Tire pressures - Ducati.ms - The Ultimate Ducati Forum
Old Nov 17th, 2011, 7:36 am   #1 (permalink)
Tire pressures
What is the safest low pressure we can run our tires at,mine call for 42 lbs ,which I find to be way to much,extremely hard ride.
mouse action is offline   Reply With Quote
Old Nov 17th, 2011, 8:06 am   #2 (permalink)
Rtfm !
Best be checking your manual ASAP !
42 PSI sounds like the MAXIMUM tire manufacturers pressure - NOT what you should be using. It'll handle like crap....
Correct pressure are (converted from metric/BAR) around F32PSI R 36PSI (for my GT1000).
Ducati GT1000 2007 - Red
Bimota DB4 2000 - Tricolor
JeremyB is offline   Reply With Quote
Old Nov 17th, 2011, 9:28 am   #3 (permalink)
Images: 16
I run about 33 on my front, between 30-35 on rear.
'77 RD-400
'96 FXSTS
'03 FLSTF
'06 SC1000
'04 XL1200R
No H'2'o in the bunch!
jcasella is offline   Reply With Quote
Old Nov 17th, 2011, 9:49 am   #4 (permalink)
olducker's Avatar
I run 32 psi front and 34-36 psi rear.
Ken
'07 GT 1000 (Gray)
'74 750 GT
olducker is offline   Reply With Quote
Old Nov 17th, 2011, 10:02 am   #5 (permalink)
barfer's Avatar
Images: 29
I run 30 front 28 rear cold on the street.
If you want to know "how low you can go" on the track I run 25 or 26 cold on the rear because the tire gets so hot that it ends up at 31 hot.
42 is kind of absurd. It will get you long tire life and better gas mileage but far less traction.
barfer is offline   Reply With Quote
Old Nov 17th, 2011, 11:40 am   #6 (permalink)
YMRacing's Avatar
For track stuff, rule-of-thumb is that you want to have about a 10% rise in tire pressure from cold to *just off the track* hot. You might want to up the cold temp to about 28 on your rear and see how that works for you. Too hot of a tire will make it greasy feeling and will feather the edges.
YMRacing Road Race and Rider Schools
Garry W. Bird, Owner/Mgr
YMRacing is offline   Reply With Quote
Old Nov 17th, 2011, 1:11 pm   #7 (permalink)
Images: 2
For the street I run 29-30 on both front and rear cold. Track about 24-25 cold
Performance is a Matter of Choice
Performance Motorcycle Products
erikesp is offline   Reply With Quote
Old Nov 17th, 2011, 2:51 pm   #8 (permalink)
My manual says 2.2bar each for the Phantoms. I am running that in my 999 wheeled Dunlop Sportmaxx tyres.
Renn Sport is offline   Reply With Quote
Old Nov 17th, 2011, 4:14 pm   #9 (permalink)
reh
reh's Avatar
I run 34 on the Front, 36 on the Rear.
Recently I picked up my bike from a service, and riding home through a great twisty section of road I found that I was struggling to hold my line through the corners, and had to back off and take it easy. It wasn't until I went for my next ride and checked tire pressures and found that the service centre had pumped the tires up to 42psi
Setting the pressures back to what I normally run and all was good again !!!
Looking at the tire pressures listed in this thread I might experiment with lower pressures.
Rob
2007 Ducati Sport Classic 1000S (Red)
http://sites.google.com/site/ducatisport1000s/home
reh is offline   Reply With Quote
Old Nov 17th, 2011, 4:41 pm   #10 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
This has served me well.
Determining Best Tire Pressures
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
va duc is online now   Reply With Quote
tire pressures (848) ragweed316 Superbikes 9 Aug 31st, 2010 9:36 am
Streetfighter tire pressures? zvez StreetFighter 4 Jun 8th, 2009 4:39 am
Question on tire pressures tech7fab Supersport 2 Oct 30th, 2007 2:24 pm
Tire Pressures rabbot Sport Touring 6 Jan 2nd, 2007 6:33 pm
Tire Pressures johnrg Sport Classic 2 May 5th, 2006 6:01 am
