View Poll Results: Didja'?
Opt Out Using Izakk's Form
2 |
13.33% |
Opt Out with your own letter
1 |
6.67% |
Nothing
12 |
80.00% |
Dec 22nd, 2011, 10:36 am
Class Action Poll
Since the fuel tank class action comment period is over early next week just wondered what you might have done.
If you used Izaak's form letter, you opted out as well as objected to the settlement.
I hope that if you opted out on your own that you sent in an objection to the settlement as well.
If you did nothing, well you did nothing.
YMRacing Road Race and Rider Schools
Garry W. Bird, Owner/Mgr
Dec 22nd, 2011, 10:51 am
What kind of poll is this and what do you guys think opting out will gain you?
I hope you bone heads didn't opt out but protested the settlement. that was our only possible path for a realistic settlement.
If you opt out and the settlement is accepted you will retain your right to sue but you know you wont and you'll still be bound be the terms of the settlement.
All of us will have to live with the consequences of this decision no matter if you opt out or not.
The poll needs a choice for objecting to the settlement.
11 Multistrada 1200
10 Streetfighter S
89 GB500
73 Duc GT750
74 Duc 750 sport special
66 Duc 250 NC racer
65 Norton Atlas cafe'
Dec 22nd, 2011, 11:15 am
Good points,
If you used Izaak's form letter you opted out and you objected to the settlement.
I suspected...I know....that if you opted out with your own letter you had also objected.
If you did nothing, you accepted inclusion into the class action.
You're right the wording is not what it should be. I'll see what I can do, delete it and start over would be the best, not sure if or how to do that though.
Dec 22nd, 2011, 11:28 am
I did nothing, because I didn't know about it. What's the deal with the class action, and why would one object to it? Is it too late to get in on it, assuming I don't object?
Dec 22nd, 2011, 12:16 pm
Originally Posted by YMRacing
Good points,
I'm sorry but it clearly states that if you opt out of the suit you are not allowed to object to the settlement.
You can only state your objections if you remain a class member. If you opted out your objection will not be considered in the case.
11 Multistrada 1200
10 Streetfighter S
89 GB500
73 Duc GT750
66 Duc 250 NC racer
Dec 22nd, 2011, 12:19 pm
I remained in the class but objected to the settlement with protestation letters. Flynbulldog is correct. Howard Johnson is correct. The sheriff is a near.
"kick the tires, light the fires!"
2007 DB6 2006 Mutleystrada 620 (1/5 Ton of Fun, 2nd tank)
Contact Jared Schoenly [jschoenly@gmail.com] for custom machining work. He's a friend in PA.
Dec 22nd, 2011, 12:22 pm
I didn't opt out because I don't think there will be enough opt-outers left to do another class action suit at a later date.
Ducadent
'07 biposto SC1K
Jersey City, NJ
black paint................no stripe, silver logo
shimmed forks...........kuan damper bracket
pazzo levers..............sd121 ohlins damper
shimmed tank............oberon 75mm fold out bar end mirrors
cannisterectomy........race ECU
rizoma reservoirs........1" headlamp drop shim
dpcars tail chop.........speedymoto frame sliders
cycle cat risers...........gerhart lay down gauge brackets
2:2 termis.................traxxion dynamics AK-20 fork inserts
Dec 22nd, 2011, 1:49 pm
Please put up a correct poll. I'm clearly not competent, nor capable. Thanks. If I knew how, I'd delete this poll and thread.
