Reverse Gear Shifter Recommendations? - Ducati.ms - The Ultimate Ducati Forum
Old Dec 7th, 2011, 3:32 am   #1 (permalink)
Ducatisti23's Avatar
Before I start researching... can anyone recommend a reverse gear shifter that they have used/seen. It would need to be adjustable for reach.
Cheers.
Martin
'06 Sport 1000
'01 WR250F
Ducatisti23 is offline   Reply With Quote
Old Dec 7th, 2011, 6:11 am   #2 (permalink)
Lifetime Premium
YellowDuck's Avatar
Motowheels sells a number of them. Not sure how much adjustability you need, but the eccentric toe peg provides some - about 1" or so.
I have their standard shift lever. It is very nice, but a bit shorter than stock even adjusted to max length, and so a bit more effort to shift.
Good luck finding any of them on MW's "improved" website though. Wow - the old setup was so much easier to use!
YellowDuck is offline   Reply With Quote
Old Dec 7th, 2011, 6:16 am   #3 (permalink)
BlackKat's Avatar
I have the SSR. They offer 2 versions, but one is intended specifically to be used with stock controls. works very well. Also, like 1/2 the price of the rest.
BlackKat is offline   Reply With Quote
Old Dec 7th, 2011, 7:17 am   #4 (permalink)
I use the stock '06 rearsets with the clamp on the transmisson shift shaft flipped over 180 degrees. I also put a slight "S" bend in the shifter rod for better mechanical advantage. You can do it without the bending the rod to see how you like it. Once in a while I still bang the shifter the wrong direction.
When I was fast,
motorcycles were slow.
Now motorcycles are fast,
and I'm slow.
- Melvin "Swede" Dunlap, 1966
Cafe racers are built,
not bought.
The older I get,
the faster I was.
1duckyboy is offline   Reply With Quote
Old Dec 7th, 2011, 8:41 am   #5 (permalink)
rideserotta's Avatar
What are the advantages to a reverse shifter?
2007 GT1000
History:
2005 Monster 620
2000 Suzuki Katana
rideserotta is offline   Reply With Quote
Old Dec 7th, 2011, 10:52 am   #6 (permalink)
Lifetime Premium
YellowDuck's Avatar
For one, you can have your foot ready to shift up exiting a full-lean corner, without dragging your toes on the ground. Downshifting is usually done when upright, so no issue putting your foot under the lever for that.
Personally, even on the track, I am nowhere near needing to do this...besides, the first dozen laps would be terrifying.
Old Dec 7th, 2011, 12:46 pm   #7 (permalink)
Official Sponsor
MotoRefugee's Avatar
Images: 3
From Motowheels.com your only two clicks away from our foot controls section. Just go to Motowheels.com click on parts, then click on foot controls.
MW Billet Reverse Shift Lever: Ducati w/ Toe Peg
SSR Short Billet Reverse Shifter
Motowheels.com is your #1 source for performance parts for your Ducati or European motorcycle.
Matt Walker
916-369-2509
matt@motowheels.com
Performance Motorcycle Specialist.
FACEBOOK | Twitter | MOTOWHEELS.COM
Dainese | OZ Motorbike Wheels| Spark Exhaust | Corse Dynamics | Brembo | Termignoni | Speedymoto | Surflex
MotoRefugee is offline   Reply With Quote
Old Dec 7th, 2011, 12:51 pm   #8 (permalink)
barfer's Avatar
Images: 29
I use woodcraft. I like it.
barfer is offline   Reply With Quote
Old Dec 7th, 2011, 3:04 pm   #9 (permalink)
weird! I didn't even know things like this existed. It would definitely make my ATV to street bike transition much more seamless
arbakken is offline   Reply With Quote
Old Dec 8th, 2011, 4:21 am   #10 (permalink)
Thanks for all the replies. I will check out all the suggestions.
Martin
'06 Sport 1000
'01 WR250F
FS: Ducati Performance Power Shifter w/ Reverse Gear Change - NEW WCMoto Parts and Accessories 6 Oct 22nd, 2011 6:20 pm
FS: CNC Reverse Shifter - Black Il_Toro_Nero Parts and Accessories 5 Sep 23rd, 2011 8:40 am
pic req: DP reverse shifter buell2duc Superbikes 0 Nov 30th, 2010 3:24 pm
SSR reverse shifter on an sc joshtw709 Sport Classic 4 May 18th, 2010 7:16 pm
reverse shifter? parabellum Sport Classic 11 Jul 24th, 2008 12:05 am
