Dec 22nd, 2011, 4:29 pm
SC died on me; a little help for diagnostic?
I have had my 2007 S1000 for three years without a single problem.
A little over 10,000 miles on the clock now.
this morning I had a hard time getting it to start, but it did, after 2 minutes of insisting.
I was riding along for less than 5 mn when the engine just died while riding along at 45mph. I tried to restart to no avail.
I have a new-ish Shorei battery. It cranks like a MoFo, so no problem there.
I seems to have gas coming through, as it ends up smelling like gas out of the mufflers.
I am guessing that I have no spark, no ignition.
Opinions? Action to take if I want to replace something and save on labor costs?
Dec 22nd, 2011, 6:23 pm
Throwing parts at something is never a good solution. I helped a friend replace the fuel pump on his Supra 3 times before I made him buy a service manual. 20 min later we had diagnosed the problem: the distributor
Step 1: don't assume battery and voltage regulator are working
Step 2: check them
Step 3: verify that you have no spark, and check all plugs
Let us know what you find
Dec 22nd, 2011, 6:34 pm
I'm going with Voltage regulator... had all the same symptoms when mine quit.
I put an 1198 Voltage regulator in, works great!
Dec 22nd, 2011, 9:02 pm
Thank man, I hope it's something like that.
I checked all fuses and the regulator's fuse as well. All is green on that end. No frayed wires either.
Dec 22nd, 2011, 9:56 pm
Are you sure it's not the faulty fuel line? When my regulator failed the bike acted very weird. The only time it simply died without much of a quip was the fuel line...
good luck!
07' Sport Classic Sport1000 Biposto, Black
Dec 22nd, 2011, 10:23 pm
Fuel seems to be getting into the cylinders because I can smell unburned gas being vented out of the pipes. I seem to be missing a spark then.
I will pull a plug tomorrow and run the starter while grounding the plug and check for sparks...
good luck!
Dec 23rd, 2011, 3:06 am
Location: Latitude: N49.13.46', Longitude:W123.05'.13, 01 966 Monster, 06 SC Monoposto, 07 SC BiPosto, 73 CB 750 Honda, 75 Harley Shovelhead
If you are gonna check for spark...use a spare plug and leave the plugs in ...atomized fuel can be ignited when blown out the plug hole..
Stephano
