Alternative Rear End - Ducati.ms - The Ultimate Ducati Forum
Old Nov 28th, 2011, 9:21 am   #1 (permalink)
LondonDutch's Avatar
Well, it's not finished - but it's coming along nicely.
I wanted a clean, minimal, timeless look to the back of my Duc, not necessarily retro or classic, but definitely not modern or date-able.
I've had bullet-shaped indies on the bikes for a while, and then found these integrated light/brake/indies on the Shin-Yo website in Germany (thanks MojoDuc), which would give me that 'Jetsons' modern-retro vibe, with as few components as possible, eliminating the need for separate indies - but leaving a few issues in attaching the license plate.
Fitting the lights was as easy as you could possibly imagine, as I simply drilled out the two rear that hold the back of the OEM tail and just bolted them through.
To attach the license plate I made a very simple T-shaped bracket from 3mm steel, and painted it black. It attaches to the same bolts that hold the seat lock on to the subframe - I just put two longer bolts on. This means very easy removal for track days or shows.
It's not pretty or clever, but it looks neat once finished and painted - and it does the job
I'm sure the end result won't be to everyone's taste - but I like it.
It's not finished. For some reason, one indie flashes faster than the other, but two LED flasher relays will sort that., but they are certainly clear and bright enough. I also plan to attach a number plate light... The wiring is there and it'll sit nicely on the simple bracket.
The bike is back to it's original red for now, but this will change soon.
...Meanwhile I hope some of you appreciate my Simoncelli tribute. Gone but not Forgotten: 58.
...And if you wanna know where the battery is, the OEM unit is under the seat in the undertray.
LondonDutch is offline   Reply With Quote
Old Nov 28th, 2011, 12:48 pm   #2 (permalink)
Air_Cooled_Nut's Avatar
Images: 2
I believe you should only need one relay for the LED flasher.
I like the tail pod. Makes me want to get one for my bike.
Toby
2006 Ducati Sport Classic 1000 monoposto(click me) | '72 VW Squareback, 2007cc, GB 5-speed, rag top | '76 VW Riviera Sundowner 2.0L, family camper | '95 VW Jetta GL 2.0L, Close-ratio tranny, LSD, modified engine
Air_Cooled_Nut is offline   Reply With Quote
Old Nov 28th, 2011, 1:05 pm   #3 (permalink)
Do you mean I only need one relay on the right hand side - i.e. for the one indie that flashes faster? (It's very odd that the L/H side is fine)
I love the tail pod. It just looks proper 70s. Now that I have one, I can't imagine the old look.
Old Nov 28th, 2011, 3:42 pm   #4 (permalink)
Images: 2
One relay that handles all of the turn signaling needs. It doesn't matter that one side works and the other doesn't. BTW, isn't the wiring swapped for the turn signals on one side of the bike? I don't recall if it was just a front or rear signal issue or both ends were affected. Maybe that is causing the issue?
Toby
Old Nov 28th, 2011, 4:02 pm   #5 (permalink)
Both right indies are flashing faster now that I've added the LED rear.
The left hand side flashes as normal.
Previously I had aftermarket indies but both used bulbs, (which I think offer their own resistance). I also read (somewhere on here?) that the actual flashing of the indies was governed electronically somewhere in the clocks, rather than by resistance, but that could be crap.
Are you saying that I should put the replay on any one of the two right indies to fix it, or that one relay should sit somewhere else in the loom?
Previously, when I've put LED indies on other bikes they ALL flashed too fast and I needed to fit a pair of relays to just back or front.
Old Nov 28th, 2011, 4:09 pm   #6 (permalink)
Images: 2
Sorry LD, I don't know.
Toby
Old Nov 28th, 2011, 9:25 pm   #7 (permalink)
flyhack72's Avatar
I don't tell guys this very often: I like the look of your rear!
Simple, clean and cheap!
Jason
Paul Smart 1000LE
Multistrada 1000DS
flyhack72 is offline   Reply With Quote
Old Nov 28th, 2011, 9:32 pm   #8 (permalink)
sportbob's Avatar
What seat is that LD? It's all sweet!
Durango, Colorado
"Old dog learns new trick"
Currently-'07 1000s ...some mods.....
Previously-
'80 Ducati 900ss, Bevel
Benelli 750 sei
Ducati 860 GT
Norton 850 Commando
60's Triumph Daytona
71 Yamaha 650 (OUCH!)
sportbob is offline   Reply With Quote
Old Nov 28th, 2011, 11:46 pm   #9 (permalink)
whitelightning99's Avatar
You're saying relay, but I'm thinking you mean resistor. Adding a resistor to match an incandescent bulbs resistance is a common ploy. The other, more elegant way is to use an LCD-specific relay that handles the flashing for all of the lights.
'04 ST3
'07 GT1000
'08 Multistrada /s
'11 Harley Street Glide
whitelightning99 is offline   Reply With Quote
Old Nov 29th, 2011, 1:37 am   #10 (permalink)
Coming along nicely Dutch.
adamld83 is offline   Reply With Quote
1098 Rear Brake Pin Alternative? Tractionless Superbikes 16 Jul 2nd, 2011 12:22 pm
ST Alternative stryder Sport Touring 5 Aug 20th, 2008 6:02 pm
Alternative to the HM? flatovercrest HyperMotard 47 Jun 19th, 2007 8:38 pm
Rear Turn Signal alternative AzCamel Superbikes 28 Jun 9th, 2006 9:09 am
