Oil leak from clutch rod (slave cover side) - Ducati.ms - The Ultimate Ducati Forum
Old Sep 16th, 2008, 11:37 pm   #1 (permalink)
I've had this oil leak for about 2K miles. I removed the side cover and resealed it, better but still leaking. Thought perhaps slave cylinder (even though I wasn't losing any fluid I would have to do constant bleeds). Put on yoyodyne and new clutch rod--now just more of a seep. The clutch rod was all grooved down due to a bad roller bearing on the other end. I guess I'm wondering if the clutch rod were spinning like a drill bit, could of it hogged out the clutch rod hole on the side cover? There is no seal or o-ring there. What's supposed to keep the oil in? Just a close tolerance of rod and side cover hole?
Floundering is offline   Reply With Quote
Old Sep 16th, 2008, 11:59 pm   #2 (permalink)
re: Oil leak.
If I recall correctly there is a couple of o rings on the pushrod. Also check the small roller bearing in the opposite end of the shaft from your leak. It is probably junk if the pushrod was grooved. New o-rings and a new bearing would help to stabilize the pushrod and hopefully eliminate the leak.
Greg
97 916
96 Lucky Strike RGV250 VJ23
94 900SS SP
95 900SS SP
96 900SS SP
04 Aprilia Futura
gregsky is offline   Reply With Quote
Old Sep 17th, 2008, 7:07 am   #3 (permalink)
Hey Greg, you are right about that roller bearing being junk. I forgot to mention that I put in a new roller bearing and pressure plate bearing when I replaced the clutch rod and slave cylinder. The clutch rod came with new o-rings but they are on the other side. I guess that's what confuses me. It has two o-rings to keep oil out of the clutch side but nothing on the slave side.
Old Sep 17th, 2008, 7:58 am   #4 (permalink)
After reading your post, I started thinking about the clutch rod orientation. I just put it back in the way I pulled it out but logically the o-rings should go towards the altern. cover side being as the clutch side has it's own seal. Explains why it's been leaking ever since I bought it. Kind of chuckling that I didn't catch that it was backwards. Thanks.
WTD : Stock Clutch Cover Ferrell75002 HyperMotard 21 May 19th, 2009 5:24 pm
EVR Slipper Clutch - MUST SEE!!!!!!!!!!!! wrichards Superbikes 20 Nov 20th, 2007 10:46 am
Clutch Slave bleeding opinion914 Superbikes 3 Jan 29th, 2007 8:22 pm
03 999 coolant leak from water pump cover gasket?? please help!! brian777 Superbikes 3 Jul 31st, 2006 1:05 pm
What exactly is the typical clutch slave problem nathanTX Ducati Motorcycle Chat 5 Mar 13th, 2006 3:00 pm
