Possable Battery problems??? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!SportbikeTrackGearMotorcycle.comGraves Motorsports
SportbikeTrackGear
Old Dec 31st, 2011, 7:23 pm   #1 (permalink)
nevb's Avatar
I went for a short ride this morning and went to restart the bike (after 1/2 an hour sitting) the instruments went through their cycle as pre normal. but when i pressed the starter button the soliniod just clicked. the strater motor did not work... I got a friend to pick the bike and myself up and after getting the bike home i disconnected the big positive wire from the starter motor and put my multimeter lead onto the wire and the other lead onto the negitive of the battery.. I pressed the starter button and only got 12.00 volts DC. The battery is 12.4v off load (removed from the bike) Would i be right in assuming that the battery is fucked.
Any advice would be appreaciated
cheers
Nev
nevb is online now   Reply With Quote
Old Dec 31st, 2011, 8:54 pm   #2 (permalink)
cheers
Nev
is your battery old?
it sounds really familiar to me since it was exactly happened to me when my battery died on my last year.
Battery should remain 12.8-13 when key's off
and when bike is on, should stays at 12.2 ish.
12v on OFF position is def low and may possibly be an dying battery.
E
'07 GT 1000
'06 M620 D
Some mods.
www.ericchangdesign.com
erichan8757 is offline   Reply With Quote
Old Dec 31st, 2011, 9:27 pm   #3 (permalink)
nevb's Avatar
Yah the battery is original 2006.. i have given the battery a quick charge and still no go... 12.4v no load and 11.8v when trying to start..
does anyone know what the starter motor resistance is. I.e from the positive terminal on the starter to ground (bike frame) I get 1.3 ohms does this sound wright.
cheers
Nev
Old Dec 31st, 2011, 9:34 pm   #4 (permalink)
cheers
Nev
I've doubted my starter motor as you are now, but after consulted with a mechanic, what I learned was that the starter motor is one tough horse to kill. You'll have to completely take it apart to make it stop working. it's a japanese brand, makes quality stuff.
you should have 12.8 at normal condition. Your battery is not charging as it seems to me. it will just turning , turning and turning trying to catch that current but your battery amp is just not high enough. Try to charge it till 12.8 and if the battery can't hold 12.6 ( to say the least) it has some life issue.
E
'07 GT 1000
'06 M620 D
Some mods.
Old Jan 1st, 2012, 3:04 am   #5 (permalink)
nevb's Avatar
Hi
The starter motor is not turning at all. I have prove that the power gets too the starter motor and that the soliod works, but the starter motor just sits there. I hope its just a buggered battery.
cheers
Nev
Old Jan 1st, 2012, 7:05 am   #6 (permalink)
Kookz's Avatar
Sounds like the battery is shot but I'd bet it's the regulator/rectifier that's the cause of the troubles and a new battery will only temporarily get the bike running.
Kookz is offline   Reply With Quote
Old Jan 1st, 2012, 7:25 am   #7 (permalink)
MTScott2's Avatar
Images: 5
I wouldn't complain about a battery getting 6 years out of it , yeah some get more ,
check all the connections, clean them up , and keep an eye on things with thenew battery , go from there if all is ok ...
2011 Red Multistrada Touring
MTScott2 is online now   Reply With Quote
Old Jan 1st, 2012, 7:43 am   #8 (permalink)
Images: 3
sounds like the battery... 5 years is good life out of one.
My bike is an 08 model... so I've just ordered 8 A123 cells to make up my own LiFe pack... figured I may as well do it now, before I get a dud battery problem.
2008 Sport 1000 biposto with Termignoni slip ons and Ducati Performance ECU.
Oberon 29mm clutch slave.
999R Forged Aluminium Marchesinis
749 Rear rotor and caliper.
999 front rotors
Brembo Monobloc Radial Calipers
Ohlins Forks
Rear spacer kit from Fast Frank Racing.
Michelin Pilot Road 2 tyres.
Fleda Tail unit
mikedsilva is offline   Reply With Quote
Old Jan 1st, 2012, 10:43 am   #9 (permalink)
magus's Avatar
Now you have a great opportunity to switch to a LiFePo battery and upgrade your reg/rec (location and unit).
That mod was one of the best I have ever done and has produced great peace of mind.
'06 Ducati Sport Classic 1000
'11 Kawasaki 1000SX
magus is offline   Reply With Quote
Old Jan 1st, 2012, 11:58 am   #10 (permalink)
nevb's Avatar
certanly no complants about the life i have had out of this battery... I will get a new one today and switch to a LiFePo battery and upgrade my reg/rec as Mick and Magnus have segested.
I'll let you know how it goes..
cheers
Nev
Battery questions/problems/options. TiltTheHorizon Sport Classic 26 Nov 11th, 2011 11:02 am
Battery Problems with My 999R lastblast Superbikes 36 Aug 10th, 2011 12:32 am
New Battery But still starting problems agardin10 Sport Touring 17 Jul 30th, 2011 8:33 pm
My battery problems were not battery problems DeBenGuzzi Sport Touring 3 Apr 3rd, 2011 11:08 am
Battery Problems sols Monster 13 Apr 1st, 2006 1:34 pm
