Aug 13th, 2006, 10:27 pm
Anyone in here only does oil change/maintenance every 6k miles?
According to a local dealer, after first 600 miles will only require servicing every 6k miles. 3k is only optional, as per dealer.
Any inputs will be greatly appreciated.
Thanks.
Aug 13th, 2006, 10:50 pm
Oil/filter change every 3k...religously. Especially since it's a wet clutch bike.
www.ducati-owners-group.com
Aug 13th, 2006, 11:37 pm
I apologize for my ignorance but I think that my 900 sport is a dry clutch, right?
Will that make a difference?
Aug 14th, 2006, 12:03 am
wet clutch is bathed in oil, dry clutches are not. the wet clutch causes a lot of shear friction which tends to break down oil faster. with synthetic oil and a dry clutch, 6k should be fine.
Blue Skies,
Dave
'05 SS1000ds
'02 748s
Aug 14th, 2006, 12:11 am
Thank you for your opinion. Would others agree to this though?
Aug 14th, 2006, 4:06 am
I have a '93 900SS and use 15/50 Pro4 which is fully synthetic and change it every 3000m, just to be on the safe side.
'93 900SS.
'09 Suzuki GSF1250K9 Bandit
'89 Suzuki GN250 (project)
UK Bikers
Aug 14th, 2006, 10:19 pm
Sorry to ask for such a newbie question: Do all Ducati dealers use synthetic oil as a standard or I have to suggest that?
Aug 14th, 2006, 10:38 pm
You're right, your 900 is a dry clutch. The 800's are wet. IMO, I'm changing my oil every 3,000 regardless. Even with a dry clutch, the engine and trans still share the oil. Keeping it fresh and clean keeps it happy. I can totally tell the difference in my 749's shifting when I change the oil. Can do that in both bikes for that matter. Did I just use "totally" in a scentence??
Aug 15th, 2006, 1:40 pm
Yes you SO did, hehe
'93 900SS.
UK Bikers
Aug 15th, 2006, 5:45 pm
Why have the dealer change your oil?
FYI that 'totally' loud clanging sound you hear at idle would be your dry clutch. It the way to tell a Duc from miles away without looking. (Aftermarket fiber clutch covers are even better/louder).
You will inevitably have someone ask you what is wrong with your bike, to which you must snort and say, "This, is a Ducati." With a long pause after 'this' to add effect.
