Nov 15th, 2011, 9:21 am
Making Brackets from sheet metal?
I need to make a bracket to hold my numberplate below my new rear light setup.
The shape has a few 90 degree bends, and just two firm mounting points up and under the subframe. It's an easy shape to cut and bend, but what metal do I use that will resist metal fatigue on the bends and fixings, ...for a design a bit like this
Thanks
Nov 15th, 2011, 11:07 am
how about mild steel? aluminum would also work
Nov 17th, 2011, 3:52 am
Official Sponsor
To hold any kind of passenger weight you need to use chrome molly. Other wise they may fold up under weight stress.
That being said the Exhaust are on there pretty firmly and they are amazingly rigid.
Nov 17th, 2011, 5:21 am
Thanks JC - although this bracket is just for a number plate, not the exhaust - so no passenger weight, just some thick perspex.
Nov 17th, 2011, 7:25 am
Location: Latitude: N49.13.46', Longitude:W123.05'.13, 01 966 Monster, 06 SC Monoposto, 07 SC BiPosto, 73 CB 750 Honda, 75 Harley Shovelhead
Thanks
Stainless steel ....
Nov 17th, 2011, 10:33 am
You could use just about anything if the thickness is right. I'm having a hard time judging the overall size of your part, but if the width of those arms is over 1" you could probably get away with 1/16" thick aluminum. I like aluminum because it doesn't rust and you can just clean it up and it looks OK without paint. The trick will be bending it. It will be hard to bend metal that would be thick enough to the sharp bends shown on your paper model. For instance if you have 1/16" thick aluminum you would probably tear the metal trying to bend it at square 90 degree bends. Just need to plan on small radius bends that's all.
Nov 17th, 2011, 9:46 pm
Official Sponsor
on our FLEDA plate bracket we use a .08" or 2mm aluminum plate and we bend it 115º
we have also used a heavier 1/8" plate that the FLEDA base late is made of but that was overkill
Nov 18th, 2011, 5:00 am
I use galvanized hurricane brackets, cut and bent to shape. They come in all kinds of sizes and configurations.
2006 749S (resurrected)
1995 900SSSP/track bike
2001 750SS/"rain bike"
1975 CB400F/Yoshima
1996 CR250R
2005 CR85R (for sale, still)
1971 Bultaco-project
2000 Z50R
Nov 18th, 2011, 8:10 am
^ +1 Joist hangers or any galvanized bracing from a building supply works and is probably drilled for lightness.  It comes in various shapes and thicknesses. Wipe it with vinegar before painting. Out here they're for earthquakes.
When I was fast,
motorcycles were slow.
Now motorcycles are fast,
and I'm slow.
- Melvin "Swede" Dunlap, 1966
Cafe racers are built,
not bought.
The older I get,
the faster I was.
Nov 18th, 2011, 9:11 am
Don't forget about heat. Adding heat to the metal makes it easier to bend
