Battery Help! - Ducati.ms - The Ultimate Ducati Forum
Old Nov 20th, 2011, 4:32 pm   #1 (permalink)
LondonDutch's Avatar
Battery Help!
After being recommended Racing Batteries by Tim & Kev at Spirit of the Seventies, I spoke with them and they recommended that instead of swapping out my OEM YT12B BS battery with the direct replacement - their RB 400010
RB400010 Racing Battery they suggested two small units, wires in parallel, which are here... RB120010 Racing Battery
They've now been hooked up as they should, but the bike won't start. Cold cranking amps are supposed to be enough, but amp hours are decreased. My local tech thinks the ECU demands more power.
Can anyone who understands these things help?
Thanks
LondonDutch is offline   Reply With Quote
Old Nov 20th, 2011, 5:09 pm   #2 (permalink)
poolagent's Avatar
Thanks
Have you read this…
"You will also need a bigger battery if you have a Ducati or BMW motorcycle fitted with the stock ECU"
You have to replace the stock YT12B-4… so the type you have chosen is to weak…
IT IS NEVER TOO LATE FOR A HAPPY CHILDHOOD…
2007 Sport 1000 biposto
1978 Moto Guzzi LeMans Cafe Racer
http://thebikeshed.cc/2011/11/14/christians-lemans/
poolagent is offline   Reply With Quote
Old Nov 20th, 2011, 5:14 pm   #3 (permalink)
poolagent's Avatar
BTW… i would have bought this one to save weight…
TECNOPARTS Webshop - YT12B-4 BatterieION HJT12B-FP-S
Old Nov 21st, 2011, 12:04 am   #4 (permalink)
Hoppy's Avatar
Images: 2
LD - I initially fitted a slightly smaller battery but it didn't have enough power. The guys at Racing Batteries exchanged it for the RB400010.
I then had a tray made up to about a third of the depth of the battery, cut a section out of the undertray and mounted it where the regulator originally sat. I'll post some pictures latter this morning.
Hoppy is offline   Reply With Quote
Old Nov 21st, 2011, 12:10 am   #5 (permalink)
magnum2000's Avatar
Here's what I'm running. So far, so good. It's mounted under the seat where the regulator used to be.
Shorai Lithium Iron LiFePO4 Battery LFX14A2-BS12
Thanks
magnum2000 is offline   Reply With Quote
Old Nov 21st, 2011, 3:27 am   #6 (permalink)
Hoppy's Avatar
Images: 2
LD - Have a look at this thread
Slipper Clutch & LiFePo4 Battery
If you interested I can measure up the pan too.
Old Nov 21st, 2011, 6:09 am   #7 (permalink)
Thanks for these replies guys.
Racing Batteries have offered me a choice of either a third unit (free of charge) or to swap out with the RB400, also FOC. Can't say fairer than that - and if it ran your bike without trouble, Hoppy, then I would expect similar success...?
These things are always a bit trial and error.
Old Nov 21st, 2011, 7:04 am   #8 (permalink)
CU3RVO's Avatar
Images: 8
Quick question about those batteries guys.... Can you still use the battery Tender on them?
Just curious...
CU3RVO
2006 Monoposto, Yellow...
When asking a Ducati owner if he had any problems with his bike, his response was:
"The only problem I've had is attractive women divesting themselves of their clothing and rubbing their naughty bits on my leg while they lick the gas tank. Makes it hard to pull away from a red light,...... sometimes."
CU3RVO is online now   Reply With Quote
Old Nov 21st, 2011, 7:20 am   #9 (permalink)
Just curious...
They tell me that you look after the battery in the same way as any normal unit, and that includes running an Optimate, or similar.
Old Nov 21st, 2011, 7:29 pm   #10 (permalink)
magnum2000's Avatar
On mine you need a special charger. 6amp I think. It's $50 and does a complete charge in 10 minutes.
Something like this, though mine is the Westward 1JYV4A.
Westward 1JYU5 Battery Charger, 6/12V (M), 55 A Start
Just curious...
DIY: 696/796/1100 battery cable and battery upgrade romancommander Monster 16 Jan 2nd, 2012 11:37 pm
Battery's so dead, Battery Tender will not charge it... Tag Sport Classic 11 May 29th, 2011 3:31 pm
Dead Battery 2004 ST4s "is it a special or regular off of the shelf battery?" 2UpDuc Sport Touring 26 May 10th, 2008 2:10 pm
Battery box for smaller battery John Superbikes 8 Dec 2nd, 2007 9:29 pm
Battery help andpopst4 Sport Touring 3 Jun 21st, 2006 5:04 pm
