate a blown head gasket or similar?
748 oil window condensation? aero748 Superbikes 14 May 21st, 2010 4:06 pm
Oil and mayo don't mix. Mister E Supersport 13 Jun 29th, 2009 6:47 pm
condensation in headlights shamrock Ducati Motorcycle Chat 0 Nov 27th, 2008 1:56 pm
Got Condensation in headlight(s) wesleymantooth Superbikes 2 Sep 5th, 2006 9:15 am
condensation in oil ? st4spokane Sport Touring 6 Mar 22nd, 2006 8:00 am
