SC 06 broke down ... - Ducati.ms - The Ultimate Ducati Forum
Old Dec 11th, 2011, 4:07 pm   #1 (permalink)
porkiespeedster's Avatar
Hi there ,
I have a 06 sport classic with 1200 miles on the clock .
Put the bike away 3 weeks ago , connected it to the battery charger ( battery was changed this year ) , and tried to start it today .
Had the gauges coming on as normal , and when pushing the starter button nothing happened ; only the yellow engine light came on and I just hear a loud "click" . Bike is in neutral ; lights are working fine .
I read about the voltage regulator problems . Is this related to this ?
I have never had a problem with the bike before and it was running fine until the last minute I put it in the garage .
Thanks for your replies guys
Cheers , Harald
Life is what you make of it . Do it while you can .
porkiespeedster is offline   Reply With Quote
Old Dec 11th, 2011, 4:15 pm   #2 (permalink)
rideserotta's Avatar
Kill switch?
2007 GT1000
History:
2005 Monster 620
2000 Suzuki Katana
rideserotta is offline   Reply With Quote
Old Dec 11th, 2011, 4:16 pm   #3 (permalink)
Sounds like your battery is bad/dead. Voltage regulator does nothing if the bike isn't running
arbakken is offline   Reply With Quote
Old Dec 11th, 2011, 4:22 pm   #4 (permalink)
Kill switch is in the OK position .
Battery sounds strange , as this was replaced some 6 months ago by a new one .
regs Harald
Old Dec 11th, 2011, 5:54 pm   #5 (permalink)
Air_Cooled_Nut's Avatar
Images: 2
Check the voltage of the battery. Needs to be more than 12v...close to 13v I believe. Bike in neutral, kick-stand down.
Toby
2006 Ducati Sport Classic 1000 monoposto(click me) | '72 VW Squareback, 2007cc, GB 5-speed, rag top | '76 VW Riviera Sundowner 2.0L, family camper | '95 VW Jetta GL 2.0L, Close-ratio tranny, LSD, modified engine
Air_Cooled_Nut is offline   Reply With Quote
Old Dec 11th, 2011, 5:54 pm   #6 (permalink)
Ditto on the battery being the problem, check connections.
When I was fast,
motorcycles were slow.
Now motorcycles are fast,
and I'm slow.
- Melvin "Swede" Dunlap, 1966
Cafe racers are built,
not bought.
The older I get,
the faster I was.
1duckyboy is offline   Reply With Quote
Old Dec 12th, 2011, 1:46 am   #7 (permalink)
Ok I'll disconnect the battery form the charger this evening , and see what the voltage does after a few hours .
Still does sound strange to me as the battery was changed recently and I keep it on charge by a battery conditioner/charging system in between rides .
Cheers , Harald
Old Dec 12th, 2011, 6:25 am   #8 (permalink)
NExE's Avatar
Easy checks:
Check voltage.
Get on bike. Kick-Stand Up. Click into 1st; then back to neutral. Pull the clutch in. Toggle the Kill Switch Off/On. Try to start.
That should take the kick-stand switch and false neutral out of the equation.
Not as easy check.
One of the connections to the new battery might be loose. Check/Clean/Tigten the battery terminals. Check/Clean/Tighten the connection to the starter coil.
Missing something here...
Sport 1000 Biposto:
Paul Smith Fork Guard & Oil Cooler Guard, GTRossi Touring Hugger, Fat Duc O2, Fastbike Fork Frame Swingarm Sliders, Desmo Case Saver, Gerhart Gauge Lowering Bracket, Kuan Steering Damper, AG Hammer Fork Brace, Dobeck EJK, caCW Air Filters, TPO Idle Air & Crankcase Breather, Aella EVO.
The Past:
2004 BMW R1100S BoxerCup Prep
2003 BMW R1150R
1996 BMW R1100GS
NExE is online now   Reply With Quote
Old Dec 12th, 2011, 7:25 am   #9 (permalink)
Lifetime Premium
YellowDuck's Avatar
Sounds like a battery connection. Could also be the connection to the starter, but I doubt it.
YellowDuck is offline   Reply With Quote
Old Dec 12th, 2011, 1:50 pm   #10 (permalink)
rmarinel's Avatar
Images: 16
Not to scare you, but I had this problem on and off for the first 4 years I had my bike! Tried everything, would work for a week...a month...longer then go again! Eventually we traced it to corrosion in the wiring loom, on the live feed no less!!!!
The normal cause I believe is a bad earth, but worth checking the live circuit as well. My problem was that I used the bike in winter a couple of times and the salt here seems to have got into all the wiring, everything is so exposed on these bike! After cutting back and using good quality cables, fixings and sealing it all I've had not problems since!
R
rmarinel is offline   Reply With Quote
broke just before the H 800ssKoeing Supersport 2 Sep 25th, 2009 5:24 am
FE broke it's belts BobHancock Supersport 43 Jan 16th, 2008 8:43 am
I broke my do-dad....... fdpalm Sport Classic 8 May 25th, 2007 12:21 pm
