Originally Posted by arbakken
Really? I'm nearly positive that's not true. The cowl on a mono is not (easily) removable, whereas the cowl on the biposto is able to be taken off and has a seat underneath.
I took my Biposto cowl, removed the padded bit (2 easy screws) and fit it on a mono comfort seat without any issues whatsoever.
How do you remove a mono cowl? Is it 4 little screws under the seat? If so, that's the same as the biposto and there should be no issues with fitment.
That said, perhaps a mono cowl doesn't have the screw fitments inside to mount the extra padded bit, which would the mean that it may not fit on a BIPOSTO perfectly since the gap between the cowl and the seat wouldn't be covered by the extra padded bit.
makes sense?
But for the sake of our friend's question: All 2007 cowls (from a biposto I assume) will fit on all 2006 seats (monos), since I did it.
