2-valve measuring & adjusting worksheet - Ducati.ms - The Ultimate Ducati Forum
Old Dec 2nd, 2011, 1:02 am   #1 (permalink)
dietrichpfeifer's Avatar
I put a worksheet together based on info culled from the web, manuals, and my own way of adjusting valves on my own and several friend's bikes. It may not be for everybody, and I know there are other worksheets out there. I don't do the "loaded gap" method, as I like to measure the closing shims directly when depressing the closing rockers.
Anyway, here's a link the the excell doc if you want to save a copy:
Ducati 2-valve Worksheet
dietrichpfeifer is offline   Reply With Quote
Old Dec 2nd, 2011, 1:34 am   #2 (permalink)
GiaGT1000's Avatar
it says "invalid url"
Gia
2006 Ducati GT 1000
2005 Triumph Bonneville
1974 Vespa 50
GiaGT1000 is online now   Reply With Quote
Old Dec 2nd, 2011, 1:36 am   #3 (permalink)
Cunning Linguist
greggers's Avatar
Fixed
greggers is offline   Reply With Quote
Old Dec 2nd, 2011, 1:41 am   #4 (permalink)
rapete's Avatar
Images: 5
Thanks both of you! IŽll attend a maintenance training for 2V-Desmos in february to finally become independent...last service valve checking was done or so i was told only to let the clearance check again 2k km later...
rapete is offline   Reply With Quote
Old Dec 2nd, 2011, 2:04 am   #5 (permalink)
Originally Posted by greggers View Post
Whoops! Sorry guys, it should be fixed now, or use greggers link.
Old Dec 2nd, 2011, 8:44 am   #6 (permalink)
spyvito's Avatar
thanks very much!
"kick the tires, light the fires!"
2007 DB6
2006 Mutleystrada 620 (1/5 Ton of Fun, 2nd tank)
Contact Jared Schoenly [jschoenly@gmail.com] for custom machining work. He's a friend in PA.
spyvito is online now   Reply With Quote
Old Dec 2nd, 2011, 12:39 pm   #7 (permalink)
Location: Latitude: N49.13.46', Longitude:W123.05'.13, 01 966 Monster, 06 SC Monoposto, 07 SC BiPosto, 73 CB 750 Honda, 75 Harley Shovelhead
EXCELLENT Deit ! Saves my scrawling ! Tried to print it off but wont print past " VERTICAL CYLINDER " ...???
Stephano
muzzmann is offline   Reply With Quote
Old Dec 2nd, 2011, 12:59 pm   #8 (permalink)
Shoot. Might have to save it down then reset the print area. I've attached PDF to this post, should be easier to print but you can't edit it.
Old Dec 2nd, 2011, 2:36 pm   #9 (permalink)
Riderjeff's Avatar
Friggin' Brilliant! As usual...
The best tools are the simplest ones.
Riderjeff is offline   Reply With Quote
Old Dec 2nd, 2011, 2:56 pm   #10 (permalink)
Thank you!
ct_mazi is offline   Reply With Quote
2-valve measuring & adjusting worksheet dietrichpfeifer Hall of Wisdom 2 Dec 19th, 2011 5:20 pm
Valve Adjusting Class jack Sport Touring 3 Mar 17th, 2011 3:06 pm
Some measuring help please? Joe-B Superbikes 3 Apr 6th, 2010 5:19 pm
Winter maintenance: valve shim measuring questions babyman1737 Supersport 1 Nov 18th, 2009 1:38 am
Valve adjusting j911brick Superbikes 7 Nov 22nd, 2006 10:35 am
