Will 916 clutch side engine case fit 900ss? - Ducati.ms - The Ultimate Ducati Forum
Old Aug 12th, 2006, 10:04 pm   #1 (permalink)
Hey guys and gals. I need to replace my right side engine case (clutch side), and was wondering if a 916 part will fit. They look identical, but I don't trust my eyes (especially when I'm just looking at a picture) to be the accurate judge of that. Thanks in advance!
andy900ss is offline   Reply With Quote
Old Aug 13th, 2006, 3:15 am   #2 (permalink)
gorma900's Avatar
Andy,
I can't say for certain, but I'm almost sure it will fit. Count the number of retaining screws - if the number of screws matches, the shape definately will.
Andre
'04 Multistrada 1000DS
'97 900SS
'82 900SS
gorma900 is offline   Reply With Quote
Old Aug 13th, 2006, 10:09 am   #3 (permalink)
pazzoduc's Avatar
You need to accurately measure many many things. Like cylinder stud spacing, bore diameter, sleeve depth, bearing journals, the list goes on....
It would probly be easier to source the correct part.
riding 'cause I need therapy
'06 KTM 625smc
pazzoduc is offline   Reply With Quote
Old Aug 14th, 2006, 1:35 pm   #4 (permalink)
blade625CT's Avatar
case cover [the part that covers the primary gears, oil pump etc]...yes. it even fits on a 750SS [I'm running one right now]
engine case, no. besides, you never mis-match engine cases. you must use a factory matched set.
blade625CT is offline   Reply With Quote
Clutch Hub Question '93 900ss TheToeCutter Supersport 5 Dec 16th, 2006 4:06 am
clutch swap 95 900ss duckgirlygirl Supersport 3 Mar 30th, 2006 6:12 pm
