Oil change question - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGear
Old Jan 1st, 2012, 6:01 pm   #1 (permalink)
rideserotta's Avatar
Oil change question
I just changes the oil on my 2007 GT1000 (5600 miles)and got it a little too full. The oil goes to the top of the circle not between the two lines on the site glass. How big of a deal is this? Should I drain a little out or am I ok as is?
2007 GT1000
History:
2005 Monster 620
2000 Suzuki Katana
rideserotta is offline   Reply With Quote
Old Jan 1st, 2012, 6:31 pm   #2 (permalink)
NExE's Avatar
Oil Level
Too high = Too much crankcase pressure.
Sport 1000 Biposto:
Paul Smith Fork Guard & Oil Cooler Guard, GTRossi Touring Hugger, Fat Duc O2, Fastbike Fork Frame Swingarm Sliders, Desmo Case Saver, Gerhart Gauge Lowering Bracket, Kuan Steering Damper, AG Hammer Fork Brace, Dobeck EJK, caCW Air Filters, TPO Idle Air & Crankcase Breather, Aella EVO.
The Past:
2004 BMW R1100S BoxerCup Prep
2003 BMW R1150R
1996 BMW R1100GS
NExE is online now   Reply With Quote
Old Jan 1st, 2012, 6:37 pm   #3 (permalink)
YMRacing's Avatar
Remove a bit. Bring it down to below the full. Better off a little low than a little too much. Hard on seals, blow by, etc.
Next time, fill the oil looking at the window, fill to the middle of the hi/low. Start the bike to fill the oil filter and cooler. Check it and add to 1/2 or 2/3 between hi/low.
If you run the bike at track days or are a really quick guy that runs at hi-rpms. 6-8k 1/2 between hi/low is plenty.
I'm sure that someone will chime in with the reasons...big pump, big pistons, lots of oil messing around in the crankcase.
YMRacing Road Race and Rider Schools
Garry W. Bird, Owner/Mgr
YMRacing is offline   Reply With Quote
Old Jan 1st, 2012, 7:25 pm   #4 (permalink)
Thanks. This may be a dumb question but oil should be checked with the engine NOT running, right?
2007 GT1000
History:
2005 Monster 620
2000 Suzuki Katana
Old Jan 1st, 2012, 7:42 pm   #5 (permalink)
Engine cold and not running. Did you start the motor after filling? If not , try starting it to fill the oil filter. The level may be OK.
herby22 is offline   Reply With Quote
Old Jan 2nd, 2012, 1:40 am   #6 (permalink)
Run it for a couple of minutes, then leave it for an hour to settle. If it is still too high, siphon some out with a piece of battery vent hose.
Old Jan 2nd, 2012, 5:10 am   #7 (permalink)
RudolphHart's Avatar
Just a thought: Did you change the oil/fill up with the bike on the side stand?
If the bike was leaning over when you filled up then it would have given a misleading sight level in the inspection window, once the bike is upright the true (overfilled) level would be revealed.
Some people use paddock stands during such tasks. I stick a block of wood under the sidestand to hold the bike pretty much upright when I am doing a quick oil level check.
RudolphHart is online now   Reply With Quote
Old Jan 2nd, 2012, 6:01 am   #8 (permalink)
Oil level
Really not much of a concern, if you can see the level in the window.
As the crankcase is vented to atmospheric pressure via the breather on the top of the crankcase, overfilling the crankcase will not result in higher crankcase pressures, or damage to seals, etc..
The problem with overfilling engine crankcases occurs when the level of the oil is so high that the crankshaft or big end of the connecting rod strikes the oil pooled in the bottom of the engine. If the rotating parts can constantly strike pooled oil, air can become entrained in the oil and as air is compressible, frothy oil will enter the lubrication system and can result in starved bearings and component failures. Raising the crankcase level to a point where frothing can occur will take more than the few cc's of oil you have inadvertently poured in.
The rationale for making sure the operator can see the level in the window is to ensure the level is not too low or too high. If you can see the oil level in the window, you are not at risk.
A good practice when changing oil is to fill the new filter with oil before spinning the filter onto the engine. This significantly reduces the time interval before the lubrication system develops full pressure.
On some bikes that take 15 or 20 seconds to develop oil pressure after an oil change, BMW boxers are in this category, I favor pulling the connectors off the fuel injectors and cranking the engine till the oil pressure light is extinguished. However, if one decides to pull the spark plugs and then crank an engine, always ground the high tension wires with dummy plugs secured to the engine as not to damage the ignition system.
Ciao,
Dick
racasey is offline   Reply With Quote
Old Jan 2nd, 2012, 6:10 am   #9 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
One way to remove some oil is to remove and drain the oil filter, then reinstall. I have done this when needed, don't ask!
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
va duc is online now   Reply With Quote
Old Jan 2nd, 2012, 6:17 am   #10 (permalink)
MTScott2's Avatar
Images: 5
If your bike takes less than the gallon of oil to fill , pour some out of the Gallon container into a clean container so you don't over fill.
then fill ,start up let it circulate for a bit then check it and add a little at a time...
I have loosened the DRAIN plug when oil has cooled down and let some drain, you don't have to pull the plug just loosen and let it dribble out slowly ...
Pay attention next time
2011 Red Multistrada Touring
MTScott2 is online now   Reply With Quote
Oil change question... jquattro Sport Classic 14 Dec 19th, 2008 9:53 am
Oil change question jquattro Sport Classic 13 Oct 15th, 2007 9:24 am
Question regarding oil change Bizarre996 Superbikes 8 Aug 28th, 2007 5:46 am
Oil change question -- help please? gregcm Sport Touring 14 Aug 27th, 2007 8:07 pm
Oil change question PookaDog Sport Touring 3 Aug 25th, 2006 7:51 am
