Nov 13th, 2011, 6:34 pm
Leaking Rizoma's
I have Rizoma Master Cylinder Reservoirs fitted to the GT.
Every time I get home from a ride there is fluid on the outsides.
They are not overfull or leaking from the hoses.
Has anybody come across this problem, and if so how did you fix it?
tamuch
Nov 13th, 2011, 7:09 pm
Where exactly? Both leak? is it near the top? Maybe a pic?
CU3RVO
2006 Monoposto, Yellow...
When asking a Ducati owner if he had any problems with his bike, his response was:
"The only problem I've had is attractive women divesting themselves of their clothing and rubbing their naughty bits on my leg while they lick the gas tank. Makes it hard to pull away from a red light,...... sometimes."
Nov 13th, 2011, 7:15 pm
Actually, if the fluid is any higher than the top of the window, you ARE overfilling them. The pressure builds and it weeps out the caps.
Blinged out Yellow '06 SportClassic Sport 1000 Monoposto: Termi 2:2, Ceramic Coated Exhaust, DP Race ECU, Ducshop Hyperstacks, PCIII, SpeedyMoto Clutch Bling, Yoyodyne Clutch Slave, SpeedyMoto Sprocket Cover, Rizoma Timing Belt Covers, DP Bar Risers, Pazzo Racing Levers, Rizoma Billet Grips, Rizoma Bar Ends and Mirrors, Rizoma Reservoirs, National Cycle Fly Screen custom painted, DP Tank Bag/Bra, Storz-Ceriani Steering Damper, Sato Rearsets, Custom Brake Lever Peg by FFR, Nichols Engine Mount Bolts, Nichols Crankcase Cover, GP Fork Cartridges and suspension "magic" by CRST, SuperSprox 14-41 Sprocket/RK 520 Gold Chain Conversion, Alpina STS Tubeless Spoked Wheels, Brembo Gold Line 4 Piston Front Brake Calipers, Feroda Platinum Pads, Galfer Wave Rotors, SSR CNC Gas Cap and Oil Cap, DPCARS Fender Eliminator Kit, Cox Racing Group Oil Cooler Guard.
Red '99 750 Supersport Half Fairing: Sil-Moto CF Slip-ons, Evoluzione Clutch Slave, 14T Front Sprocket, Corbin Seat, Storz-Ceriani Steering Damper, otherwise stock.
Black '12 Honda CBR250R: (Keeps me entertained until I find the Black 749 that I am searching for) Too new to even have any mods, so totally stock.
Certified Peet's Coffee Junkie
Nov 13th, 2011, 7:18 pm
I've had the same problem for years.. it's just a slight weeping from the top of the reservoirs, most noticibly on the clutch side. it looks like it's weeping from the top but it only happens after aggressive riding. Maybe the bellows don't compress enough to allow for the expanding hot fluid returning to the reservoir and pressure pumps just the slightest bit of fluid out around the cap seal?
Ducadent
'07 biposto SC1K
Jersey City, NJ
black paint................no stripe, silver logo
shimmed forks...........kuan damper bracket
pazzo levers..............sd121 ohlins damper
shimmed tank............oberon 75mm fold out bar end mirrors
cannisterectomy........race ECU
rizoma reservoirs........1" headlamp drop shim
dpcars tail chop.........speedymoto frame sliders
cycle cat risers...........gerhart lay down gauge brackets
2:2 termis.................traxxion dynamics AK-20 fork inserts
Nov 13th, 2011, 9:13 pm
Thanks mate.
This sounds about right I think. Always there, but much worse after a blast. I will try reducing the level as far as possible and see what happens.
ta
Nov 13th, 2011, 9:50 pm
Ditto prev posts - my riz res did the same until I found the right max fluid level. Once set correctly they've never leaked since (for years)
...ask me about huggers
'06 S1K - with a few mods...
Carbie DS1000 cafe project in progress
Nov 14th, 2011, 9:10 am
they all leak. once or twice per ride, I wipe it with my glove.
07 Ducati Sport 1000 SE, 09 KTM EXC 530, 07 Yamaha R6
Nov 20th, 2011, 3:44 pm
It really is a function of having the level correct. And once you have it high and get fluid up into the threads, you really have to work to clean it out of the threads even when you lower the level. Brake fluid is a pain and will seep for many rides once you've had it overfull - I would clean the fine threads of the cap and reservoir with rubbing alcohol and let them dry before I put the cap back on.
If loud pipes save lives, imagine what learning to ride that thing could do!
