S/M Oil Causing Engine Wear - Ducati.ms - The Ultimate Ducati Forum
Old Dec 16th, 2011, 12:26 pm   #1 (permalink)
Has anyone got any thoughts on synthetic oil which is rated at SAE SL/SM not providing adequate lubrication? Modern synths such as Shell Advance Ultra have greatly reduced levels of ZDDP (basically an additive containing zinc and phosphate) which has resulted in heavy wear of cams and rockers in classic engines. Now I know that our Ducatis are not classics (yet) but the cams and rockers are basically the same as Ducatis of old. The level of ZDDP was reduced in these oils to stop them contaminating the catalytic converter, so would we be better off using an oil with higher levels of ZDDP rated at SG or SJ?
Old Dec 16th, 2011, 1:00 pm   #2 (permalink)
poolagent's Avatar
I would say that modern oils are perfectly suited for our bikes…
As long as they have the correct specification…
IT IS NEVER TOO LATE FOR A HAPPY CHILDHOOD…
2007 Sport 1000 biposto
1978 Moto Guzzi LeMans Cafe Racer
http://thebikeshed.cc/2011/11/14/christians-lemans/
poolagent is offline   Reply With Quote
Old Dec 16th, 2011, 2:01 pm   #3 (permalink)
dietrichpfeifer's Avatar
Well, I've used just about every oil under the sun in the last 60,000 miles including semi-synthetic and blends of multiple brands, with no noticeable wear so my suggestion would be to not worry too much about it. Use Moto specific oil, change it every several thousand miles, and ride and ride...
dietrichpfeifer is offline   Reply With Quote
Old Dec 16th, 2011, 2:27 pm   #4 (permalink)
olducker's Avatar
I suggest that you use a motorcycle specific oil in air-cooled, wet-clutch engines. However, some folks run automotive oils and report good results. I tend to err on the side of caution and only run a full synthetic (group IV) oil with a rating of API SG, SH/CF, JASO MA.
Ken
'07 GT 1000 (Gray)
'74 750 GT
olducker is offline   Reply With Quote
Old Dec 16th, 2011, 7:03 pm   #5 (permalink)
Riderjeff's Avatar
OIL THREAD! YEA!!
Red Line full synthetic motorcycle oil 10-40. Period.
Riderjeff is offline   Reply With Quote
Old Dec 16th, 2011, 7:59 pm   #6 (permalink)
Shell Rotella-T full synthetic, around $16-$17 a gallon at Wally World.
When I was fast,
motorcycles were slow.
Now motorcycles are fast,
and I'm slow.
- Melvin "Swede" Dunlap, 1966
Cafe racers are built,
not bought.
The older I get,
the faster I was.
1duckyboy is offline   Reply With Quote
Old Dec 17th, 2011, 1:22 am   #7 (permalink)
$16-$17 a gallon!! you guys don't know how lucky you are! The cheapest synthetic over here is $60 a gallon and the dearest is around $150.
Old Dec 17th, 2011, 6:06 am   #8 (permalink)
$150 a gallon?? Want to by some oil? No really, would it work to buy the oil here and ship it across the pond?
mouse action is offline   Reply With Quote
Old Dec 17th, 2011, 8:06 am   #9 (permalink)
poolagent's Avatar
UK oil source
Engine Oil, Motor Oil, Gear Oil, Car Oil, Motorbike Oil from oilman at Opie Oils
4 stroke engine oils[EntityIDs=@(61)@*ava=0]
Old Dec 17th, 2011, 12:39 pm   #10 (permalink)
RudolphHart's Avatar
£29.99 for 4 litres:
Shell Motorcycle Advance Ultra 10W-40 Engine Oil - 4 Litres - Autosessive - The Online Store for car lovers
That's around $46-$47 at current rates.
RudolphHart is online now   Reply With Quote
Does anyone wear.... bruce19 Apparel and Accessory Chat 10 May 28th, 2010 6:03 am
TPO kit causing oil spray??? Dark749 Superbikes 24 May 18th, 2009 8:59 am
Pressure plate causing slippage?? STICKER HyperMotard 6 Jun 11th, 2008 6:07 pm
What's causing the cupping? brianmdavis Ducati Motorcycle Chat 11 Sep 27th, 2006 2:45 pm
Bridgestone Battleaxe causing head shake OntarioSV Sport Touring 7 Aug 30th, 2006 10:55 pm
